Ian Barkaway's 308 engine stand | FerrariChat
Discussion in '308/328' started by Du_Man, Nov 15, 2022.
  1. Du_Man
    Du_Man Formula Junior
    320
    Dallas, Texas
    Derek
    Barkaway’s YouTube video shows a 308-engine stand that I would like to fabricate something similar before I pluck out my engine - the engine may be out for months and wheeled around. In the deep pool of the forum, has someone measured the distances between the 4 motor mounts? Or is there a schematic side-view drawing of the engine that will give me the dimensions?
    Maybe Ian Barkaway will wander in here and throw some dims of his stand my way! His videos are great and I really look forward to them. Image Unavailable, Please Login Image Unavailable, Please Login
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,640
    Toronto / SoCal
    Rob C.
    Unfortunately my car is nowhere close or I would measure it up for you. If nobody chimes in just slide under your car and measure the center to center of the 4 mounts. It should be fairly easy to do on the ground.
  3. classicalfas
    classicalfas Formula Junior
    318
    Gardiner, NY
    Peter D
    When I did my motor, I had 2 carts and an engine stand. The engine stand is specific for Alfa motors and spins on its motor mount locations. It also worked perfectly for the 308 installing the bottom end as it spins. Once the heads were in, I dropped it on the trans sitting on the higher cart. I had these different height cars, it just made it easier to work on. I then put it on the short cart and used that for the test stand to fire the motor before we dropped it in the car. The motor sat on its oil pans and wasn't even strapped down when started. Not difficult to make, I can take dimensions if you need and photos.
  4. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,640
    Toronto / SoCal
    Rob C.
  5. Du_Man
    320
    Dallas, Texas
    Derek
    You are correct just get under the car....I need to make a homemade autobody tram gauge to pick the points!:)
  6. Du_Man
    320
    Dallas, Texas
    Derek
    I am digging that Alfa engine stand! I really like the 360 access
