I thought my clutch cable snapped but it is in tact afterall. What happened? | FerrariChat
Discussion in '308/328' started by ColoradoTiger, Jul 4, 2014.
  1. ColoradoTiger
    ColoradoTiger Formula Junior
    Jun 11, 2010
    607
    Colorado
    Mark
    Anyone have any ideas on why my petal would lose all feel if it didn't snap?
  2. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    Did a linkage break? Have you true pulling the cable from both ends? Also look if it came off the guide pullies
  3. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,977
    The Cold North
    Tom
    Pull off the left rear wheel and inner fenderwell and have a look while sombody works the clutch pedal and see what's happening.
  4. ColoradoTiger
    Jun 11, 2010
    607
    Colorado
    Mark
    I have the fender well off. The pulley near the rear of the car is fine. Are there other pulleys?
  5. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    Check the cable coming up under the pedals. It's a simple design anything else I can think of would be in bell housing or clutch pack
  6. ColoradoTiger
    Jun 11, 2010
    607
    Colorado
    Mark
    Thanks! I'll check in the morning. I've had enough for today.
  7. ColoradoTiger
    Jun 11, 2010
    607
    Colorado
    Mark
    Well, the cable/pulleys/linkages seem to be in tact. The petal does sit several inches lower than before however. Am I going to have to take the clutch apart?
  8. 1Evil4re
    1Evil4re Formula Junior
    Jun 24, 2012
    313
    Nashville Area
    David
    #8 1Evil4re, Jul 5, 2014
    I had the same problem. I was downshifting (not even aggressively) and the clutch pedal went to the floor and stayed there. I limped home in 1st gear. I really thought it was the clutch cable but it was the clutch and pressure plate.
  9. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #9 finnerty, Jul 5, 2014
    With someone inside the car operating the pedal, and someone at the rear observing the linkage arm at the bell housing, it is a no-brainer to determine whether or not the external mechanism is working correctly. If it is, then something has broken inside the bell housing --- either the pressure plate or the release fork / arm. If so, then yes, you will be opening it up to diagnose and repair.
    Only other possibility (though very unlikely) is that the pedal arm / pivot shaft / mounting has broken ---- this is easily diagnosed by visual inspection and determining if the pedal has any side-to-side (out of the plane of normal travel) movement by grabbing it and giving it a good "wiggle".
    PS --- release forks have been known to fail occasionally ;)
  10. BigTex
    79,386
    Houston, Texas
    Bubba
    There' helper spring on the pedal arm, under the dash??
    Or is that the brake pedal I am remembering...when I broke that it made quite the snap..
  11. ClydeM
    ClydeM F1 World Champ
    11,949
    Wayne, NJ
    Clyde E. McMurdy
    Yep, two as the cable exits the underskirt (cable hidden between it & the body) and goes to the back of the car.
    Did one of the pulleys break? They are old plastic and brittle at this point.
  12. ColoradoTiger
    Jun 11, 2010
    607
    Colorado
    Mark
    I got the car started and put it in gear while up on jack stands. I tightened the turnbuckle all the way to shorten the clutch cable. I was able to get the car in gear but can't get the wheels to turn. Must be the mechanism inside the housing. Bummer.
  13. finnerty
    May 18, 2004
    10,406
    #13 finnerty, Jul 7, 2014
    Yep, sounds as though something inside is preventing the pressure plate from engaging against the disc ---- which is kinda strange because the default (with no actuation applied) of course is for the plate to be clamped down autonomously by its own spring force.
    So either your pressure plate has broken or the throw-out bearing / release fork is jammed in the "release" (pushing against the plate spring) position.
    I'm sure it will be very obvious and easy to repair once you open it up --- nothing too complex in there. Good news is doing a clutch on these cars is really not too bad ---- except for the special tool needed for the ring nut, and several places loan them out now......if you don't want to eat the expense of buying one.
  14. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    Must be that time of year! Mine snapped last night and I will have to take it apart to find out what happened. OH well, Lost
  15. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    Mark.
    Did you figure out what happened to your clutch??
    john
  16. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    When my cable failed it didn't break in the sense that it was separated. A few of the strands of steel wire broke and that effectively lengthens the cable to the point where you can't get the clutch released.
  17. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    I had the same experience at Lime Rock. I thought the cable snapped while shifting, but it turned out the clutch disc disintegrated.....
  18. ColoradoTiger
    Jun 11, 2010
    607
    Colorado
    Mark
    Not quite sure. I'm pretty sure that it is inside the bell housing and I don't want to get in to that. I'm shipping my car back to Carobu on Monday for some top secret updates (stay tuned) :) and I'll have them fix the clutch issue while it is there.
