I HATE flat tires... | FerrariChat
Discussion in '348/355' started by whyte, Jan 10, 2008.
  1. whyte
    whyte Formula Junior
    Apr 25, 2006
    409
    Merritt Island, FL
    John C
    So I get out of work a bit early, ready to take in a beautiful Florida Winter drive home and..
    FLAT TIRE
    Luckily I had a spare tire (no rim) at home, so I called my pit crew* and managed to pump enough air into the flat to limp shamefully to the local tire shop, where they quickly determined my PZero was trashed and resorted to mounting my spare tire on the rim, and off I went.
    I have flatbed service, but honestly, I can change a tire in 30 minutes with a jack and be on my way. Many of you just carry the fix-a-flat. Is that a real mess to clean up when you have the new tire mounted?
    Anyone have an ugly rim lying around that holds air they want to part with for a reasonable fee? If not, is anyone else interested in perhaps buying and splitting a set of 4 so we all have a spare?
    Just thinking out loud while I enjoy my Spaten.
    *Wife, Niece and Daughter
  2. CavalloRosso
    CavalloRosso Formula 3
    Jul 12, 2007
    1,423
    Atlanta, GA/Vail, CO
    SVO
    Ooooh. Sorry this happened to you bud.
    By the way, Spaten ale, lager or Hefe (which has incidentally become my favorite Hefe of late)?
  3. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,975
    MD and NE
    Robbie
    I have an entire extra set that I have been thinking of using one to make a spare, but didn't know what to do with the other 3. Couldn't sell them as a set every again. May be an idea to sell off 3 of them as singles and keep one for myself...
  4. whyte
    Apr 25, 2006
    409
    Merritt Island, FL
    John C
    Hef. :)
    Amd if you are seriously considering it 285, let me know!
  5. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    Hamilton, NewZealand
    James
    The rear's are wider than the fronts, if you split up a set, how would you get around fitting a rear rim to the front of your car?
    Just thinking out loud.
  6. 285ferrari
    Sponsor
    Sep 11, 2004
    20,975
    MD and NE
    Robbie
    Duh-----Dumba$$ me didn't think about that....I guess a front will fit either way, but the rear may be too big for the front...Oh well - I'll just keep them -----then again I have seen single wheels fronts and rears sell on Ebay---I guess someone who bent the heck out of a rear may be looking for one....
  7. TheOnlyest
    TheOnlyest Formula 3
    Sep 25, 2007
    1,686
    Las Vegas Nevada, US
    Steve
    Every wheel on a 348 is unique to its location... but I spoze if it was just used as a spare to get you home or to the tire shop, it would'nt matter. You can use a front on the rear, but not a rear on the front... so only the front wheels would make suitable spares.
    If you really want a spare, you'd be better off to find a car that came with a space-saver spare, with a 5x108 bolt pattern from a junkyard or something. You'll also need to buy some short lug bolts off ebay... and you may have to drill some holes in the rim for those pins in the rotors to stick thru.
  8. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    +1. You might want to call tirerack, they have the small spares. You could ask if they have that bolt pattern.
  9. whyte
    Apr 25, 2006
    409
    Merritt Island, FL
    John C
    That's a good call.
    I actually was aware that they were different sizes, but with a separate set of lug bolts I figure you could at least limp to the nearest service station. In any case, a small spare would be a better solution.
    I'll see if I can track down a good thrid-party solution and I will share any findings with the brotherhood.
  10. Houston348
    Houston348 Formula 3
    Oct 18, 2006
    2,297
    but are they directional like the 348s?
    yeah, i would sell them one by one on ebay. there is always someone who just needs ONE and not a whole set
  11. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    Why not just order one Enkei 17x7 with a 5x108 bolt pattern with a Kumho Ecsta AST tire mounted from streetdreams.org?
    http://www.streetdreams.org/wheels/rims/Enkei/CDR9/Silver/17/7
    The wheel is $140, and the tire should be less than $100. So for around $250 you have a spare wheel and tire that you can use in a pinch.
    BT
  12. whyte
    Apr 25, 2006
    409
    Merritt Island, FL
    John C
    Great idea. I was concerned with mixing wheel types for balance issues, but frankly, I suppose anything in the ballpark is good enough to get 10-15 miles at low speed.
  13. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    You should be able to get to 50mph easy. That is what porsche recommends on the tiny donut for 911s
  14. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    The only caution would be to get shorter bolts if the stock ones do not compresss the wheel and carry a wrench to remove the mounting nibs... The streetdreams.org guys were really helpful when I ordered some tires from them recently and actually called the importer to confirm the hub diameter of a British car I have. I'd give them an A+.
    If you email them a picture of a wheel bolt they would probably know if it would work with the wheel I spec'd. You can go to their site and see what wheels are offered by bolt pattern...
    BT
