ideas on hanging garage emblems | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by daviddallas, Aug 11, 2018.
  1. daviddallas
    daviddallas Formula Junior
    Jun 10, 2013
    303
    Lucas, Tx
    David Hill
  2. daviddallas
    Jun 10, 2013
    303
    Lucas, Tx
    David Hill
  3. clonmeliw
    clonmeliw Karting
    Aug 27, 2016
    192
    Tulsa, OK
    Jeff Fischer
    Bought the cavallino and the script in a slightly larger size about two years ago. In the instructions they suggest possibly mounting them on spacers to give a greater sense of depth. I used slightly thickish washers and normal double sided tape from Home Depot and, with the spacers, they are only fixed to the wall at about 6" intervals. They have a foam core with a brushed aluminum face so they're pretty light and I've had no problems whatsoever. It's a little time consuming as they come in quite a few pieces and you'll want to get the spacing right but they look terrific. The only interesting note is that the dot over the "i" is actually elliptical whereas the "real" script appears to be rectangular. Probably a copyright thing but you'd never notice unless you went looking.
  4. daviddallas
    Jun 10, 2013
    303
    Lucas, Tx
    David Hill
    thanks, great info
  5. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,734
    Just East of Weird
    Bob
    I got the same thing off of eBay. After several attempts for the letters to stick, I think I got it. I got small wooden dowels from Lowes and used "Liquid Nails" glue to attach them to a plank of wood. I tried several glues and none lasted more than a week. Liquid nails has held. I didn't want to use double sided tape as once on, you can't move it.
    I used the "F: and "dot" to layout the other letter spacing with painters tape along the edges so the spacing would be OK. So far so good.
    Why I took pics of this process I'll never know...
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  6. daviddallas
    Jun 10, 2013
    303
    Lucas, Tx
    David Hill
    nice, thanks for the input
  7. daviddallas
    Jun 10, 2013
    303
    Lucas, Tx
    David Hill
  8. clonmeliw
    clonmeliw Karting
    Aug 27, 2016
    192
    Tulsa, OK
    Jeff Fischer
    That's a REALLY nice garage! The black lowers with the white separation look great. NewAge Pro cabinets?
  9. daviddallas
    Jun 10, 2013
    303
    Lucas, Tx
    David Hill
    thanks and yes on the new age cabinets.
    of course the Ferrari under cover is red and black..
  10. sandreb
    sandreb Karting
    Feb 7, 2018
    52
    Sander B.
    I used loc-tite power grab and it is holding up well.
  11. daviddallas
    Jun 10, 2013
    303
    Lucas, Tx
    David Hill
    well after a week ig Prancher had fallen down, so stickups i posting didnt work
    trying another...
  12. malex
    malex Formula 3 Silver Subscribed
    Dec 5, 2007
    1,247
    FL
    Perhaps some neodmyium industrial magnets? Super cheap on Amazon. Since sign is aluminum, use high strength epoxy to attach some fender washers to back of the sign (key the surface where epoxy will attach with some 80 grit paper, clean with acetone). Screw some thin, disc-shaped magnets to the wall (you can buy them already pre-drilled and countersunk). Attach sign once epoxy has full cured (give it a few days to cure properly).
    Something like this should work. Depending on the sign's weight, you can use a few smaller magnets, or a couple of larger magnets.
    https://www.amazon.com/Personalized-Multi-Use-Whiteboard-Magnetic-Refrigerators/dp/B076RV524B/ref=pd_sim_328_1?_encoding=UTF8&pd_rd_i=B076RV524B&pd_rd_r=38349207-e5c4-11e8-8349-9126162516c7&pd_rd_w=qJhrV&pd_rd_wg=b74JG&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=18bb0b78-4200-49b9-ac91-f141d61a1780&pf_rd_r=4M4K9M6JB9WW2K40HFWB&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=4M4K9M6JB9WW2K40HFWB
    Biggest PITA is aligning everything up. I'd use as large (and thin) a fender washer as you can source so that you have some room for adjustment room.
    If you go this route, make sure to buy appropriate strength magnets. Too weak and the sign will tend to slide down under its own weight. Too strong and you'll have a hard time getting the sign off the wall. Good luck.
  13. 458 Spider 0414
    458 Spider 0414 Formula Junior Owner Rossa Subscribed
    Dec 7, 2017
    502
    MIAMI, FLORIDA
    RAY
  14. HH11
    HH11 F1 Rookie Rossa Subscribed
    Sep 4, 2010
    3,345
    I would suggest using an anchor with a heavy duty screw and put it through the center hole in the cavallino. Maybe another underneath its right front leg to stabilize it. If the screw is silver you wont even notice it.
    I have a small black cavallino in my office and did just that. You cant even tell the screw is there.
    458 Spider 0414 likes this.
