I Screwed Up---And I am Mad!!!! | FerrariChat
Discussion in 'Other Racing' started by FastLapp, Jun 28, 2005.
  1. FastLapp
    FastLapp F1 Rookie
    Mar 18, 2004
    2,962
    Rhode Island
    James
    I was practicing at a local high school in my kart. For some reason on this really sharp turn I kept spining out, its like I had no control. I had practiced there before, and I did fine.Today was different. Well on about my 10th lap I skidded around, went into the grass and smacked into a concrete sewer thing at about 30 mph. Hurt my knee pretty bad plus my elbow and hip bone. I have ice on it right now. I cracked the body kit, but worst of all I bent and cracked a $1000 chassis. I will have to bend it back to the exact right degrees and find someone to weld it, If it is not fixable I will have to pay half of my fortune to get a new frame, plus mount the engine seat, ect. onto the new one.
    I think one of the major reasons I was doin badly is because the tires. They were worn ALOT. I'm not trying to blame other things, it was my fault - I came into the curve to fast. But its weird because I was not doing antyhing different than last time. I just hope my knee will get better, summer is here and I dont want to be stuck indoors. If it still hurts as bad as it does now tomorrow, I will go to the hospital. and get x-rayed. Live and learn I guess.
  2. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    Go to the doctor and get everything checked out. The cart can be replaced, you can not. Don't wait, get checked out.
    As to the cart, this rule holds true at all levels of motorsport, if you can't afford to write the whole car off, you can't afford to race.
  3. SRT Mike
    SRT Mike Two Time F1 World Champ
    Oct 31, 2003
    23,343
    Taxachusetts
    Raymond Luxury Yacht
    I can't imagine that the frame can't be fixed instead of replaced. Is it aluminum? You will probably find two groups of repair guys. Some will say "Frame? NO way, gotta be replaced". Others will slop a few welds on and call it fine. I haven't seen it, but I would expect with careful welding it would be fine. The welds are generally stronger than the base metal so it shouldnt be a problem. Worst case you could add in some braces to make it stronger.
  4. s_eric09
    s_eric09 Formula Junior
    Feb 7, 2004
    570
    SoCal
    George
    "if you can't afford to write the whole car off, you can't afford to race"
    same though
    the tires were worn, in a case like that a team would change them rite away saving some bucks on tires can cost much more.
    and depending on the damage, throwing some "welds" into the car can end up costing you much more.
  5. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    It sounds like you were on Michelins.. :)
  6. FastLapp
    FastLapp F1 Rookie
    Mar 18, 2004
    2,962
    Rhode Island
    James
    lol, actually I was on Bridgestones!!!
    I can get the kart replaced. I have $2200 that I have saved, plus my parents have a solid income. The crack doesnt go all the way through-we shoudl be able to get it fixed and everything should be fine. I'm in a better mood now, a nice hot bath brought down the swelling and pain on my knee/leg. This si my exact chassis, a Coyote widetrack LE, The black part that curves into where the tire part is is cracked as you can see with the arrow. http://img100.echo.cx/img100/8658/flierwidetrackle0oh.jpg
  7. Admiral Thrawn
    Admiral Thrawn F1 Rookie
    Jul 2, 2003
    3,932
    I'm surprised noone has asked this, but why were you practicing at a high school? Shouldn't you be driving at a track?
    One possible reason for you spinning out may be that there was dust or some other loose material where you lost control. The weather could also play a part, having altered the surface. Either way you didn't adapt your driving to the conditions.
    About repairing the chassis... Because karts have no suspension, the flexing of the chassis is crucial to the handling of the kart. In order to create and control this flexing, the different areas of the chassis have specific stiffnesses built into them. That is why, even if a kart chassis can be bent and welded back into shape, it may never handle the same again.
    Once you lose this predictability of handling it becomes very difficult or even impossible to setup the kart correctly, or be able to accurate diagnose and dial out handling deficiencies.
    Out of curiosity, what type of engine do you use, and what kind of circuits?
  8. adamr
    adamr Formula Junior
    Aug 16, 2002
    720
    Chicago
    Sorry to hear about your accident. Glad it wasn't more serious.
    Those are some of the reasons I stopped going to the track (or go a lot less):
    1) Tired of being hurt during the summer. Strangely though, I never got hurt as badly as I did going bicycle riding or roller blading.
    2) Tired of spending time fixing the bike.
  9. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    I have to agree with James on this one. You should have been out practicing at a controlled course. (Race Track). Not only did you place yourself at risk but what would have happened if a kid was riding his bike right into your path.
    At least at a track they have controls to prevent situuations like people wandering onto the track plus crash barriers to arrest you in an off track shunt.
    Best of luck with your cart and you knee.
  10. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Were they Michelin cart tires?
  11. dretceterini
    dretceterini F1 Veteran
    Apr 28, 2004
    7,289
    Etceterini Land
    Dr.Stuart Schaller
    That should be easy for any competent welder who is in the racecar business to repair
  12. WJC
    WJC Formula Junior
    Apr 28, 2004
    855
    Austin, TX
    Joe C.
    Knees aren't anything to mess with, get them checked out. I was in an auto accident, head on going about 65, (the other guys fault, and he didn't have insurance) and tore my PCL. My knee hurt but I didn't think anything of it but I ended up having surgery and crutches for 3 months.
    As far as practice in a parking lot, when we practice at Georgia Tech with our SAE Formula car, we always make sure there is a good amount of run off area and cone it off. I know, it is hard finding a large enough space where people will let you practice. It is hard for us, we use a 600 cc engine on a kart that maybe weighs 350 lbs total.
    Anyway man, I hope you get better and good luck on getting back to running. Go to your nearest college, see if they have a Formula SAE team, they might be able to help with the chassis.
    Joe C.
  13. CRG125
    CRG125 F1 Rookie
    Feb 7, 2005
    2,638
    Los Angeles, Ca
    Vivek
    I agree with PSK, why were you driving in the parking lot? Next time practice at a kart track. As for the chassis, yes you can weld it back together, but it does affect the chassis handling. It won't be the same. But for you, since you are just beginning, it really doesn't matter. Just get it fixed instead of buying a new one. As for you spinning out, what type of chassis do you have? Does your chassis have rear brakes only or both? If it has both, it could be that your brake biasis was set to the rear. When you set it more to the rear, under braking the back end of the kart will kick out. If you are on it to long, than you will just spin it.
  14. senna21
    senna21 F1 Rookie
    Jul 2, 2004
    3,334
    Los Angeles, CA
    Charles W
    I wound up bending a 125cc shifter (Tony Kart) frame at the Dallas GP back in 93. Medium size story, big mess, other drivers involved, $1,000 bucks out of my pocket and I didn't get to race. :( As the Admiral has said the frame is crucial to a Kart performing properly.
    My guess is there's a lot more damage to it than just the crack. Frames have a lifespan anyway. As they flex over and over their torsional rigidity changes. With that so does your handling.
    I know how you feel.
  15. racerx3317
    racerx3317 F1 Veteran
    Oct 17, 2004
    5,701
    New York, NY
    Luis
    If you go somewhere that specializes in kart chassis and welding and don't nickel and dime it you should be fine. See if you can get someone to string the kart at every corner to make sure it's totally straight. I'm glad you didn't hurt your self. Keep it on the track next time if you can. No rasied sewers covers there...:)
