I just finished my first belt+bearring change! | FerrariChat
Discussion in '308/328' started by stevel48, Jul 25, 2010.
  1. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Steve (85 308 Owner)
    AND the car started w/o issue! I was nervous though. I triple checked everything and then some. I guess I shoudn't be nervous since I followed the advice of a Ferrari mechanic and like I said, triple checked the belts, tension, touque specs and so on.
    It took me 3-4 weeks of on and off work to get it done. I took the time to clean everything I could see as well. I have a lot of photos and notes so I'll do a write up on changing the belts on an 85 QV and all of the little things you have to do, what to watch out for and what is different in Birdmans guide.
    Steve
    Many thanks to my local Ferrari Mechanic and Birdmans write up.
  2. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Good Work, Steve...It was fun wasn't it?
    Did you re-install your AC yet?
  3. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Yes it's in but need to charge it with Duracool. That thing has to weigh 20lbs alone. Everything would go much faster if that compressor wasn't there.
  4. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    What tripped me up was the front bank tension between the cam gears. At points in the revolution there was too much slack between them. I would measure the slack by grasping the belt between my thumb and index finger and moving it up and down. There was too much play when compared to the rear bank. The tensioner was not taking up the slack so what I did was this. I followed the tensioner spring movement during 2 rotations back to TDC and at about the 10 o'clock position the spring was applying as much tension as it could/would. I then rotated the exhaust cam a smidge to take up the slack between the cam gears and locked it down. Then I compared the 2 banks and the tension matched. I use the workshop method of tensioning where you rotate it twice and lock it down. That process worked well on the rear bank but the front bank needed a little tweaking to get right.
  5. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    I had similar results and had to recover the front bank timing. I did this successfully. I think the idea of loading the belt with moving the cam is a useful idea...should be the same as rotating the crank clockwise.
    Good work. What's the next project, Steve?
  6. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    #6 stevel48, Jul 25, 2010
    I think in the case of my front bank the spring may have been a bit tired. I would figure that the tensioner would have removed that play from between the cam gears but no, it didn't. So, I consulted my local mechanic. I cleaned and regreased the assembly but still no luck. I just felt in my gut that the tension was off. I felt that I ran the risk of slippage when the car was started again. That slight rotation of the exhaust cam (clockwise) did the trick. I would say it rotated 1/4 of a tooth to take up the slack. Obviosly that affects timing and such but that will all be addressed during a major. I rotated that engine maybe 15 times to make sure there was no interference.
    Next is diagnosing the rich running conditions. First oil, gerabox and coolant change.
  7. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    #7 stevel48, Jul 25, 2010
  8. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,919
    Atlanta
    John!
    No biggie huh? I remember my first time.....
  9. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    #9 stevel48, Jul 25, 2010
    Not to bad at all. I went slowly and every nut and bolt went into a labeled coin envelope and was noted on a diagram or photo. I had great advice along the way too.
    My mess
  10. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Nice vid.
    Looks like if you were "in time" and turned the forward cam pulley CW, you could load the belt to max. Is that what you did?
  11. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Gotta have a MESS to do it right:D...although you likely have accounted for all of it (does that mean it's still a mess?).
  12. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Steve,
    Good to hear she's back together and running...
    Glad to be of help and thanks again for the Dunkin' Donuts treat!
    Best,
    David
  13. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Correct but not sure if I loaded it to the max. I didn't apply any additional pressure to get the play out. I just helped the tensioner by giving it the slack that the spring didn't have enough umph to pull out. I gave the spring plenty of chances but it didnt do it as you can see in the video. I was in time when the new belts went on for sure but something wasn't right. If i rotated the intake cam pulley I would have created slack on the wrong side that could not be taken up.
  14. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Did you see that video David? That's where the trouble was.
  15. phrogs
    phrogs F1 Veteran
    7,358
    Kzoo Michigan
    Its pretty good fun doing this job isn't it!
    I enjoyed doing mine I love to tear cars apart!
