I think I've changed my mind re AC (York/Sanden) | FerrariChat
Discussion in '308/328' started by mike996, Sep 12, 2013.
  1. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    I had "decided" to replace my York compressor with leaking seal with a Sanden unit. After doing more research and consideration, I have think I may have re-decided to replace the York with a New York.
    I came to the conclusion that I didn't want to bother with all the angst/expense/work that accompanies changing the unit. The York will bolt straight in with no other changes required. Both the York and Sanden have similar capacity and both appear to be "fake" York/Sandens - made in China - so I don't see how there can be any quality/performance advantage for either one as far as cabin cooling is concerned.
    I agree that the Sanden should be quieter and take less power to operate but I don't see that as a real issue at all when cruising down the road. If I want all 260 of those Ferrari-supplied horses to appear at the flywheel, I'll turn off the ac!
    One of the most important considerations that led me to this decision was the fact that I have never seen any feedback that indicates that there is any cooling difference in the cabin between the two compressors. Yes, there are threads where someone took a non-working old system, replaced it with a Sanden and stated that it works great. But I have never seen a thread where someone took a working York/properly charged system and changed to a Sanden which then provided better cooling. With that in mind, I don't really see any advantage to spending the additional money necessary to change from Y to S.
    But I'm still open to input, at least for a couple more days before ordering the new compressor... ;)
  2. cockrill
    cockrill Formula 3
    Jan 23, 2008
    1,088
    Columbia, MO
    Jeremy Cockrill
    I'm also replacing my York compressor with another York. You can't beat the price (less than $150), it'll bolt right in and, even if it doesn't cool as well as the Sanden, I'll never drive the car when it's 100+ degrees out.
    Are you going to do the swap yourself?
  3. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    To each their own. Want to purchase my old York? Condition unknown.
    Sent from my iPhone using Tapatalk - now Free
  4. Dr Tommy Cosgrove
    36,437
    Birmingham, AL
    Tommy
    The chemical will make a bigger difference than the choice of compressor. In a 308, a York with R12 will ALWAYS 100% OF THE TIME OUTPERFORM A SANDEN WITH 134.
    This is an indisputable fact and anyone on earth disagreeing with me is 100% wrong 100% of the time.
    Case closed.
  5. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I did the conversion when my OEM Italian compressor went. It is a much simpler conversion and takes the belt tension-er assembly out of the equation. Also because it is smaller it is easier to move around when doing a belt change. I can't compare how it cools vs. the R12 but my vet temps are just under 50* in 95* temps. As we all can guess but if you increase the size of the condenser and the evaporator it would most likely be more efficient.
  6. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    I always thought the reason they originally used the York compressors on USA cars and Sanden on Euro was the York performed better. If thats not the reason, what is?
  7. Dr Tommy Cosgrove
    36,437
    Birmingham, AL
    Tommy
    #7 Dr Tommy Cosgrove, Sep 12, 2013
    If you had 12 it would blow even colder.
    If you do as you suggest above, you will see an improvement with 134's performance - but this is simply never done except in a few very rare cases. 99.9999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999% of the time a lying ass or completely cluless mechanic will just screw two cute little red and blue caps on your existing schrader valves, charge with 134, take your money and watch you drive away after lying to you that everything will be just fine and your a/c will work just as well as before when it was charged with 12.
    ^^^ This WILL NOT work like people want to believe it will.
    DO NOT DO IT unless you enjoy getting ****ed in the ass bone dry by a shop.
    And once again, my usual statement: I am 100% right and ANYONE INCLUDING EVERY SINGLE MECHANIC READING THIS ON PLANET EARTH IS 100% WRONG IF THEY DISAGREE!!!!
    Clear enough?
  8. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    As far as refrigerant - 12 vs 134, I use neither. Duracool worked quite well in my system until the compressor seal started leaking. I totally agree that 134 cannot possibly work as well as 12 in the original system, which was designed for 12. But I got vent temps down into the high 30's with Duracool on mid 80s' days with low humidity so I was quite pleased with Duracool (propane-based) and it's cheaper than 134. I have read here that the propane based refrigerants don't actually cool "properly," in that the way they actually work is not the "correct" way as rel refrigerants such as 12/134 but if it cools the car well, I don't really care how it accomplishes that. It cools far better than 134 did in my 328. I have never had 12 in the system, the PO converted it back in the 90's, so I can't directly compare it to 12. I had thought about installing R12 but being reasonably happy with the duracool, I never did it.
    Yes, I will do the swap myself, whether it's to the Sanden or a new York.
  9. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Twenty million over-the- road diesel rigs that are factory equipped with Yorks just can't be wrong. Jq.
