I may need a new battery (430) | FerrariChat
Discussion in '360/430' started by CAracer, Dec 23, 2012.
  1. CAracer
    CAracer Karting
    Oct 26, 2012
    228
    Pflugerville, Texas
    John Blanor
    I will have my battery checked next week. If I need a new battery, should I go with the Interstate MTP-91? Is it a direct fit and should I purchase the vent kit? Does it really need to be vented? And where is the best place to purchase this battery in So Cal?
    And the last question, is it really necessary to perform the relearn process after installing a new battery? It seems like overkill. It I skip this step, what's the outcome?
    I did some researching and it seems like a pain in the ass to perform. Will the radio need a security code as well? If so, I don't have one.
    Before I change out the battery, I don't want more problems to follow.
    This should be an easy process and the least expensive one, considering the cost of everything else that can go wrong.
  2. m2g2
    m2g2 Formula 3 Owner
    Aug 10, 2012
    1,383
    SoCal
    Mark
    John, an accessory was left on my '08 f430 and ran the battery to Zip. I dug it out, disconnected the cables and charged it. Upon re-installation the radio needed to be re-coded, but that was it. No other discernible or "re-learn" issues. Check you manuals package for a card with the radio code on it, otherwise a dealer can get it for you I am told. Entering the code is simple...turn on the radio and it guides you through it.
  3. LTL
    LTL Karting
    Sep 26, 2011
    80
    City of Angels
    Leon
    I just changed the battery on my scud yesterday. I bought a battery tester and it showed that the battery was done. I bought a replacement battery at orielleys, being that I've never changed a battery before I didnt feel comfortable doing it on my car. However I was told it was really simple. Ive offered some money to one of the workers at orielleys to change my battery after he was off work and it only took him 30 mins to get everything done. You just need the code for the radio and if your alarm starting going off just lock and unlock the car with the remote key and everything should be fine. I posted a similar thread to yours 2 days ago (saturday). Hope it should resolve your issue.
    Happy Holidays
  4. DonJuan348
    DonJuan348 F1 Rookie Owner
    Aug 5, 2008
    4,442
    Taxing Jersey
    If you need a battery get a gel cel like Optima, Diehard gel etc . No vent needed
  5. CAracer
    CAracer Karting
    Oct 26, 2012
    228
    Pflugerville, Texas
    John Blanor
    thanks for all the replys. My car has had five previous owners and I know I don't have the radio code. So the dealer can supply it for me? If I don't have the code, then the radio is inoperable? And when hooking up the new battery, the alarm will sound and all is needed is to hit the fob to turn it off. Sounds easy enough.
    Thanks again.
  6. djkling
    djkling Formula Junior
    Sep 28, 2012
    498
    Newfields, NH
    Domenic
    Do you need to do anything in terms of "radio code" if you have an aftermarket radio???
  7. m2g2
    Aug 10, 2012
    1,383
    SoCal
    Mark
    Depends on the radio...most of them I would say no; but some do have the code feature.
    I've always wondered why they bother with the code. It's really a "who cares" situation. By the time some low-life gets to the point he discovers he needs the code, it's long since extracted from your car and sitting on his table in his house. The damage the low-life has inflicted to your Ferrari is five times the value of the crappy OEM Ferrari radio or your aftermarket model.
  8. CAracer
    CAracer Karting
    Oct 26, 2012
    228
    Pflugerville, Texas
    John Blanor
    I pulled the cover off and had the battery checked today. It's fine for now. So no need to purchase a new one. My battery even had the pig tails for the trickle charger already installed. I didn't know that.
    Anyway, I was talking with the guy from Autozone. They have a device that plugs into the diagnostics port. This device provide electric power to your vehicle while you change your battery. So therefore, no need to perform a relearn or re-code your radio. Great idea!
    They also bag up the battery leads, insulating them from shorting out, since they will be hot with the battery being backed up using their battery device.
    The only thing that scares me is that no one knows how mechanically inclined these guys are. If they short out your car, I'm not sure how liable they will be. He told me he does this all the time with Mercedes and other high end cars. He actually seemed quite confident and I might go with his system when I need a new battery. It would save me from pulling my radio to retrieve my personal code.
    Just thought I'd pass on this information for those looking at replacing their batteries.
  9. djkling
    Sep 28, 2012
    498
    Newfields, NH
    Domenic
    Im pretty sure they carry liability for damaging a car they work on.
    I had Jiffy Lube do a change on my old Mitsubishi Eclipse back in college... they forgot to add oil. By the time I went a block or two the car was toast.
    New Eclipse 2 weeks later.
  10. Nashtyboy
    Nashtyboy Formula Junior
    Sep 8, 2010
    429
    Raleigh, NC
    There is a process you are supposed to go through after putting in a new battery, but its very simple. I believe it's leaving the key in position II for ~15 seconds before starting it, and then letting it run at idle for some amount of time before driving it that first time. 15 mins or so I believe. Check the manual to verify.
  11. CAracer
    CAracer Karting
    Oct 26, 2012
    228
    Pflugerville, Texas
    John Blanor
    Nashtyboy,
    You're right. However, you have to have the radio code as well. If not, you need to pull the radio and get the serial # and request the code for your radio. When I purchased my car, it came with no radio code.
  12. Nashtyboy
    Sep 8, 2010
    429
    Raleigh, NC
    Or do what I do... leave it off
  13. rlips
    rlips Formula Junior
    Jul 29, 2011
    959
    New Jersey, USA
    Please do not do this. These cars can be very sensitive to electric charge, so much so that even jumping a battery can wreak havoc on your electrical system. I would NOT trust the word of an Autozone tech, these cars are specialized.
    If your Ferrari factory trained tech recommended this, then I would say "maybe," but given the many threads on damage just for jumping, I would be very careful. From what I understand, you are not even supposed to jump these cars, rather, you charge the battery in place or do a replacement.
    A fried electric system would be a very, very big deal.
  14. CAracer
    CAracer Karting
    Oct 26, 2012
    228
    Pflugerville, Texas
    John Blanor
    I'm sure you're right, good advice.
    Thanks,
  15. DonJuan348
    Aug 5, 2008
    4,442
    Taxing Jersey
    These are cars not planes . Get the radio or better scrap the crap factory unit for a new one. Turn off master power switch change battery ...
    Very simple less than one hours. I've done this a few time already
  16. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    Ditto what donJuan said, be careful, don't short anything out, Red to plus. do some thread searching as this happens often. It's not rocket surgery.
    Jeff Pintler
    89 348tb, 86tr, 99 360 3-pedal
