I blame my Daughter | FerrariChat
I blame my Daughter
Discussion in '206/246' started by nerodino, Feb 11, 2007.
  1. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    #1 nerodino, Feb 11, 2007
  2. dm_n_stuff
    Dec 10, 2003
    43,715
    26.806311,-81.755805
    Dave M.
  3. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    Is it any wonder that you were distracted, poor attention or not. That sweet face could make you reinstall your engine IN THE FRONT:)
    Cheers, Hank
  4. sowest
    sowest Formula Junior
    Aug 18, 2006
    899
    #4 sowest, Feb 11, 2007
    Please use this with some caution. It is a diagram that I made from a Jarama cylinder, but I do believe that they may actually be the same part. In the diagram, the booster would be on the right.
  5. sowest
    Aug 18, 2006
    899
    Ooops! They can't be the same part. The Jarama has remote boosters so the actuation of the cylinder will be different, but I do think that the cylinder internals may be the same. I did a 365 C/4 a while ago and I seem to remember using this diagram as a reference. I looked through my notes and can't find a separate diagram for the Ferrari. I would normally make another if the assembly was different. Again, use the information with caution.
  6. sowest
    Aug 18, 2006
    899
    #6 sowest, Feb 11, 2007
    Someday I have to get organised. I did find my notes on the C/4. The cylinders are all a little different, but very similar at the same time. I enclose the diagram for the C/4. It is very similar in layout to yours and I think that it might offer better guidance than the other diagram. Again, use any of this information with great caution.
  7. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    #7 nerodino, Feb 17, 2007
    Sowest, thanks for the drawings but i don't believe either appertain to my car, These photo's show how i think it should go but in the third photo i am showing the smaller piston of the two which i think its cutout groove shown must line up with the banjo fitting which protudes into the piston cavity of the casting. this fitting fits in the second from right hole on the top picture of the cylinder casting, the left hand side is the side to which the slave piston/resovoir fits. Can anybody confirm or deny????
    G P
  8. sowest
    Aug 18, 2006
    899
    #8 sowest, Feb 18, 2007
    I think that I might finally have something that will help. The picture is of a cylinder that I just took apart from a Ghibli. It is Bonaldi and the body and internals look just like yours. The body does have side exit outlet ports, but that should make no difference. In this cylinder (and the others) the light spring rests directly against the pressure output rubber seal. The steel cup at one end of the light spring rests on the end of the heavy piston return spring. The heavy piston return spring always pushes the relevant piston back towards the booster.
    I am quite sure that the assembly shown in your picture is wrong.
  9. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Sowest, I like the look of that! Fantastic tommorow it goes back together that way.
    G P
  10. Mondialmike
    Mondialmike Karting
    Mar 12, 2005
    217
    London
    Mike Hunnisett
    Graham,
    Out of interest have you managed to source replacement seals? If so from where?
    Thnx.
  11. RP
    RP F1 World Champ
    Feb 9, 2005
    17,667
    Bocahuahua, Florxico
    Tone Def
    Absolutely, having two daughters, I would agree with you completely. Actually I forgto to install the engine altogether.
  12. dm_n_stuff
    Dec 10, 2003
    43,715
    Dave M.
    Mike/Graham. Are they just O-rings? Nothing special?
    I've got a ton of those in varying sizes, what's the OD, ID and thickness?
    Dave
  13. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Wouldn't standard butyl or neoprene O-rings be adversly affected by glycol based brake fluid, resulting in swelling and sealing loss?
    Viton might work, but I'll bet the correct material is made out of EPDM (Ethylene Propylene Diene Monomer), sames as flexible brake lines.
    Lines/O-rings for brakes, fuel, and water are different.
  14. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,808
    Cerritos, CA.
    Did you ask your daughter? maybe she knows how it's put together, you'll be surprise how smart this kids now adays.
  15. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Mike, These are available from www.superformance.co.uk
    G P
  16. BigTex
    79,379
    Houston, Texas
    Bubba
    Dino resto thread has a good pic in it....
