I need a new Starter Motor | FerrariChat
Discussion in '308/328' started by fishing, Mar 25, 2011.
  1. fishing
    fishing Karting
    Sep 3, 2006
    137
    Norway
    Harald
    I need to change my Starter Motor on my 308 GTB (1977).
    Anyone know the Bosch number for this or an other car using the same starter motor as the 308?
  2. deeprivergarage
    deeprivergarage Formula Junior
    Oct 3, 2009
    560
    S of Fort Worth
    Jerry
    I do not know of a cross reference number, but I would think it is likely that there may be an interchangeable unit, or at least the internal parts.
    However, depending on whether your problem is a bushing, drive/clutch, armature, or field windings, you may be able to substitute the parts from a comparable starter that merely mounts differently to the engine.
    There are usually some 308 starters listed on ebay, but the cost and shipping would likely be more than the cost to rebuild your starter.
    At least one company makes a high torque gear reduction starter for the 308. Listed on ebay.
    Also, rebuilding a starter is a common repair for an alt/gen/starter shop.
    Good luck,
    DRG
  3. flaviaman
    flaviaman Formula Junior
    Jul 26, 2005
    318
    Vernonia, OR
    Gregg
    Carb 308's came either with Bosch or Fiat starters, I believe the Fiat starter was used on the 130 model as well as a light truck.
    I do not know of a cross reference for the Bosch starter
    I have had both rebuilt at auto electric shops with success....
  4. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    First go to the part number cross reference thread:
    http://www.ferrarichat.com/forum/showthread.php?t=64460
    Use the 'Search This Thread' function at upper right below page numbers.
    Search for 'starter' - Note this search stays withing the cross ref # thread.
    Many Fiat cross references available
  5. SteveG75
    SteveG75 Formula Junior
    Nov 23, 2010
    380
    FL
    Stephen
    I had a local electric motor shop rebuild my starter for under $100. Didn't reinstall it though. Got the gear starter and very happy with it. Much smaller and lighter and car starts much faster. Worth the $$$. PM me if you want the contact info.
  6. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,025
    Unless it's a real mess, they rebuild nicely. The parts are real solid on both marelli and Bosch units. Find a good auto electric place. I recall the bosch unit has a different armature than other starter motors even though they'd fit. More hi rev support with cord about the winds etc.
  7. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    +1 - I've just had my 328 starter (and Alternator) rebuilt for very little.
  8. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    They aren't hard to do.
    They used to teach starter, generator and alternator rebuilding in high school auto shop.
    Dunno if they still, do, but not important.
    As long at the armature doesn't have a bad winding, which can be determined on a growler, a rebuild place can turn the commutator, install new brushes and bearings and solenoid, and starter drive, and you are good to go.
    That said, I would consider a newer gear drive starter.
    Doug
