Identify your oils here please | Page 2 | FerrariChat
Discussion in '348/355' started by rskdsk, Oct 23, 2009.
  1. PAP 348
    Dec 10, 2005
    100,245
    Mount Isa, Australia
    Pap
    My 348 always had Shell 75W-90 in the gearbox from new according to its service history. :):)
    When I first got the car, it was hard to get 2nd gear. Only could get it when the gearbox oil had warmed up 5 mins down the road. :):)
    When I changed the oil to Redline, I got 2nd gear when cold on the first attempt and it has been perfect silky smooth gear changes ever since. :eek::eek:
  2. PAP 348
    Dec 10, 2005
    100,245
    Pap
    Redline makes the best gearbox oil for these cars by far! :D:D
    Motul makes good oils also, but I wont bother trying their gearbox oil for my 348 now I have Redline in there. :D:D
    Once you find a good product, you stick with it! :eek::eek:
  3. TSM
    TSM Karting
    May 24, 2008
    66
    So Cal
    Troy
    '98 F355 Spider
    All factory specified fluids.
  4. dc348
    dc348 Formula Junior
    May 27, 2006
    386
    Luckily back in HK
    DC
    94 348Sp 42,000kms
    Gearbox- Redline Superlight Shockproof
    Engine- Redline 5-40
  5. bigwave92107
    bigwave92107 Karting
    Oct 6, 2009
    155
    #30 bigwave92107, Oct 27, 2009
    I dropped my car off today and was talking about oils... he said as long as it is GL-5 rated then its cool.
    is the superlightweight shockproof GL-5?
    it says its good for limited slip and locker diffs. so I think its gonna be cool.
    I bought a gallon just like the stuff PAP posted on page 1.
    holler.
  6. AceMaster
    Feb 6, 2009
    34,790
    Ontario, Canada
    What is this and where can I get it?
  7. bigwave92107
    Oct 6, 2009
    155
    #32 bigwave92107, Oct 27, 2009
    everywhere. check the redline website for dealers near you.
    it is a coolant alternative.
  8. I'm gone
    I'm gone Formula Junior
    Feb 5, 2006
    619
    Phoenix,az
    Brian
    engine: Mobil 1 synthetic 0w-40
  9. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    Redline in the gear box and motor.
  10. bigwave92107
    Oct 6, 2009
    155
    just saw this on the redline website.
    http://www.redlineoil.com/product.aspx?pid=42&pcid=8
    Avoid use with pumps, coolers, and filters as unique medium and affinity for metal can cause clogging
    Designed for wet sump transmissions and differentials with splash lubrication
    arent our cars dry sump with an oil cooler...
  11. AceMaster
    Feb 6, 2009
    34,790
    Ontario, Canada
    awesome, thanks!!
  12. FerrariDeeJay
    FerrariDeeJay Formula Junior
    Jun 2, 2009
    418
    Chino, CA
    Michael
    I have a 1995 F355 Spider 6 speed:
    Engine oil- Mobile 1 15w50
    Gearbox-Mobile 1 Synthetic 75w90
    Coolant-Prestone
    Question for any 355 guys using the Redline gearbox oil. Which one works best? the 75w90, the 75w90NS or the superlight?
  13. fvracing
    fvracing Karting
    Nov 4, 2003
    69
    Winnipeg
    Pete
    1995 F355 Berlinetta 6 Speed
    Motul 15/50 Synthetic. Not sure about the rest, but will definitely use redline for trani next time.
    P
  14. Rifledriver
    37,314
    The engine is a dry sump, not the trans.
    It does say specifically though that it is not for transmissions with pumps and all V12 transaxles and all V8 transaxles since QV do have a pump. Additionally all V8's, 355 and up have a transaxle cooler so Redline says you should NOT use this oil
  15. Rifledriver
    37,314
    Redline says not to use Superlight in a car with a transmission oil pump or a cooler. Your car has both.
  16. Llenroc
    Llenroc F1 Veteran
    5,580
    Colorado
    Vern
    +1 Brian
    I was trying to say this a few years ago to those on this board that you should not use the Shock Proof product in our gearboxes. But since there are bigger mouths on here than mine:D there are still some blindly using this instead of the MTL or 70-90w products.
  17. Rifledriver
    37,314
    I never read the website for that product because I never had interest in using it but it does surprise me that in the information age how few do any investigation of any kind when it is so easy.
  18. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    No reason to use Superlight when Redline's Lightweight Shockproof shifts just as well while providing more protection: http://www.redlineoil.com/product.aspx?pid=43&pcid=7
  19. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Redline's MTL is the gear oil that comes with their warning:
    Ferrari goes further, recommending against GL4 gear oils such as MTL.
  20. Llenroc
    Llenroc F1 Veteran
    5,580
    Colorado
    Vern
    "Originally Posted by Redline
    MTL & MT-90 are not for use in differentials with hypoid gears"
    Geez, how many times do you have to be told 348 and 355 gearboxes are NOT hypoid type gears.
  21. striker27
    striker27 Karting
    Feb 22, 2008
    84
    canada
    andy
    Red line every where.
    The coolant I bought at Walmart no idea what it was the cheapest.
    I threw in some Redline Water Wetter though!!!
  22. Rifledriver
    37,314
    That warning from Redline applies to their entire line of Shockproof lubricants.
  23. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    No, Redline has two different warnings; 1 warning about pumps/filters clogging for the Shockproof line and a 2nd warning for the MTL line against hypoid gears.
    Ferrari also weighs in against the MTL line of GL4 oils.
  24. tazandjan
    39,365
    #49 tazandjan, Nov 1, 2009
    ABOUT RED LINE SHOCKPROOF® GEAR OILS
    Acting like a liquid grease, these unique lubricants contain a suspension of solid microscopic particles as an extreme pressure agent, offering a "best of both worlds" balance of low drag and superior protection for gear teeth
    Unique lubricant with solid microscopic particles offers low drag/high protection
    Relatively low viscosity, yet cushions gear teeth under extreme pressure
    Helps to prevent tooth breakage, resists throw-off
    Taz
    Terry Phillips
  25. Rifledriver
    37,314
    No one is, or to my knowledge ever has, advocated the use of MTL in any Ferrari with hypoid gears.
    Could you possibly cite a source for Ferrari saying not to use MTL specifically?
    If you bother to inform yourself about API specifications both GL4 and GL5 are designed for use in hypoid differentials. GL4 is for low to medium offset hypoids and GL5 is for medium to high offset hypoids. But none of that is applicable to this situation as none of the 308/328, 348 or 355 models have hypoid gears.
