Idiot move on my part - help! | FerrariChat
Discussion in 'Technical Q&A' started by setbkk, Dec 18, 2010.
  1. setbkk
    setbkk Rookie
    Mar 16, 2009
    29
    San Francisco, CA
    Steven
    Have a F430. A couple of days ago I was doing something with the accessories and left the key in the on position. Now it is deader than a door nail. Trunk release won't open so I can't access my battery tender or owners manuals. To make matters worse, I am leaving the country for a couple of months tomorrow night. Would like to get this resolved and the car on the battery tender before I leave. Fortunately, car is in garage.
    Any advice for this moron? I don't even recall where the battery is. Is jumping an option without causing damage?
  2. dm_n_stuff
    Dec 10, 2003
    43,887
    26.806311,-81.755805
    Dave M.
    is there not a trickle charge plug installed from the factory?
    My 350 has one tucked into the passenger side brake cooling duct. Just get a tender, plug it in, buy the time you get back you should be all charged back up.
    Otherwise, call the dealer, they'll figure it out for you.
    Jumping it is not a great idea, if it's anything like the 360. All kinds of warnings about zapping the dash if you're careless.
    DM
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #3 2NA, Dec 18, 2010
    If it's completely dead a battery tender might not do the job. You might need to charge the battery a bit first.
    Consult your owner's manual, I'll bet there's a "+" terminal in the engine compartment that you can connect a charger to (clamp the "-" cable to a grounded bolt somewhere nearby).
    After a little while you'll probably have enough juice in the battery to make things work.
  4. BOKE
    BOKE Beaks' Gun Rabbi
    33,965
    600 East Fremont Street
    Lucky
    #4 BOKE, Dec 18, 2010
    Try a trickle charger via the lighter socket if that is live with the key off on your 430.
    Here is my favorite tender. It comes with a lighter plug.
    http://www.saveabattery.com/
    I have six of the All-In-One units. They will bring back a totally flat battery.
    You can buy direct or from Amazon, and no I don't have any affiliation with the company other than being a loyal customer.
  5. sal123
    sal123 Rookie
    Dec 1, 2008
    33
    There is a pull handle under the dash , on the left site . this opens the front boot.
    the battery is behind the panel under the passengers feet.
    You can jump start it with good anti zap jumper leads.
    i suggest , turn off the battery from the switch under the bonnet.
    put the battery on charge ,
    you may need to get a charger that will charge the battery from flat.
    hook it up directly to the battery & leave it overnight.
    hope this has helped.
    Sal
    Racing-Red
  6. setbkk
    setbkk Rookie
    Mar 16, 2009
    29
    San Francisco, CA
    Steven
    Mr. moron, in his panic, didn't bother to read earlier posts about this subject. Thanks all!
  7. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    By US DOT law, there has to be a "manual release" mechanism somewhere on the car to open boots / bonnets in the event of failure of the primary (electric) release. Someone can probably chime in as to where this backup release is on the 430 and how it is activated?
  8. tazandjan
    39,319
    Steven- Go to this site, download an owner's manual for the F430, and look up the location of the emergency releases for the front and rear lids. You can then recharge the battery, one way or the other. Personally, I would not jump the battery, but then I never was particularly adventurous, except for having 2000 hours of fighter time.
    http://www.ferraridatabase.com/The_Downloads/Downloads.htm
    Taz
    Terry Phillips
  9. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    There are a surprising large number of posts about dead F430 batteries. If I had an F430 I would probably be among them-falling asleep in the driver's seat fondling the leather, listening to music.
    Battery is in passenger footwell. Battery has a disconnect switch for long storage with a short 10 second 'self learning' procedure on reconnect. Glad someone was thinking ahead.
    Found a page in the OM devoted to 'Opening the Fuel Filler Cap Flap' in cases of electrical non-function there is an emergency handle in the engine compartment. Fancy.
  10. setbkk
    setbkk Rookie
    Mar 16, 2009
    29
    San Francisco, CA
    Steven
    If I hadn't freaked out about leaving the country for months tomorrow, I would have rationally done some searches and found everything I needed. Nevertheless, thanks to all of you for your advice. What a great forum! Amazing responses!
    Steven
