I need help please | FerrariChat
I need help please
Discussion in '308/328' started by rmichael71, Aug 8, 2010.
  1. rmichael71
    rmichael71 Rookie
    Aug 8, 2010
    1
    Hello, i own a 1982 Ferrari Mondial 8. I just had a tune up last year. Now i have 2 problems. My car starts up great, i let it warm up for a couple of minutes. Then i take it down the road for about 2-3 miles and then the car starts to backfire and when i accelerate i loose a lot of power. the second probelm is my headlights are not coming up, i changed the fuses but still the same. turning signal works, high beam works but not the headlight and the tail light. Thank you for your help............Michael
  2. zeiglerr
    zeiglerr Karting
    Oct 23, 2009
    69
    Lansdale, PA
    Reid Z.
    These are common Mondial 8 problems and you can find a lot of information searching archived posts. The power loss/backfiring problem sounds like you're dropping one bank of cylinders. It can often be fixed by cleaning all of the connections on the ignition system - especially ground connections. I finally tracked mine down to a loose multi-pin connector on the side of one of the Fuel Injection ECUs on the firewall (remove left rear wheel and fender liner for access) The headlight lift problem is probably a bad relay, or relay connections that need to be cleaned. Good luck!!
