I just bought a 599 on BAT! | Page 2 | FerrariChat
Discussion in '612/599' started by cfensty, Jul 17, 2024.
  1. Dogdoc1
    Dogdoc1 Rookie
    Jan 28, 2016
    23
    Philly
    Congrats you will love it!
  2. AhmetUz
    AhmetUz Karting
    Aug 11, 2022
    160
    Congratulations :) , enjoy it. I always say that the 599 is one of the most beautiful modern Ferrari models in many ways. I hope you have lots of fun driving. Grigio silverstone is also a very stylish color. Also, what has been done to the car in general, has it been put into a detailed service or is yours a very well-maintained car that doesn't need it?
  3. cfensty
    cfensty Formula 3
    1,108
    South Carolina
    Well-maintained with history back to the beginning. It was due for F1 fluid service, the rest was me being meticulous. Engine oil was done in May so I did F1 system, gearbox, coolant, brake fluid and belts. I will do air filters and cabin filter myself, spark plugs next year with next oil service. I have to say this is the third F1 transmission I’ve had, which included a 360 with upgraded TCU and a late model 2008 F430 and the F1 Superfast is fantastic. So far I like it better than the numb DCT in my Cali T HS. I don’t think I will be converting this one after all!
    Skidkid likes this.
  4. cfensty
    cfensty Formula 3
    1,108
    South Carolina
    Okay, so I must admit that I am pretty proud of myself. Replaced two sticky switches and refinished two others. My glovebox “open” switch and parking sensor switch were bad and I found NOS replacements for a decent price. The R and “auto” switches were also sticky so I cleaned and refinished those. Wiped them clean with alcohol and then hit them with two coats of satin clear. That didn’t look factory enough so I put two coats of flat clear on top.
    UroTrash and mrp_e like this.
  5. cfensty
    cfensty Formula 3
    1,108
    South Carolina
  6. Qksilver
    Qksilver F1 Rookie
    4,587
    PC, UT
    Joe
    Interesting! Any idea what the difference between the original and the Maserati part is?
  7. cfensty
    cfensty Formula 3
    1,108
    South Carolina
    The Maserati strike plate has a metal sleeve over the pin, so it doesn’t get all tore up like the plastic one on the Ferrari part. You can see the plastic tearing off of the pin in the first photo. I actually believe the original strike plate has been superseded by the newer metal version when you look at the part suppliers.
    George Vosburgh likes this.
  8. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,429
    E ' ' '/ F
    Enzo Gorlomi
    What's the impact of that failure? A rattle in the door?
  9. cfensty
    cfensty Formula 3
    1,108
    South Carolina
    That’s one of them. In my case it was more about difficulty closing the door. In my F430 it was a rattle.
  10. diegolrz
    diegolrz Karting
    58
    Dallas TX
  11. cfensty
    cfensty Formula 3
    1,108
    South Carolina
    See post # 32 above. If you decide to replace yours, be sure to note the location of the original ones with a sharpie or with painters tape. Once you loosen the bolts, the nuts inside of the body will move around, and you will lose the location and have to start from scratch with adjustments. I marked mine and put the new ones in the same spot and only had very minor adjustments to get a good latch and the right gap.
  12. Gershwin
    Gershwin F1 Veteran
    Feb 21, 2005
    6,415
    Kentucky
    I’ve had manual Ferraris but I’ve come to love the transmission/paddles in the 599.
  13. cfensty
    cfensty Formula 3
    1,108
    South Carolina
    Finally got my hands on some Tubi test pipes. Installed them today and looking forward to a test drive tomorrow!
  14. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    955
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    Love my test pipes on my 599.Too muted otherwise.
    Skidkid likes this.
  15. lhanddds
    lhanddds Rookie
    Dec 9, 2024
    29
    Shreveport, Louisiana
    Larry Hand
  16. ferrarinewbie28
    Dec 15, 2023
    25
    Seattle, WA
    Have Fabio's test pipes on my car. Really wakes it up. I also pinned the valves to be open at all times - the forza controller might have been a better option but didn't want to deal with the hassle of wiring. I do need to fix those exact buttons at some point. Congrats on the beautiful car!
    Imstillonjava likes this.
  17. cfensty
    cfensty Formula 3
    1,108
    South Carolina
    Thank you. I’m thinking about just opening the valves permanently for now. I installed a valve controller on my California T and it was a real pain. Had to remove the entire rear bumper and I don’t want to go through that again! I also wasn’t real fond of having a 1980s looking remote control in the car all the time. I guess you can hardwire the switch, but it’s not going to be factory and that just requires more work to run wires.
  18. lhanddds
    lhanddds Rookie
    Dec 9, 2024
    29
    Larry Hand
    Some are simple some are not. I had a 07 Vantage and all you had to do was remove fuse 22.
  19. DZ-96
    DZ-96 Formula 3
    1,926
    South Germany
    Daniel
    Installing the valve controller at the 599 is easy.
    Just remove the rear underside panel and get the wire for the remote control unit inside the rear.
    Daniel
