I have a seat belt issue... It locks up... | FerrariChat
Discussion in '308/328' started by ronfrohock, May 10, 2007.
  1. ronfrohock
    ronfrohock F1 Rookie
    4,174
    MA
    Ron Frohock
    When I try to pull out my seat belt - 88.5 Mondial Cab - it locks up unless I pull it out very very slowly. This happens only on the drives side.
    Any help - please?
    - Ron Frohock
  2. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    My 79 308 does that. The only thing I do is press on the inertia lock, and it releases the belt so you can pull the seatbelt out with no problems. It's on the back side of where the seatbelt comes out of.
  3. Mark 308 gt4
    Mark 308 gt4 Formula Junior
    Apr 24, 2006
    285
    West London
    Mark Taviner
    Hi Ron,
    Be carefull there may be a problem with the internal workings. You also may have a twist in the spool, pull it out all the way to the end of the belt and let it back keeping under a little pressure so it wraps back tight on the roll.
    Don't forget its your safety, if in doubt change it.
    Hope that helps
    Mark
  4. ronfrohock
    4,174
    MA
    Ron Frohock
    inertia lock is behind a panel and I cant get to it .
    I understand that I shoulnt mess with it - its a safety thing, although my will tells me otherwise...... Just want to kow if anyone has any experiance and or fixes.
  5. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Pull the whole thing out, clean it, put it back. May be a PITA to get to so you might try a little oil on the roller first with the belt pulled all the way out. Make sure you don't use too much or it will get on the seat belt, and don't use an oil with a strong smell!
    If it's anything like mine, it works on a simple pedulem that locks a sawtooth gear when you stop short, or pull the belt too hard. Years of dust/gunk are likely forcing the locking thingie to be right on the gear, so any small movement locks it up.
    I doubt the car is unsafe as is. As I have no idea personally how a Ferrari seat belt inertia drive may be different than mine, YMMV, but I would be surprised if it's anything you can't DIY as long as you don't have to take half the car apart to get to it.
    Ken
  6. ronfrohock
    4,174
    MA
    Ron Frohock
    I will do this week end and post back with the results.
    - Ron
  7. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    my 78 308 did this, i did not have to pull the mechanism, just sprayed wd40 onto the wheel/gear part of the retractor - did this 7 years ago - never a problem since...
  8. ronfrohock
    4,174
    MA
    Ron Frohock
    No more pulling at the belt, inch by inch. WD 40 and Ferrari Chat to the rescue.
    Thanks!
    - Ron Frohock
