News
I backed the car out of the garage and there is only smoke out of exhaust on one side ??
Discussion in '360/430' started by tvoismo, Sep 14, 2018.
  1. tvoismo
    tvoismo Karting
    Jun 14, 2016
    83
    Norway
    Tor
    What is going on ?? So worried.
    Sent fra min SM-G955F via Tapatalk
  2. timwu12
    timwu12 Formula Junior
    500
    Houston, TX
    do you mean 1 out of the 2 pipes on each side or do you mean smoke on the driver vs passenger side?
    did you unplug your valves? if so, exhaust gases will only be coming out of 1 of the 2 pipes per side
  3. tvoismo
    tvoismo Karting
    Jun 14, 2016
    83
    Norway
    Tor
    2 pipes on one side.
  4. BlacktopRacing
    BlacktopRacing Formula Junior
    587
    Dale
    Is this a 360 or 430?
    How many miles on it?
    Do you have OEM exhaust manifolds?
    Is any other part of the exhaust NOT OEM?
  5. Skidkid
    Skidkid F1 Veteran
    Rossa Subscribed Owner
    Aug 25, 2005
    5,171
    Campbell, CA
    John Zornes
    And what do you mean by "smoke"? White, blue, ??? You may need to post a vid if you want any useful feedback OR provide much more detail. One other question, is it running rough and are there any codes?
    cpep likes this.
  6. cpep
    cpep Formula Junior
    277
    new york
    CHARLIE
    Like skid said is it running okay? Maybe only half the engine is running. I had that happen a couple of weeks ago and had to shut it off and restart it.
    Skidkid and BlacktopRacing like this.
  7. BlacktopRacing
    587
    Dale
    Dare I say, anytime you put eight Italians in one room together, they're not going to wake up and go to sleep at the same time
    billy.gif and Ghostdiver like this.
  8. Skidkid
    Skidkid F1 Veteran
    Aug 25, 2005
    5,171
    Campbell, CA
    John Zornes
    Yep, my guess was going to be limp mode but there is not enough info to make anything but a WAG.
    cpep likes this.
  9. tvoismo
    tvoismo Karting
    Jun 14, 2016
    83
    Norway
    Tor
    There is just coming exhaust out of 2 of 4 pipes. ZERO from the back right pipes. The car has not been used in over a month. When I started the car, it was a flash thing with the lights + ( almost not starting ) could it be it was not starting on all cylinders ? thanks again
  10. tvoismo
    tvoismo Karting
    Jun 14, 2016
    83
    Norway
    Tor
    It has not been used in a couple of months. Could it be that the battery was Almost flat and just started "half" the engine?
  11. irix
    irix Rookie
    Aug 28, 2015
    30
    Germany
    J.B
    There is "limp mode" when the battery is too week to deliver AMPs to all the ECU and starts only half of the engine
    Sometomes you can see odd behaviour of the instrument cluster too.
    I have it once and only one bank of cylinders was running after starting. RPMs was low and it sounds very different, you can feel the temperature difference also .........believe me!
    Lesson learned. Use always your ctek battery charger on your FCar.
    Regards,
    Joerg
  12. tvoismo
    tvoismo Karting
    Jun 14, 2016
    83
    Norway
    Tor
    Thank you so much for the comment! I connected the ctek a couple of hours a ago. it was on 3/8 now its on 6/8 so It looks like the battery still lives :)
    So you think there is nothing more to worry about starting it up again when its on 8/8 on the ctek charger ?
  13. vrsurgeon
    vrsurgeon F1 World Champ
    12,068
    Charleston, SC
    Curt
    I didn’t know the creek was strong enough to charge a very low battery.. I’d charge it with a real charger personally.
  14. Mickster
    Mickster Formula Junior
    592
    Sweden
    Mikael Andersson
    If you got the ”one bank running only problem” you would hear the engine running really rough (if running at all). That would probably mean a shot ECU, though. Don’t know if that can happen due to low battery voltage..?
    Poorly maintained battery can cause all sorts of problem in our cars, I’m sad to say.
  15. tvoismo
    tvoismo Karting
    Jun 14, 2016
    83
    Norway
    Tor
    Did not quite understand this part ? Do you think I have a broken ECU ? I will always use the c-tek from now on :) When the c-tek is going 8/8 and green, its still safe to try starting the car? Thanks again people for the help.
  16. cpep
    cpep Formula Junior
    277
    new york
    CHARLIE
    It's actually a pretty common thing. When I bought my car the lead tech said it happens on occasion and like I said mine did it recently. I just shut it off and restarted then it was fine. That's one time in almost a year of having the car.
    Skidkid likes this.
  17. irix
    irix Rookie
    Aug 28, 2015
    30
    Germany
    J.B
    If you get 8/8 just start again. Put key in position 2 just wait 60sec. befor starting the engine.
    Regards,
    Joerg
  18. tvoismo
    tvoismo Karting
    Jun 14, 2016
    83
    Norway
    Tor
    The car startet right up again :) But I feel there is a bit more exhaust and heat coming from just one side. Is this normal ?
    Thanks again! I swear to the c-tek now.
  19. MalcQV
    MalcQV F1 Rookie
    2,700
    Manchester, UK
    Malc
    Don't both banks at some point prior to the silencer (muffler) or at it come together anyway?
  20. Themaven
    Themaven Formula 3
    2,438
    London
    Darius
    My 575 was v low battery recently after I forgot to plug in Ctek over 2 months. Lights went on dimly, turned over once, no more, didn't start, dash lights were on. Overnight on Ctek cured it. I think it would have been a different story with a completely dead battery though.
