I have filed for divorce from my CIS | FerrariChat
Discussion in '308/328' started by [email protected], Aug 19, 2009.
  1. andy2175m4@yahoo.com
    [email protected] Formula Junior
    Dec 7, 2008
    473
    Los Angeles, CA
    Andy Rein
    I have decided to file for divorce from my CIS system. The 1982 308 I bought was a rust bucket, and the CIS was no exception. After trying for several months to get the CIS to work properly, and get the car to run, I decided last night the only solution was to just install the Holley EFI system that's been sitting in a box in my garage for a year or so.
    This is not my first post on this topic, I hope you-all don't think I am a blasphemer for filing for divorce from the CIS, but I have decided it's just too much of a pain. Mainly because it's susceptible to corrosion. It's just rusted out and too expensive to replace.
    The Holley system is all digital, and works with Windows 98, XP, or whatever. I installed a Holley EFI system on my Thunderbird, and it started the first time I turned the key, go figure.....
    The only issue is whether or not I can get it to pass smog here in L.A. The CIS system was filling the neighborhood with smoke every time I started the Ferrari, so there's no doubt in my mind that the CIS (as it was) was never going to work (Unless I sent out the entire system for a professional rebuild and calibration, which I don't want to pay for).
    So, here we go: Tonight I removed the entire Bosch CIS system (and all that cold start nonsense) from the 308, and started down the road to a full EFI conversion for the 308.
    The first time I ever saw a Ferrari in the flesh was when I was cruising on Paseo Del Mar (Spanish for "path by the sea") on my Honda CB450 in 1976, and I came upon a very snappy red Italian sports car, that had the logo "308" on the back. I was very impressed with myself when I remembered that the logo stood for "3.0 liter V8", as I was an avid reader of Road and Track at the time, at the tender age of 18.....that was a long time ago, but the memory persists.
  2. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    would be very nice to see step-by-step pics of this conversion ;)
  3. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    Put the parts in a box on a shelf. They will be worth rebuilding to someone some day.
  4. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    Take pics and document this process. I want to see it step by step. What are you doing to make it work with the intake man.? Are you using the stock bosch pump?
  5. andy2175m4@yahoo.com
    Dec 7, 2008
    473
    Los Angeles, CA
    Andy Rein
    I am taking pictures, and I did stick the bosch system in a box, I have no plans to toss it, I just don't want to spend any more money on it right now.
    I have all the parts for the EFI, I just need to get 8 injectors that will fit into the tiny CIS injector holes in the mainfold.
    stay tuned for further details.
  6. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    Without seeing this manifold, i would suggest any competent machine shop could open up those holes to fit std Bosch injectors.
    Or, contact Arizona speed and Marine about machining and adding fuel rail brackets, thats mostly all they do is EFI. I would suggest Arizona TPI as a the first place to try though, as they are more receptive to custom work.
    You can probably find similar places in LA.
    Good luck,
    Doug
  7. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
  8. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    FWIW, I've been using 19lbs Ford 302 Mustang injectors - less than $200 for a set.
  9. woody6
    woody6 Karting
    Mar 9, 2009
    117
    Madison, AL
    Robert B.
    Andy,
    I've been thinking about the same sort of project, albeit with a haltech system I have sitting around. Are you aware that there are adapters to fit electronic injectors in the CIS injector manifold? Check out bitzracing dot com (link below)
    --Woody
    http://www.bitzracing.com/products/injector_bungs/index.html
  10. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    This is a slam-dunk how too project for the f-chat archives!
    Please doc your process, parts and such as there will be many people in the future that would love (or need to) convert in the future.
    Thanks for your work and willingness to share with the rest of the community.
    Best of luck!
  11. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    yeah ... that won't work in the 2V manifold ... follow my link ... I've already figured it and you won't have to pull the manifold. I've got a setup for the 4V also.
    cheers
  12. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #12 luckydynes, Aug 19, 2009
    Here's my setup ... I've put 550 hrs on this motor with this setup.
  13. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,177
    E ' ' '/ F
    Snike Fingersmith
    We've chased that down before, they don't fit the 2V or 4V.
  14. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Suggestion: Luckydynes has done this a couple of times - would research all of his threads & lessons learned.
    Good luck and have fun!!
  15. woody6
    woody6 Karting
    Mar 9, 2009
    117
    Madison, AL
    Robert B.
