I Know, Dumb ?....Will 16" tires fit on TRX Wheel? | FerrariChat
Discussion in 'Boxers/TR/M' started by kerrywittig, Feb 8, 2009.
  1. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    I was just loading the 3 sets of wheels into the coach.......and then I noticed (it's about time) that one set of wheels is metric 415's. I was going to have these redone in satin black........but now...........why should I if they can only be shoud with metric tires.
    So..........if they won't accept 16" tires and those I hear are hard to find and expensive............
    Should I just get them restored to OEM silver? Is there a market for these wheels..........I am wondering if I should even invest in them. Restoration alone will be $700, and then I have my initial purchase price to add in. Any response, very quickly will be appreciated.........I'm departing at 12 midnite tonite (sunday 2/8/09)............I'd rather not take them if it is a loser project economically. I can't believe I over looked this!!!! Kerry
  2. AMA328
    AMA328 F1 Rookie
    Nov 12, 2002
    2,518
    ABQ-67me68-OKC :)
    Yeah, I'd bet 16" rubber would fit on a TRX wheel just fine...for about the first 200 yards you
    drive the car.
    TRX is a dead end, better to go with a 16" wheel and offsets, if needed.
  3. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    Wow, a Dumber response than the question I posed!
  4. Europeanroadandracing
    Europeanroadandracing South Carolina
    Dec 19, 2003
    2,228
    Isle of Palms, SC
    Karl Troy
    All jokes aside. The answer is NO.
    The 415s are actually 16.34 " in dia.
    Karl
  5. Steve Magnusson
    26,606
    #5 Steve Magnusson, Feb 8, 2009
    Unfortunately, incompatible in both directions (16" tires don't fit 415mm wheels and 415mm tires don't fit 16" wheels).
    I wouldn't invest anything more into them (although, if they are single-lug wheels, the steel spline piece might have value if it is the same as the 16" wheels spline piece). A case of oversupply meets no demand IMO. If they are 5-lug 415mm wheels, you'll be lucky to even get enough $ to cover the shipping charges -- if you can ever find a euro concorse-conscious buyer.
  6. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    Thanks Steve, I was afraid of this. My oversight though..........Yeah, since I posted in a panic I measured everything up, TRX tires, 16" tires, TRX wheels, 16" wheels....and it was quite evident that the answer was a big NO.....Thanks again for saving me some cash and frustration......Kerry
  7. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,423
    Alabama (was Mich.)
    Jeff
    I agree...the splined hubs, and trim rings if you have them, are worth some bucks. Too bad you cant machine the metric wheels down so that 16 inch rubber can be mounted, but I think too much material would have to be shaved off....about 3/16 of an inch thickness or so....reducing the safety factor too.
  8. dwhite
    dwhite F1 Rookie
    FYI, Not to offend, but Google can help avoid the dumb question factor. There are many conversion websites. Hey there is an idea for a sticky thread under technical helpful websites for info.
  9. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    First thing I did....www.worldwidemetric.com/metcal.htm .....go and convert metric to inches..........disappointment................so as a last breath before succumbing, I thought ask the FChat community....... there might at least be a market for these useless $500 of srap metal...NOT...live and learn!!!
  10. dwhite
    dwhite F1 Rookie
    I have a set of the 390mm w/ TRX tires and they are probably only good for a concours. Metric rims were not one of Ferraris best ideas :-(.
  11. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    #11 parkerfe, Feb 8, 2009
    If you want to keep and paint the stock wheels, you will need to get new TRX tires...try www.coker.com . The way most of us drive our Ferraris for weekend fun, TRX tires are just fine and using TRX wheels and tires will keep your car looking great. While they're a little pricey, they will likely need to be replaced in the future due to age rather than mileage...
  12. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    Yeah I'm aware of Coker, thank you though for bringing up. I just find it hard to swallow that I'll have $1200 into the wheels and another $1900 into tires for a total of $3100.............I could spend the money elsewhere for sure.
  13. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I had the TRX wheels on my BB512i refinished for $150 per wheel...
  14. ASG 86TR
    ASG 86TR Formula 3
    Aug 23, 2001
    1,474
    New Jersey
    Adam G
    Kerry....clean the wheels up nice, and make cool cocktail tables out of them with some nice thick glass sitting right on the rubber.
