I reallyneed some advice on my 550 | FerrariChat
Discussion in '456/550/575' started by Dave pagano, May 25, 2025.
  1. Dave pagano
    Dave pagano Rookie
    Dec 9, 2024
    20
    Dave pagano
    Firstly sorry for the long post.
    I bought my 550 last December and unfortunately it hasnt been a happy experience so far.
    I drove the car from the dealers and on he way home i could tell it wasnt right. This was my first drive of the car as a i wasnt allowed to test drive it. I called the dealer literraly from the car
    I got the car home. I got it home and checked a few things and took the car for another run.
    Temp was all over the place but at that point the car seemed better on the open roads in my area.
    Not long later the Go Slow light came on andthe car lost power.
    Next morning i took the car back to the dealer.
    Car was sent to a Ferrari specialist.
    Upon looking on this forum i mentioned the Cat Ecu and relay board issues these 550s suffer.
    Mechanic decided i needed new fuel pumps and lines.
    After 2 months i got the car back. By the time i drove it the 100km home it weirdly started turning the cylinders off and on almost like switch was being turned on.
    I contacted the mechanic and he told me my relay board had issues.
    The next day i had the top hose fail. Luckily i noticed the leak.
    I decided to replace everything (timing belt, water pump injectors hoses etc).
    Once back on the road the car never ran right.
    Went back to the cylinders turning off under 2500rpm and turning back on at 3000.
    I put 50 litres of fresh fuel in and the car suddenly ran well.
    The next day it ran well till the afternoon when it went back to running terrible.
    Now the Go Slow light is coming on from a cold start.
    I did a fuel pressure check. Left injector bank has 60lbs fuel pressure.
    Right injector bank has only 12lbs.
    Ive ordered a new relay board but which is on its way but im not confident this is the problem.
    Im at a loss now with this car. 6 months in ive barey driven it.
  2. No Quarter
    No Quarter Karting
    Dec 29, 2016
    96
    Denmark
    Michael
    Dave, on my 456, the Slow Down coming on already when cold, that just meant the Motronic computers had a fault stored. In my case P0102, MAF sensor, and as soon as that code was cleared, Slow Down disappeared.
    My logic says it should have been the Check Engine light, but it wasn't
    To make totally sure, measure temperature on cats, if low and even, it's probably like mine was...
  3. Qavion
    Qavion F1 World Champ
    14,150
    Ian Riddell
    If you can get the engine to run and the issue is present, can you compare the voltage drop across the L/R fuel pump fuses? i.e. put one probe on each side of the fuse (without removing the fuse)… assuming you have fuses with cutouts in the back. The values will be in millivolts. From these values and fuse amperage rating, you can use tables to determine actual current.
    The only way a board is going to cause low pressure is if you’re not getting enough current to the pumps, but, it seems more likely he messed up the pump installation, there’s a restriction in the line or you have a fuel pressure regulator issue.
    The Slow Down light could be a thermocouple or Thermocouple ECU issue. Technistrada have cheaper ECUs. Maybe you could also buy some of their “dummy ECUs” for faultfinding. The dummy ECUs replace the thermocouple and Thermocouple ECU (on a temporary basis), to prove it’s not those causing the issue.
    Do you have a scanner? If so, that might tell you what’s going on.
    pchop likes this.
  4. fatbillybob
    Aug 10, 2002
    28,834
    socal
    dave are you near SoCal?
  5. Aerosurfer
    Aerosurfer Formula 3
    1,856
    Indianapolis
    Nick
    He's in Australia
  6. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    673
    Continental Europe
    First off you don't have to be sorry for a long post.
    I can't see anything exotic with the issues you mention.
    Replacing the fuseboard with an upgraded unit will always pay back over the long term, like the "cat ECUs".
    The fuel pressure issue may be down to pieces of rubber from previous fuel pump supports that have crumbled apart and made their way through the fuel lines. I would replace fuel filters and have the injectors cleaned.
    It is frustrating to not be able to enjoy a newly-acquired car, especialy a V12 Ferrari, but ALL of them suffer from OEM illnesses that need to be addressed in the hope to turn them into reliable cars. Hang in there and you wil be rewarded for your efforts.
    belfry, Ferrari55whoa and Aerosurfer like this.
  7. Dave pagano
    Dave pagano Rookie
    Dec 9, 2024
    20
    Dave pagano
    Thanks Sydney Australa
  8. Dave pagano
    Dave pagano Rookie
    Dec 9, 2024
    20
    Dave pagano
    Thanks i went to scan it last week but the car doesnt have an OB2 port so no way to plug the tool i had in.
    Last night i played around with the fuel pressure regulators. I plan to swap them over and see if that changes things.
    I tend to agree that the problem is with a blockage somewhere. It had new pumps , baskets and fuel lines fitted. Maybe ill blow the fuel lines on that side back.
    I have a full tank of fuel in it so draining it out will be fun.
    I had the injectors rebuilt but yes they could be blocked. Would blocked injectors reduce fuel pressure?
  9. Dave pagano
    Dave pagano Rookie
    Dec 9, 2024
    20
    Dave pagano
    Thanks i dont have a scan tool for this car. Doesnt have an ob2 port.
