I need an engine for a 308 2V carb 1979 | FerrariChat
Discussion in '308/328' started by dan the man, Jan 20, 2004.
  1. dan the man
    dan the man Karting
    Nov 5, 2003
    146
    Alabama
    Daniel
    I need an Engine for a 1979 308. An Intake valve stuck and shattered a Piston.
    Dan
  2. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Question - why don't you rebuild the existing engine, or is the damage too much. If it's just piston and valve overhaul it shouldn't be a problem?
    Regarding a replacement engine, I may be able to locate a secondhand US spec 308GTBi engine for about $1100
  3. jimangle
    jimangle Formula 3
    Nov 5, 2003
    2,499
    Haverford
    James
    How did the valve stick open?
    Jim
  4. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,703
    colorado
    Giovanni Pasquale
    my 78 308 euro dropped a valve about 8 years ago, forcing a rebuild. thats when i fitted the borgo pistons.
  5. rudy
    rudy Formula Junior
    Jan 13, 2004
    363
    Los Angeles California
    Rudy Hassen
    Drop a Chevy crate motor in there. I think they have a 575 HP version now. What a rocket!
  6. dan the man
    dan the man Karting
    Nov 5, 2003
    146
    Alabama
    Daniel
    I believe the Valve "Floated" and made contact with the piston. I was reving it around 8000-8200 rpm's. Blew Chunks of piston up through the weber and all into the intake air Filter housing.
  7. stratos
    stratos Formula Junior
    Dec 9, 2003
    639
    Switzerland
    That's why you should always replace sodium-filled exhaust valves with solid items (steel or nimonic). It was an exhaust valve wasn't it?
  8. dan the man
    dan the man Karting
    Nov 5, 2003
    146
    Alabama
    Daniel
    No. Intake valve.
  9. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,059
    Kansas
    Sean F
    Note to self, that little red line on the tach means "Danger-Danger". ;)
  10. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    Ted Rutlands/Maranello Auto Parts in Tucker, GA has rebuildable engines or just blocks/heads for sale.
    The 'parts section of this website should also be invaluable:
    http://www.ferrariportal.com/
