I NEED HELP FROM A PILOT | FerrariChat
Discussion in 'Aviation Chat' started by Haizum, Mar 26, 2006.
  1. Haizum
    Haizum Rookie
    Mar 26, 2006
    2
    This might seem a little strange, but I need an actual pilot to answer this question.
    A friend of mine thinks that this image (linked below) is that of a typical business jet but with one engine mounted towards the front. He claims that the engine pictued on the left is actually offset and mounted towards the cockpit. The sad thing is I'm not joking.
    Apparently my friend refuses to accept the fact that the plane pictued isn't centered with the camera, and that the position of the engines is an illusion.
    Please confirm that there is no such airplane in production.
    I should add that this plane was carrying Iran's president, hence the Persian girl in the foreground.
    http://www.mehrnews.com/mehr_media/image/2006/03/186218_orig.jpg
    Thanks,
    Haizum
    Alexandria, Virginia
  2. SWITCHESOFF
    SWITCHESOFF Formula Junior
    Nov 9, 2005
    582
    Haizum, your friend is a victim of photographic "distortion". The airplane has a symetrical aft engine configuration that has been distorted by the effect of long distance in a photo that is focused in the foreground.
    Trace the line of the leading edge of the vertical down to the intersection of a line coming in from the number two ( right hand )engine strut. That point of intersection will be the centerline of the airplane. From that point of intersection trace an imaginary line out to left engine and you will see that there is symetry....approximately. I hope this helps to settle your argument.
    Switches
  3. Skyraider
    Skyraider Formula Junior
    Nov 4, 2005
    620
  4. SWITCHESOFF
    Nov 9, 2005
    582
    Haizum, in my suggestions on figuring out your problem I should have said....." trace a line down the leading edge of the vertical FIN to where it intersects a line traced in from the leading edge of the right hand engine strut...." Thanks from Syraider in identifying the aircraft, I'm not up on some of the new stuff, I guess, even tho my wife and flew in an RJ recently.
    Switches
  5. Haizum
    Haizum Rookie
    Mar 26, 2006
    2
    I appreciate the help. Argument settled.
    Enjoy safe travels.