  10. Steve King
    Feb 15, 2001
    4,367
    NY
    LOL , now tell us how you really feel. I find it interesting if anyone believes that 134 is equal to R12 but then again there are a lot of naive people in the world.
  11. Dr Tommy Cosgrove
    36,437
    Birmingham, AL
    Tommy
    I walked the walk two times on two different cars with 12 to 134 and I was so ******* mad that I will never EVER forget it.
    Big, HUGE bills to go back to 12 and get it right again. The shop owners should be jailed and I am not kidding. Stole from me pure and simple.
    I am here to warn others WITH THE TRUTH and I will continue to do so
  12. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Mike,
    When I redid the AC system in my 328, my mechanic (second generation, Ferrari trained) recommended going back with the York unit, as did the mechanics at Classic Coach, a major Ferrari shop here in NJ. Their rational: The York unit is less expensive, needs no adapters, bolts right up, and works just fine. I went with the York and the system works really well.
    As Tommy says (when he isn't ranting), the big issue is 134 vs. 12. Around here, the 12 is really, really expensive vs. the cost of 134. I went with 134, and the cooling is adequate. In fact, it gets cold enough to freeze the coil in the passenger compartment. I'm sure that 12 will do an even better job cooling, but if it is getting cold enough to freeze the coils up, I can't see how making it even colder would make much of a difference.
    That's just my $.02. YMMV, but that's my experience with the 328.
    Steve
  13. staatsof
    95,972
    Fuggetaboutitland
    Bob
    Then get a Sanden capable of running either.
    Of course we don't know if that will be compatible with R134's scheduled replacement.
  14. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,230
    CT
    John Kreskovsky
    That has always been my experience with my 308 gtb, since new. Driving in hot weather everything would be fine for a while. The AC would cycle on and off but after a while I would notice the AC not cycling and the cabin getting stuffy. Evaporator would freeze up. 12 or 134. Plus, driving on a sunny day it's never the cabin temp that is the problem. I can get it down to 72 even on the hottest days( with no freeze up). But there is so much direct radiation hitting my upper legs, arms and chest through the windshield I just feel hot. It's like sitting under a sun lamp in an air conditioned house. Air temp and convective cooling can only remove so much of the radiant heat from the body.
  15. Dr Tommy Cosgrove
    36,437
    Birmingham, AL
    Tommy
    I have always said, if you do it and like it, great. That isn't the problem. The real issues are KEEPING the 134 in the system (it will seep out everywhere eventually on most of these cars, although it is cheap to refill) and any expectation that is is as good or better than before with 12.
    I am just here to make people aware of problems BEFORE they do it. Once 134 is in, it is IN and you are going to have to open your wallet BIG time to go back the better way. You think R12 is expensive? Try replacing almost everything, then buying some.
  16. Dr Kananga
    Dr Kananga Formula 3
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    Where do you get a replacement for $150?
    What about a Sanden with 12?
  17. Steve King
    Feb 15, 2001
    4,367
    NY
    I would assume the cost to return would be minimal if done yourself but would be expensive to have a shop do it. Other then the cost of R12 the only thing I would change is receiver/drier and maybe compressor oil which now is comparable to both. Just do a flush and pump it down for 24 hrs and leak test and fill it back up. Parts are cheap as is my time being retired. The cost would be getting the R12 especially in NY.
  18. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    I want to know how the OP has 260hp
  19. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    "I want to know how the OP has 260hp"
    I just blindly assume none of the horses have escaped from when they were stuffed into that little 195 cu in space back in '89. :)
    I've become convinced to go with the new York. Only thing left to figure out is: IS there any difference between the York clone from action air at $260+ and the $150+ York clone offered by several other suppliers.
    Oh...and I also need to figure out the proper charge for 134 so that it cools better than that obsolete R12 stuff.
    OK, the last sentence above is a JOKE! Dr Tom, it is NOT necessary to respond! I KNOW that 134 will not work as well as R12 in these systems. I repeat, it was a joke.
  20. Dr Kananga
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    This made me very nervous.
    I almost closed my account so I didn't have to see the fallout.
    Sent from my iPhone
    (which means I am probably sitting by the car, confused.)
  21. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,121
    Atlanta
    Tom Spiro
    I have the stock york system, and am running freeze 12 and so far - 3 years running the AC works well. even in very hot humid traffic days here in atl...
    now when I mean well... in stop and go traffic as long asyou are moving you will have some cool air, but the sun will heat up your left side... on the open road its actually very plesant... in a cloudy day - its cold...
    if you have to sit for more than 10 min stationary in bright sun... forget it. the system cant ovecome the heat.
    I do have to top up the supply of Freeze 12 every spring... and they are not making it any more...so not sure what will be next...
  22. Dr Tommy Cosgrove
    36,437
    Birmingham, AL
    Tommy
    I was about to say.... :)
