I have a KERS question/hypothesis - | FerrariChat
Discussion in 'F1' started by James_Woods, Apr 24, 2009.
  1. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    I believe that it was David Hobbs during Australia opining that some weird engine revving going on during downshifts was an ECU algorithm to help charge up the KERS -
    This made me wonder: What if you programmed the engine/transmission to declutch the drive wheels during deceleration and then rev the engine to make charge with the KERS motor/generator set? Then, your brake action would be fully by the friction brakes (probably more reliable & controllable) and maybe even more KERS charge could be obtained more quickly than by a true form of dynamic braking.
    The downside would be a little more fuel consumption, and of course that the intellectual dishonesty of "fuel economy via KERS" goes totally out the window. As if the sanctioning body really cared about intellectual honesty of these devices in the first place.
  2. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,867
    ESP
    Bas
    I guess by what you mean is that by declutching there will be zero engine braking correct?
    wont do any good at all as cars have to brake earlier than normal as they cant use the engine to slow down.
  3. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Well, to expand on what I was saying...engine braking is pretty minimal on these cars anyway as they can pull down at something like 4g maximum. The brakes are already more than powerful enough to haul the cars down at the full limit of traction anyway - and of course most of the brake action comes from the fronts.
    My conjecture was that it might actually be easier to modulate the rear brakes alone and use a decoupled engine blip for enhanced KERS charge. So, I don't think they would have to brake earlier at all.
  4. dretceterini
    dretceterini F1 Veteran
    Apr 28, 2004
    7,289
    Etceterini Land
    Dr.Stuart Schaller
    My concern with KERS is that if it doesn't get used for a few laps, does too much energy get channeled and stored in the batteries, causing them overheat? Is something like this the reason Kimi's butt got fried?
  5. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    I would assume that they have a charge manager (sort of like a voltage regulator) that should be preventing the above.
    Whether it actually WORKS is of course another question.
    These high charge/discharge rate batteries can be pretty unstable even at the nominally correct rates - being under vibration, heat stress, maybe water splashed on them while hot, etc. Most everybody who has run R/C airplanes or cars has sooner or later seen a big-time battery meltdown.
  6. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    If you disconnect the wheels/brakes from the generator/engine, yes, it would work. But you'd need a second clutch, because the seperable parts are Engine | Gearbox/Drivetrain and KERS | Drivetrain. You can't couple the engine and generator and seperate both from the drivetrain. Even if it was possible, the question is if it would make sense at all, as the generator is under full power during braking anyway, using the engine to power the generator would just switch the power source, nothing more.
  7. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Probably you are right, I was assuming the KERS motor was connected to the front of the engine (unclutched) and that the clutch paks (no idea if single or dual) were part of the gearbox.
    Not that it matters much as it looks like KERS was totally valueless this year as opposed to the diffuser.
  8. mousecatcher
    mousecatcher Formula 3
    Dec 18, 2007
    2,116
    san mateo, ca
    the engine already powers the generator. what would you be switching?
  9. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    IIRC it is different from team to team with most teams having placed the motor/generator behind the gearbox, and with a clutch of sorts. But (again IIRC) the motor/generator are seperated from the engine by the clutch. Not sure though.
    No, the generator is powered during braking.
  10. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Ha! The engine put in the inertia to be braked down in the first place.
    I am Mr. smartypants now! All others are imposters!
  11. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    You're so lucky I can't throw anything over the Atlantic right now :D
  12. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Well, at least you just about have me talked out of the disconnected wasted revs theory...
  13. mousecatcher
    Dec 18, 2007
    2,116
    san mateo, ca
    by the engine.
  14. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    He knows - Far Out and myself cannot go more than 3 days without a nice friendly science rumble.
    Without weapons, of course.
  15. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    No, the generator acts as a sort of "brake". The engine has nothing to do with it.
    :D
  16. mousecatcher
    Dec 18, 2007
    2,116
    san mateo, ca
    aww, where's the fun in that? always better when there's a danger of someone getting their eye poked out!
    sure, i realize that the engine isn't "powering" the generator, but the red bull video shows it connected to the front of the engine, like a harmonic balancer. so when the drive wheels are connected to the engine, on deceleration the generator can charge the battery. in that video, if the engine isn't turning (engine/gearbox declutched) the generator isn't turning. well i guess at minimum it could be going 6k or whatever the engines idle at.
    but now i see other videos, which are probably more accurate, showing the generator attached directly (not through the engine or gearbox) to the drive wheels.
  17. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    #17 James_Woods, Apr 24, 2009
    First of all, Florian is a German and can probably fence far better than I can. We stick to the .45 automatic here, and that is obviously outside the pale between men of science.
    The deal is that the wheels are spinning the engine up when no fuel is squirting (thus engine braking). The electronic modules let the generator in these engine braking moments charge the batteries. In "normal" KERS, the generator would not suck power from the engine (controlled electrically without a clutch) except under braking, letting the wheels turn the engine and charge the KERS.
    In "James KERS", the autobox would declutch the engine and let it rip up to full RPM (using fuel) against the KERS while the wheels depend only on the disk brakes. It was just a whimsical idea, after all...
