Idle rises after warm-up | FerrariChat
Discussion in 'Boxers/TR/M' started by Philwozza, May 16, 2011.
  1. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    #1 Philwozza, May 16, 2011
    On the last few drives out in my Testarossa (Euro spec, 1987, KE jetronic) I have noticed that the idle speed sits at about 1,400 rpm.
    From cold engine idles at 1,400 for about 1 to 1.5 minutes and then lowers to 1,200. Its done this from the first day I owned it.
    It stays at 1,200 but after the car has covered a few miles and up to normal temperature I noticed that the idle creeps up to about 1,400.
    The only work I have done on the fuel system this winter is to have all the pipes re-plated
    Is there any reason why this should happen?
    Where should I start to diagnose the system?
    I am suspecting one of the two air bypass valves leaking air when warm.
    Phil W
  2. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Sound like a vacuum leak or air being drawn in. Check your lines. I bet you'll find the culprit. On a side note the buzzing has not returned but it has been cool out. Once the temp outside goes up I should have more to report.
    R
  3. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Yeah, its the same here Robbie. Cooler weather and no buzzing :D
    P
  4. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    your idle set up is probably incorrect. Check fuel mixture with a gas analyzer and set bank balance with two vacuum gauges. Also follow the procedure in the service manual in setting the fuel mixture
  5. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    I hear what you are saying Rocco but, for the first twenty minutes or so of running the idle is perfect at 1,200 RPM and only increases once the engine has got up to full working temperature.
    P
  6. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    the idle and mixture has to be checked and set when the car is up to full temp and the fans have cycled.
  7. Mr.Chairman
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    I disagree.. the hotter she gets the more difficult it is to set the mix... the sweet spot is as soon as the temp gauge reads over 140 when the o2 sensors would normally take over.. disconnect the sensors then set your mixture.. but I dont think Phil has a mixture problem.. sounds more like an air leak.
    R
  8. ALPO
    ALPO Formula 3
    May 13, 2005
    1,482
    Annapolis area
    alpo
    Any idea how I can reset the air/fuel mixture w/o vacuum gauge or gas analyzer?
    I think there are two set screws (bolts actually) to do so. One bank is running richer than the other (almost like flying a twin prop plane w/both engines out of synch). I can feel the differences in pressure and gas in tailpipes.
    Car has no cats/pre-cats and does have test pipes to a Tubi.
  9. Mario Pano
    Mario Pano Formula Junior
    May 24, 2006
    273
    Where ever fun goes
    Mario
    It sounds like you are leaning out more after full warm up.
    Maybe a leaky cold start injector shuts of after all gets hot enough if it is leaking a little fuel after it should shut off.
    You can not adjust your banks with out co and mercury vacuum gauges connected to both banks together.
    Small adjustments in your fuel distributors make huge differences and after done with an alan wrench you have to measure your co with the screws (covering the whole to adjustment) back in since air comes through there and make a huge difference in your mixture.
    Proper adjustment should be done with air by pass screws closed by the throttle screws and fuel adjustment on the fuel distributors.
    Tricky to do right since your little rods effected by the throttle screws are effecting each other when you adjust one (the other changes also unless they are disconnected from each other when adjusting.
    In an emergency with out tools you could theoretically adjust each side to a lean miss and then go back rich until the rpm drops but for the long run you need to be dead on on co (fuel)and vacuum both sides and your idle should fall after free revving and stop at a thousand rpm without dipping or stalling.
    You can make a vacuum gauge your self out of two clear long tubes on a wood stick sucking mercury out of a container at the bottom connected to each side with little t connectors on your vacuum lines on each bank.
    An accurate co meter in a shop somewhere can allow you to do this once if needed and it stays good for ever if there is no issues else where if you got a proper mercury gauge made.
    K jetronic is very dependable and I adjusted mine only once in twenty years and is still perfect .
    Fresh good fuel is key to keep the system trouble free
    Mario
  10. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    This is what I did Mario, all working well again and not a drop of mercury in sight. :D
    P
  11. ALPO
    ALPO Formula 3
    May 13, 2005
    1,482
    Annapolis area
    alpo
    I'll give a go this weekend.
    I did this once before and managed to get the car home okay w/o any tools or guages.
    I think this will be fine to get it to the shop for proper adjustment.
    Ciao,
    360 Modena (on the other F-site)
  12. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
