I Hate Electrical problems, GT4 | FerrariChat
Discussion in '308/328' started by 3px19, Aug 23, 2009.
  1. 3px19
    3px19 Karting
    Aug 29, 2006
    218
    Calvin crouch
    My horn circuit doesn't work, this includes cig lighter and clock.
    I find with multi meter I have 5v at the horn button, 0 at the horn when I push the horn button. I used to hear the relay click when pushing the button but now I don't.
    Tried switching around relays to see if problem. The horn relay works in other locations.
    Car is a 79, my earlier owners manual doesn't match the car. Is the horn relay on the lower row 3rd from the right?
    Being electrically challenged how do I go about figuring out what is going on with the circuit.
    Prior to this attempt to fix the circuit was blowing the fuse all the time so I just removed the fuse and now want to fix it.
    As stated I hate electrical problems and could use a tutorial and some good advice. And my old eyes can't read the wiring chart, too small and all just black.
    thanks
    Cal
  2. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Buy Paul's wiring guide on CD. Phone 1-503-472-5644. Problem solved.
  3. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,038
    I'm sure you will get many sympathizers over this issue. Intermittent problems bug me the most. It makes troubleshooting really un-fun!
    I would recommend to start with the fuse box. I mean replace both of them, or repair the buses on them. I soldered mine. The wires are robust. The junctions are usually the culprits. Also, relays do fail, but generally are pretty good as well. There's a strong following on these cars, and that's great 'cause you should get support for every possible problem that may arise.
  4. Beta Scorpion
    Beta Scorpion Formula 3
    Jun 22, 2006
    1,379
    Is your battery charged? You should have 12v at the horn button.
  5. Steve Magnusson
    26,861
    #5 Steve Magnusson, Aug 23, 2009
    +1, but just start with the fuses themselves. Per your OM, fuse #16 runs the horn, clock, and cig. lighter -- so remove/inspect/reinstall this 25A fuse. Measure the voltage at the top and bottom male tabs of the fuseblock of fuse #16 relative to ground -- both should be +12V.
  6. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    That's easily fixed. http://www.ferrari308gtbi.com/
  7. mustardfj40
    mustardfj40 Formula 3
    Jun 17, 2004
    1,142
    Northen California
    Ken
  8. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    While I don't like the presentation used for the 328 wiring diagrams, at least they are legible. Which wasn't the case for the 308 which got me started.
    So, sorry, no plans at this time.
  9. Harry
    Harry Karting
    Nov 1, 2003
    101
    Germany
    Take away the two fuse boxes and solder all the rivets to the bars they are holding. The rivets get loose with time and your electrical systems does funny things.
    Regards
    Harry
  10. RichardAguinsky
    RichardAguinsky Formula Junior
    Nov 12, 2007
    478
    Palo Alto, Californi
    Richard Aguinsky
    Hi Paul,
    You did a fabulous job on the wet site and diagrans.
    Any plans for a 1984 Mondial Cab US version? ;-)
  11. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    At the moment I'm trying to fulfill several requests for the 400i
    as they suck like the 308 diagrams.
    Yours is the first mention of Mondial in the 2 years. Plus
    my pdf Mondial OMs (1980, 1982-) don't have a diagram.
    What do you use now for electrical documentation? I have
    nothing to work from.
  12. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    #12 rolindsay, Aug 27, 2009
    Same with the Mondial QV diagrams. They are quite useful for tracing harness wires but useless in detail as all of the Mondial's "modules" are just represented as (black) boxes. Wanna know how the Check Control works? Good luck! Same with the oil level sensor, etc. No documentation other than where the wires go.
    Anyone ferrited out the many systems on this car?
    BTW, my car is a Standard Specification '83 Mondial QV.
  13. fgcfire8
    fgcfire8 Formula Junior
    Jan 19, 2008
    459
    Montpelier Va
    Frank Castelvecchi
    lol looks like common issue on mondials
    I have installed an additional fuse block with a bank of in cabin switches under the AC to be able to bypass fuse panel/circuit board issues. I also carry a set of jumper wires.
    Is there a replacement circuit board avail for 82 Mondial 8?
    Frank