    Thanks, that's good to know.
    --Woody
  16. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,037
    That's a bit of a setback. I was very interested in this project for emission reasons. Having the injector open only when necesssary is very cool.
    Something to keep in your pocket is CIS Flowtech. It's owned by a very very talented CIS Guru. He could get you back to happy running with CIS.
  17. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Tillman was referring to the parts on the bitzracing link.
    Mine work without pulling the intakes. Pulling the manifolds to insert the injectors further is not a bad idea if you don't mind cutting up the manfiold. I thought people would be real sensitive about that but quite a few do it that way.
    cheers
  18. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Did I mention how much easier it is to work on these things with all that CIS stuff gone also? :)
    Another way to go about it is to make an adapter to replace the CIS "head" that you can run all the lines to instead of doing the fuel rails like I did. I was concerned about long line lengths with EFI and pulsation/resonance but I think someone has a system running like that ... could always do steel for a majority of the line and just make short bits to attach to the injectors ... just more ideas that have been kicked around more than once here. Still need some kind of bung for the injector if you don't want to pull the manifolds though.
    cheers
  19. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    When I first set my system up I only used the ignition portion of an E6x to run the twin distributors with the Kjet still installed. The Haltech read the stock triggers so basically there was no visual mod's to the car period.
    Then I added the EFI I still used the stock Ferrari triggers for about a year. When I upgraded to the coil on plug/direct fire ignition setup I had to install a better trigger setup.
    Com'n guys ... start pulling all that stuff off already :).
    cheers
  20. airdelroy
    airdelroy Formula Junior
    May 10, 2007
    420
    Austin, TX
    Aaron Richardson
    What are the differences in price from a CIS rebuild to a new ignition/injection setup?
    Aaron
  21. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    I don't know what CIS costs but here's some rough numbers for EFI.
    bungs/fuel rails $500-$1000 or free if you have a machine shop
    Haltech E6x with wiring harness .. new $1500 but seen them for $1000 or less
    2 channel ignitor for dizzy's ... $200
    Map sensor $100
    TB mod/bracket for position sensor ... $150
    Fuel pressure regulator ... $150
    injectors $200
    Misc hose/fittings ... that stuff adds up but might be cheaper options ... say $500
    what am I missing ... ouch ... install and tuning which can be painful. I think Mke is willing to do installs and tuning.
    If you want to direct fire/coil on plugs you'll need to upgrade the trigger.
    It adds up quick.
  22. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,037
    I presume Los Angeles Crazyfornia. I'd think it should be easier. The electro injectors only squirt when the intake valve is opening. Big improvement over the CIS when it comes to emissions. As for equipment, I wouldn't think a smog shop would get into that level of detail, and you'd be fine. I'd be curious to know what your raw sample exhaust is.
    Post some pix of the hardware that drops in to retrofit the injectors. Hope it goes smooth for you.
  23. gilligan308
    gilligan308 Karting
    Dec 8, 2008
    141
    S.W.Florida
    Brian
    Andy, The cis is not that complicated to get going.Plus parts are so readily available due to use on sooo many vehicles. Are you sure you dont have some thing else you want to spend the time on? OK We all want to choke the s..t out of the warm up regulator,piping ,fuel pump, accumulator,cold injector ,OK maybe it is a good idea to at least try a new fuel management system for fun.
  24. woody6
    woody6 Karting
    Mar 9, 2009
    117
    Madison, AL
    Robert B.
    In a sequential EFI system, each injector is timed like you say, but many systems are batch mode (all injectors fire at once). The E6X, for example, has only four chanels for injectors, so you can't do a full sequential setup with it (except on a car with four or less cylinders). Haltech does offer systems with more channels, but at significantly increased cost.
    While batch operation might sound less than ideal, the time between successive intake-valve opening events gets so short as RPM increases, that it isn't nearly as bad as one might think. Even the haltech's speed-density operation, now replaced by the OEMs with mass-airflow systems, is light-years ahead of the CIS.
    The only question is, is it worth it to make the change?
    --Woody
  25. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    http://www.youtube.com/watch?v=C9dNg-dAEBw&feature=channel
    This is behind the wheel video of my car out gunning a 360 and hanging with a new Porsche turbo ... no stock carb'd 308 or 328 goes like that. Only other engine mod is high compression pistons ... whether or not it's worth it is all relative ... absolutely priceless to me :).
    cheers
