News
Ideas on 348 clutch please?
Discussion in 'United Kingdom' started by burriana, Nov 15, 2004.
  1. burriana
    burriana Formula 3
    Jul 8, 2004
    1,675
    North Yorkshire UK
    AL
    Just a rough guide before I start getting prices in from my two local specialists please, if anyone has had one replaced recently.
    It has just started to slip when making serious progress into 4th and 5th.
    Not unexpected as it was the one thing that the pre-delivery inspection flagged up as a possible in a few thousand miles... and seeing as I've done 4k in the last 8 weeks, three of those caning it around Europe and the Alps.... can't complain too much!
    Ta :D
  3. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,836
    East Yorkshire
    Justin Kenyon
    Clutch not lasted a long time.
    My 348 spyder has done nearly 35,000 miles and its still on the same original Clutch. No wear issues at all.
    I have been told clutches do not last that long.
    The 348 Spyder is a single plate clutch they cost around £450 to £500 inc VAT.
    Fitting £50.00. Very easy to fit. Not labour intensive (2 hour job).
    http://www.eurospares.co.uk/
  4. burriana
    burriana Formula 3
    Jul 8, 2004
    1,675
    North Yorkshire UK
    AL
    I didn't think 11 years and 25k was bad, especially after the hammer it took a few weeks ago!
    Just waiting for a price from Strasse and R7D Automotive now.
  5. ferrarimadbloke
    ferrarimadbloke Karting
    Aug 19, 2004
    188
    Porthcawl S.Wales
    Leyton Thomas
    Al,
    Make sure you get the flywheel "Regreased" whilst the clutch is out. This is SPECIAL grease is made by a company called "KLUBER" and is specific to dual mass flywheels.
    It's not essential that this is done, but after the recent use it's had, I would definately insist on getting it done. (It makes the clutch take up a lot smoother) If your "specialists" are scratching their heads where to get it from (Ferrari sell it tubs around £100 a time) then I've got some (unused) jars you can have.
    Leyton.
  6. burriana
    burriana Formula 3
    Jul 8, 2004
    1,675
    North Yorkshire UK
    AL
    Thanks Leyton.
    Do you happen to know if it's a single or twin plate clutch? Apparently there's £400 difference between the two!
    al.
  8. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,836
    East Yorkshire
    Justin Kenyon
    Al,
    The 348 spider are single plate. Mush better then the double plates which are on TB, TS models.
  9. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,030
    12cylinder town
    steve
    All just take it to trev at strasse nobody better ask simon355lambo
  10. burriana
    burriana Formula 3
    Jul 8, 2004
    1,675
    North Yorkshire UK
    AL
    Thanks Justin - that makes it £470 instead of £815!
    Steve - I still need to get comparison prices in. As it happens, Strasse are the same prices parts wise but more competitive on labour time, so that's where it will be going.
    If they can get any of this Kluber gunge wotnot that is :D
  11. jkuk
    jkuk Formula Junior
    Nov 3, 2003
    259
    Wirral, UK
    John K
    AL,
    I found FerrariUK cheapest for parts. - cheaper that eurospares but this was the dual plate version
    Did my complete 348 clutch & flywheel grease etc this summer.
    Suggest you follow the current thread in the Vintage section - a guy there is just about to do his.
    A complete rebuild of the flywheel will get expensive if you go to a dealer, but if there is no oil/fluid leaks past the triple shaft seals/throw bearing I would not bother.
    Also ensure they change the triple drive shaft seals. They are cheap and easy to replace once the clutch pack is out.
    If you need more detail let me know.;
    Cheers
  13. burriana
    burriana Formula 3
    Jul 8, 2004
    1,675
    North Yorkshire UK
    AL
    Have just spoken to Dave at Strasse. He knows about greasing the fly wheel and is just working out the additional cost. The triple drive shaft seals are done automatically.
    Cheers for all the guidance so far.
    al
