i think my left side tank has failed (f40) | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by ross, Sep 8, 2013.
  1. ross
    ross Three Time F1 World Champ Owner Silver Subscribed
    Mar 25, 2002
    38,014
    houston/geneva
    Ross
    i opened the garage door yesterday, and there was a puddle around the left rear tire. i touched it and smelled it but frankly it did not feel like gas, but more like greasy water. so i dont really know what the deal is. i looked all around etc but could not determine what it was.
    so given that i cannot take it anywhere before monday, does anybody have any advice on this issue??
  2. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,206
    Beverly Hills, CA
    Jay
    If you have a gas can, you could pour some fuel into the tank and then see if it leaks out
  3. Traveller
    Traveller F1 Veteran
    Apr 10, 2009
    6,323
    Tim
    Rear left looking from the rear or the front?
  4. Napolis
    Napolis Three Time F1 World Champ Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Personally I wouldn't do that.
    I'd dump kitty litter on the spill, ventilate the room, shut off any source of ignition and get it towed out of your house asap.
  5. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Whatever you do, don't start the car until the source of the leak is diagnosed.
  6. GreenLantern
    GreenLantern Formula Junior
    Apr 23, 2010
    459
    CA, NV, TX
    ^^ This. +1
  7. Hogatoshagooarnie
    Hogatoshagooarnie Rookie
    Oct 16, 2009
    23
    Uk
  8. Maxige
    Maxige Karting
    Jun 5, 2005
    190
    London/Milan
    Max
    By your description and the location of the small leak, sounds like coolant, not gas...especially because very unlikely you'll ever find gas under the car unless it just happened as it will evaporate very very quickly.
  9. ross
    Mar 25, 2002
    38,014
    houston/geneva
    Ross
    correct you are! i was just getting on here to tell you all that it was in fact coolant. tanks are fine.
    the problem is that garage has several older ferraris and other cars, and its quite tight, so the smell of gasoline is pervasive at all times regardless of whether there is a real issue or not.
    anyway, problem solved. all ok. thankfully !
  10. Traveller
    Apr 10, 2009
    6,323
    Tim
    Exactly, which is why I ask which side of the car.
