I need a brake fluid resevoir cap...Where can I get one? | FerrariChat
Discussion in 'Technical Q&A' started by up4speed, Oct 28, 2014.
  1. up4speed
    up4speed F1 Rookie
    3,691
    Long Island, NY
    Chris
    I tried to bleed my brakes today on my 2004 360 F1 using my Motive brake bleeder tool.
    I attempted to use the adaptor#1100 that is recommended by the manufacturer of the brake bleeder. For some reason, the threads did not match up. It felt like the cap was starting to thread on properly, but as soon as it started to engage, it felt hard to turn and it jumped the threads. I called Motive and asked about my issue. The guy said that some Ferraris for some reason don't work with the #1100 adaptor, so he told me that if I send him a spare cap for my reservoir, he will alter the cap and make an adaptor for the bleeder for me using the cap. The only problem is that I'm having a lot of trouble finding a cap to send him! The best I could do is find the whole reservoir and cap sold as a unit for approx. $120.
    I didn't want to spend that much and buy the whole tank. Does anyone have any idea where I can buy just the cap?
    Oh, by the way, there is a rubber button in the center of the cap, what is that button there for?
  2. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    Mine has no rubber button although on my other cars that has reset the brake light..should it come on for low fluid etc. try aw autoparts for a cap...maybe they have one...strange that the Motive doesn't fit...mine does just fine...wonder if somebody put a goofy cap on your brake tank?
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,521
    Charleston, SC
    Curt
    Chris does your reservoir have a brake fluid level sensor? Mine has the sensor in the brake fluid reservoir cap.. is that what the rubber plug you're referring to fills?
  4. Rifledriver
    37,082
    It has been talked about before. The reservoirs are very inconsistent and some just leak. Maybe one in ten cars I have a problem with.
    The rubber piece is not a button, it covers the electrical contact for the level sensor. I don't recall the 360 having that style cap though.
  5. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,242
    So Cal
    Bert
    Having same issue. Apparently the 1109 metal cap may work better according some
    Others commenting on this. Will have to try that since I want to bleed at home.
  6. up4speed
    up4speed F1 Rookie
    3,691
    Long Island, NY
    Chris
    The cap has an attached float device and wiring for the sensor. The top center has a rubber button on it that says something to the effect of "push to test" or something like that...
    See above response.
    I'm very confused. My first step in solving my issue is that I bought a used reservoir and cap from awparts. I'm going to see if it is the same setup that I have and if it is, I'm going to send the cap to the company that makes the Motive bleeder and they will alter the cap to work with my bleeder. I'll keep you guys posted on my success (or lack of).
  7. up4speed
    up4speed F1 Rookie
    3,691
    Long Island, NY
    Chris
    #7 up4speed, Nov 14, 2014
    Here is a picture of the Brake reservoir cap that I purchased. The rubber button on top is visible in the photo. After looking at it carefully, it appears that the float is attached to the orange rod. When I push the button while holding the rod, I can feel the rod under the rubber button. I have to guess that it is designed to be pushed in order to get an accurate level reading. If the float gets a little stuck and the level drops, the brake fluid level will appear correct until the button is pressed and the orange rod is pushed down, allowing the float to move down and have an accurate reading. I hope that makes sense, and it's just a guess.
    I already sent the cap to Motive Products so they can alter the cap to work as a bleeder for my car. I will post the outcome.
  8. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,242
    So Cal
    Bert
    I can not get the Motive 1100 adaptor to seal on the 360 or the Benz.
    Called them, lady claimed they never had a problem with 1100 on Euro cars....
    Told them the seal seemed thick, do they have a thinner seal ? Yes, and she sent
    a new seal out. Somewhat thinner, still leaks, does not work. It is leaking from
    seal on cap.
    Think I will get a mighty vac. unit, as I need to be able to bleed at home.
    Never had a problem with Motive bleeding the Vette.
    I have a big brake kit arriving Monday, so this sets me back.
    I hope that your cap you sent them works, no guarantee that the cap you sent
    can hold 15 psi.
  9. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,242
    So Cal
    Bert
    Etoolpros.com, they sell Mityvac cap adapters, mva804. I just bought one, $12
    for cap and $11 shipping. This is the Mityvac euro 45 mm adapter cap, mva804.
    Figured I would try that with the Motive pump.
  10. up4speed
    up4speed F1 Rookie
    3,691
    Long Island, NY
    Chris
    I have to hope that they tested it when they made it. I will obviously try it with an empty bleeder tank at first, just to make sure that it doesn't fail. If it fails, that would be a very bad thing! The guy told me that they have done the same thing for someone else that owns a Ferrari, and it worked perfectly for him.
    Please post back to let us know how it worked out. Hopefully it seals ok and hooks up to the Motive quick release. If I don't trust the cap that they made me, I may buy one of those too.
  11. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,242
    So Cal
    Bert
    I also ordered a Mityvac 8000 kit off Fleabay for $40 shipped,
    as backup in case the Mityvac cap does not work. The cap has a swivel
    head so a little easier to use than the Motive one.
    I have always used the Motive empty, a little more work but less chance
    of spills.
    Will post what happens.
  12. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,944
    The Cold North
    Tom
    Try a Porsche cayenne cap. They look the same. Wait a sec.. I have 2 360's in the shop right now and a couple of Porsches. I'll compair the caps for you on Monday.
  13. up4speed
    up4speed F1 Rookie
    3,691
    Long Island, NY
    Chris
    I have the Porsche cap. It works perfectly on my 911, but it will not tighten on the Ferrari. I have no idea why, it is supposed to work.
  14. up4speed
    up4speed F1 Rookie
    3,691
    Long Island, NY
    Chris
    #14 up4speed, Nov 17, 2014
  15. vrsurgeon
    16,521
    Charleston, SC
    Curt
    Nicely done!
  16. up4speed
    up4speed F1 Rookie
    3,691
    Long Island, NY
    Chris
    #16 up4speed, Nov 19, 2014
  17. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,032
    Summerfield, NC
    Tom Jones
    The red aluminum (may be the 1109) fits perfect. Mine does not have the part number on it so not 100% sure of the correct part number. I highly recommend the reinforced hose as the other hose will go bad and spring a leak in a few years.
  18. GT4 Joe
    GT4 Joe Formula Junior
    Oct 19, 2010
    833
    Dana Point, Ca.
    Joe Williams
    And if the hose leaks, you're going to ruin that Hello Kitty blanket!
