I need some help on my 550 | FerrariChat
Discussion in '456/550/575' started by Bart, May 19, 2004.
  1. Bart
    Bart Formula 3
    Nov 1, 2003
    1,522
    Orange County, Calif
    Bart
    I just got a set of tires for my 550. I went to the dealer for them. My mechanic who has my car right now called me to say the front tires are the wrong size.
    The question is what is the correct size for the front tires on a 550?
    2.55 45 ZR18 or 2.35 45 ZR18
  2. 550
    550 Rookie
    Sep 19, 2003
    46
    what brand of tire do you have?
  3. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    the stock tires are:
    FRONT: 255/40 ZR 18 on 8.5J x 18 wheels
    REAR: 295/35 ZR 18 on 10.5J x 18 wheels
    doody.
  4. maranelloman
    maranelloman Guest
    Bart, Michelin provided OEM tires in the Pilot SX class for the 550 with a 235 front width. All th eother OEM tire suppliers provided 255's. If I were you, make them change to a modern 255 tire.
  5. teachdna
    teachdna Formula Junior
    Sep 1, 2001
    374
    Cincinnati
    Jeffrey Robbins
    Just looked at mine, which are stock wheels and tires installed by the dealer. My fronts are 235/45/ZR18, Michelin Pilot SX. Could be the stock wheels can take 235-255?
  6. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    how weird that the michelins are 235s. that's how it's spec'd in the book too (cf.).
    doody.
  7. teachdna
    Sep 1, 2001
    374
    Cincinnati
    Jeffrey Robbins
    So help me out here: what differences in handling, crispness of turn-in, etc are we going to see between a 235 versus 255?
  8. Bart
    Bart Formula 3
    Nov 1, 2003
    1,522
    Bart
    The plate on the door jam says 2.35 not 2.55.
    Which one is stock?
  9. ferrarifixer
    ferrarifixer F1 Veteran BANNED
    Jul 22, 2003
    8,520
    Melbourne
    Phil Hughes
    Different companies spec their sizes differently. Some use the width to mean the actual tread width, and some use it to define the carcass size.
    The overall circumferance is the important one, and the sizes in the handbook are all the same in real terms.
    If you have 255 45 they are too tall. You need 255 40 or 235 45.
  10. speedball
    speedball Formula Junior
    Mar 29, 2004
    268
    Pasadena Area
    Scot Anderson
    My 2000 550 came with Bridgestone S 02's in the 255/40/18 front size ..... haven't tried other tires on mine .... these work great and look good.
  11. Bart
    Bart Formula 3
    Nov 1, 2003
    1,522
    Bart
    I took my 550 to Ferrari of Orange County today. Within three hours they had change both front tires for smaller ones. No mess, no hassle.
    Thanks!
  12. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    Please note
    The Michelin is a 235/45 ZR 18
    The others are a 255/40 ZR 18
    One is a 45 and the other a 40 aspect ratio. This keeps the overall diameter the same. The manufacturer does not matter, only the size.
    For this car the wider tire with the shorter aspect ratio is better for handling.
    aehaas
  13. shelbee
    shelbee Guest
    The Michelin is 235 only apply to MXX3 but for Pilot Sports are 255/40/18
