I have static on my AM radio | FerrariChat
Discussion in 'Technical Q&A' started by Bart, Jun 27, 2004.
  1. Bart
    Bart Formula 3
    Nov 1, 2003
    1,522
    Orange County, Calif
    Bart
    I listen to AM radio as I drive my 550. If I go under a bridge the static is terrible. Most of the time I can only get a couple of stations.
    I remember when I could replace the condenser on the distributor and the problem would be fixed. With the electronic ignition, I do not know what to do.
    Any ideas???
  2. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    FM?
    IPOD?
    XM?
    Just a 'lil light humor.
    Sorry no idea
  3. Jdubbya
    Jdubbya The $10 Trillion Man
    43,648
    Hell's waiting room
    AM Radio?? They actually put one in a 550?? AM will always cut out or get fuzzy when there is interference. The AM signal is not strong enough to penetrate any big obstructions! Try FM or a CD!!
  4. dm_n_stuff
    Dec 10, 2003
    43,879
    26.806311,-81.755805
    Dave M.
    Put a Ferrite core on the antenna lead into the radio add a power filter and a noise filter, all from Radio Shack and that should help cut the noise/interference down.
    Wander into Radio Shack, explain the problem (LEAVE THE WORD FERRARI OUT OF THE CONVERSATION) and they'll fix you up.
    You may need to use a combination of items, and even perhaps a signal booster for the antenna to get it right.
    YES, Radio Shack.
  5. f355spider
    f355spider F1 World Champ
    18,055
    Bart,
    is this a recent problem? If it is, then you may have a problem with the radio or antenna. Check grounds, and better yet, check with the dealer...there may be a TSB dealing with this.
