I have starter problems too. | FerrariChat
Discussion in '308/328' started by lonnie77, Feb 23, 2011.
  1. lonnie77
    lonnie77 Karting
    Feb 17, 2011
    140
    Kennedale, Texas
    Lonnie Harrison
    First thing I did today was drain the gas. I have never seen green gas before but there it was. I kept wondering if I was draining antifreeze. I flush the tanks with a gallon of fresh gas and then added four gallons.
    I have installed a rebuilt starter and the engine did crank several times but did not start. I needed to know if the fuel pump was working so I removed an injector line and there was not a lot of pressure but there was some not so clear fluid. I guess the old gas in the line had not finished going through. I put the line back on and tried to start the engine but it would not crank.
    It does have an Alpine sec-8048 alarm system that seems to be working. I will trace down the starter control relay tomorrow. And look at the fuel filter.
    Any suggestions are welcomed. I have read the other starter problem threads and will follow that advice.
    I was happy it cranked I'm going in the right direction.
  2. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    perserverance furthers.
  3. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    If you search around, there is a way people cross a couple wires to get the fuel pump to run without cranking the engine, you might do that process to flush the lines and get a steady flow of fuel. Or maybe someone can jump in here if they know what it is.
