I need a set of 348 spider wheel lug bolts. | FerrariChat
Discussion in 'California & Nevada (Northern)' started by morefun4us3, Apr 2, 2004.
  1. morefun4us3
    morefun4us3 Rookie
    Mar 1, 2004
    8
    Please reply if you know of a good used set.
    Thanks Randall
  2. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    Try Lyle Tanner Enterprises in Campbell?
    --Dan
  3. morefun4us3
    morefun4us3 Rookie
    Mar 1, 2004
    8
  4. vincent355
    vincent355 F1 Veteran
    6,516
    Wine Country
    Vincent
    Try Paul Hill. Hill engineering, He's a sponsor and sells lug bolts with his spacer sets. He probably would ship just the bolts. They're nice I had some when I had a 348.
  5. BigHead
    BigHead Formula Junior
    Oct 31, 2003
    995
    Outside of Boston
    Dennis
    From my personal archive.... :)
    As I wrote previously,
    >Just heard from my shop... I now need 20 longer lug bolts. A friend will also need 20 bolts too. I'm told that they must be "14mm x 1.5mm thread pitch, conehead, and 2.5 inches long". We just discovered that when using Speedline Challenge wheels on a 355 (or 348 for that matter), the stock bolts aren't long enough for the wheel -- there is only a 1/4" holding the bolt on, instead of the 1/2" for the stock street wheels. Doh. Actual 355 Challenge cars use a stud/nut solution. Would the longer bolt from the late-offset 348 work? I'd probably rather go with a generic bolt solution (need not be OEM Ferrari, nor that pretty, for that matter), as I understand that these Ferrari bolts are $$$$$.
    ___________
    ***THANKS*** to all who responded -- much appreciated! I was about to try getting a set from custom fastener sources, but thanks to Bob Zino, who suggested checking with H&R, and Jamie Troutman and Steve Magnusson, who provided a link to ECS tuning, which is an H&R dealer, I think this problem is solved.
    http://www.ecstuning.com/HR/appguides/app_search.cgi?make=Ferrari&qt=studbolt&model=F355&submit=Search%21&thread=Choose+Thread
    http://www.ecstuning.com/HR/support/how_to_mesure.html
    I ordered a set of new H&R lug bolts (HR141560FER, 60mm, M14x1.5 ) from ECS, for $4.95 apiece (plus shipping), in lieu of the ~$70 or so that Ferrari charges PER BOLT.
    vty,
    --Dennis
  6. BigTex
    79,386
    Houston, Texas
    Bubba
    Good deal!! I think site sponsor Hill engineering does the stock size bolts.
    Don't know about customs. Sounds like you got it handled.
  7. BigHead
    Oct 31, 2003
    995
    Outside of Boston
    Dennis
    If you check the sites I listed, I think you'll find lug bolts in all lengths, including the equivalent of 348 SS/Spider rear bolts....
    Hope this helps!
    vty,
    --Dennis
