I need an opinion on hose girth... | FerrariChat
Discussion in 'Other Off Topic Forum' started by away, Apr 3, 2006.
  1. away
    away Formula Junior
    Aug 5, 2004
    635
    Lansdale, PA
    Andrew
    I know innuendo awaits, but I need a judge and jury for a question from this weekend. My friend was washing his car with a probably 1.5 inch width garden hose. (I would say typical hoses are about 1 inch, maybe slightly larger.) He claims the larger diameter flows more water and thus gives him better pressure. I maintain the position that the pressure would be the same if you just used a regular hose because the pump can only flow so much water at once anyway and it all exits through the same sized nozzle opening. I wouldn't even have made an issue of his hose if it weren't for the fact that it looks ridiculous because it's so big and weighs probably twice as much as a typical sized hose.
    Regardless, can a slightly larger diameter hose, for all intents and purposes, give better water pressure?
    I'm willing to admit defeat if I'm wrong but would like to know the answer either way.
  2. Aureus
    Aureus Formula 3
    I’d think it'd be the other way around. You're get a certain mount of water from the faucet. With a smaller hose its the same amount of water via smaller opening = more pressure. Bigger opening, same water, less pressure.
  3. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    25,018
    Dallas, TX
    Jim E
    Smaller hose will give you higher pressure, but not necessarily more water flow.
  4. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    12,313
    At Sea Level
  5. Simon^2
    Oct 17, 2005
    12,313
    At Sea Level
    Sorry, this is wrong. smaller nozzle at the end of the hose will give highe pressure, but you want to minimize loss in the hose....
    see above post
  6. away
    away Formula Junior
    Aug 5, 2004
    635
    Lansdale, PA
    Andrew
    Yea that was a far too technical way to end my day. hmmm, I understand the concept, but in this relatively small hose application can there really be a measurable difference? It would seem I'm wrong, however, I don't like that conclusion.
  7. Simon^2
    Oct 17, 2005
    12,313
    At Sea Level
    You opened the link, before the beer didn't you. I warned you...
  8. WILLIAM H
    WILLIAM H Three Time F1 World Champ
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    try some Viagra to increase the girth & pressure :)
  9. away
    away Formula Junior
    Aug 5, 2004
    635
    Lansdale, PA
    Andrew
    took long enough...
  10. BWS550
    BWS550 Wants to be a mod
    Apr 1, 2002
    8,933
    NEW JERSEY
    BRUCE WELLINGTON
    ASK LAMOUR
    HES KNOWS ABOUT FINDING GURTH AND HE LIKES LONG HOSES.....
  11. BWS550
    Apr 1, 2002
    8,933
    NEW JERSEY
    BRUCE WELLINGTON
    ASK LAMOUR
  12. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    ball licker
  13. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    back to the question ........ i can tell you this - im lucky enough to have a 2 inch diameter fire hose but if the opening on the head of the nozzle is the same as the one on the kiddy size hose, the force of water spewing would be the same. when i use my fire hose the same amount of liquid shoots out but has a much larger build up of pressure. when the pressure builds in my hose its like an eruption of mount st helens. my wife can handle the fire hose, she s got bolt ons.
  14. brassM3
    brassM3 Karting
    Dec 21, 2004
    55
    Calgary Alberta
    The flow rate from both hoses wil be the same (determined by maximum flowrate from the valve). Flow rate = velocity X cross sectional area of the hose. So in the smaller hose, the velocity of the water will be higher. However, your friend is right, generally larger pipes or hoses do have more pressure (its somewhat counterintuitive because of the difference in velocity). I would think a smaller hose would be more effective because the higher velocity of the water will be more effective at knocking the dirt off the car. Somewhat of a half-assed explanation, hope it helps.
  15. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,252
    Southlake, TX
    Rob Lay
    Warning #1 - Watch it.
  16. quartermaster
    quartermaster Formula 3
    Sep 11, 2005
    1,826
    Jeff has it partly correct.
    Velocity, pressure, and volume are 3 different things.
  17. Simon^2
    Oct 17, 2005
    12,313
    At Sea Level
    Sorry. he only has it partially correct. when washing a car you only care about pressure at the hose nozzle. to get must pressure there, must reduce loss in the hose, therefore you want a shorter hose of larger diameter...
    see my post above for link to equations if your so inclined...
  18. quartermaster
    Sep 11, 2005
    1,826
    Fixed!:)
  19. Stephanie
    Stephanie F1 World Champ
    14,973
    The Beach, FL
    Stephanie
    Opinion on girth? :D
  20. ^@#&
    ^@#& F1 World Champ
    12,091
    three day ban!!!!!!
  21. Stephanie
    14,973
    The Beach, FL
    Stephanie
    WHY? :(
  22. ^@#&
    ^@#& F1 World Champ
    12,091
    oh I think you know..
  23. rob lay
    Dec 1, 2000
    64,252
    Southlake, TX
    Rob Lay
  24. Stephanie
    14,973
    The Beach, FL
    Stephanie
    I didn't read the whole thread, I apologize. :(
  25. Gilles27
    Gilles27 F1 World Champ
    Mar 16, 2002
    13,337
    Ex-Urbia
    Jack
    I always assumed that a narrower hose would increase pressure, but then I got one of those coil hoses and it sucks. I guess there's a reason garden hoses are the size they are. Way to go Stephanie.