  10. Qavion
    14,150
    Ian Riddell
    You may be able to find an OBD2 adaptor ("Fiat 3 pin") and plug it directly into the plug on each ECU. I think it may be the plug shown in this photo (experts???)
    i.e. disconnect that 3 pin plug behind the kick panel and plug in your scanner to the 2 wire side.
    I haven't personally done it on the 550, but I've done it on my F355. In my case, I had to supply power to the adaptor (from my cigarette lighter). It's a bit of a pain. I've been told that sometimes the Fiat 3 pin adaptor sold on Flea-Bay doesn't have the right size pins. I Googled it in Australia and it took me to an Australian site which had the right fit.
    I think it was this one:
    https://www.ebay.com.au/itm/135387138323?
    The ad says Located in Australia, but you can never believe what they say. I think the one I bought came from Darwin, which I found odd.
  11. Dave pagano
    Dave pagano Rookie
    Dec 9, 2024
    20
    Dave pagano
    Thanks ill buy it
  12. Timmo
    Aug 26, 2017
    673
    Continental Europe
    #12 Timmo, May 26, 2025
    Yes, that's the correct 3 pin adapter. I use an Autel AL519 OBD2 reader which has always worked well for me.
    An easy way to tell if the system has stored a fault code is if, after turning the engine off, the amber "CHECK ENGINE" light at the top right of the gauge cluster turns on for a few seconds then turns off.
    Note : From 2001 onwards the amber "CHECK ENGINE" light was replaced with the now current CEL symbol as found on all OBD2 cars :
    Qavion likes this.
  13. Qavion
    14,150
    Ian Riddell
    I've been told that on some Ferraris that that 2~3 pin OBD plug is used to transfer some data from the LH ECU to the RH ECU, but I haven't confirmed this. If it is the case, then you may not see all of the data on the scanner because you are breaking into the line to fit your scanner. Also, for all engine ECU scans, you will need to disable the immobiliser with the fob.
    Actually, I'm wondering if disconnecting that plug will prevent the car from running? This might be an issue because some folks have said that the engine has to be running to get all data on the 550.
  14. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,470
    San Carlos, CA
    Mitchell Le
    So, are you going to work on this car yourself? Or are you collecting information to relay to the specialist who got your car to this condition?
    fatbillybob and Aerosurfer like this.
  15. fatbillybob
    Aug 10, 2002
    28,834
    socal
    It's really valuable to do a nose to tail sorting. With a used car you have no idea what you have until you get in there. Records mean nothing. There is a great 550 sorting thread on this board. It gives you an idea of how to make a great running car. What it did was give that owner a new baseline going forward and complete understanding of how the 550 works making future diagnosis and repair easier and faster. You can have very flawless running if you do everything right the first time.
    308 GTB likes this.
  16. Dave pagano
    Dave pagano Rookie
    Dec 9, 2024
    20
    Dave pagano
    I do generally all my own work. I sent it back to the dealer because i figured after spending 220 grand they wear the problem. As usual it seems the repairer did a patch up job.
    I changed all the belts ect myself.
  17. Dave pagano
    Dave pagano Rookie
    Dec 9, 2024
    20
    Dave pagano
    Yes i agree and was fully prepared to go through the whole car as i knew it hadnt been touched in years. Having said that the dealer really should have recommissioned it properly. They sold it to me based on it being an immaculate ready to use car and i paid accordingly.
    I run a small restoration business
  18. fatbillybob
    Aug 10, 2002
    28,834
    socal
    I’m sorry you are in the business and got taken. The number of used exotic cars sold in top condition are extremely small. Every one I have purchased over 40 years started with a nose to tail sorting before I enjoyed the first mile.
    Ferrari55whoa likes this.
  19. 575
    575 F1 Rookie
    Nov 20, 2009
    4,647
    who was the dealer /repairer?
  20. yelcab
    Nov 29, 2001
    13,470
    San Carlos, CA
    Mitchell Le
    Well then Dave
    1. The first thing you need to do is to make it possible to read the and clear any engine codes. Get that 3 pin dongle and an appropriate OBD2 scanner. Read the codes, write them down, and then clear them. The codes will tell you which bank is shut down, probably bank 2.
    2. You have to figure out why one bank is shut off. I'll give some ideas below but the list is pretty big.
    • Green thermal control unit is bad on one bank. This can be bench tested.
    • Excessive fuel flow in one of the injectors. They are old enough to need cleaning now, especially if they don't get driven much.
    • Bad injector wiring or engine harness. This happens all the time on Ferrari wiring harness of this era.
    • Exhaust leak near the O2 sensor on bank 2. Read the live data or hook up an oscilloscope to the O2 sensors. There are real clues here.
    • Bad wiring / bad relay controlling bank 2. At least you live on the same continent as Qavion, our local electronic guru.
    • Also bad cam timing can do this. Did you check compression and leak down when you did your timing belt? Did you degree the cams? V12 is very susceptible to cam timing issues. Compression test can give a clue.
    Good luck.
  21. fatbillybob
    Aug 10, 2002
    28,834
    socal
    I thought all the 550's were obd2 capable but ferrari left out the connector on some cars to other countries. Aren't the wires in the approx driver's knee bolster area and wasn't there a TSB to show you how to connect the wires to have a functioning obd port? It would be useful to fix this 1st. Having access to the port is so much easier that going to the foot well all the time.
