Idle speed 328 | FerrariChat
Idle speed 328
Discussion in '308/328' started by Alfer, Mar 15, 2015.
  1. Alfer
    Alfer Formula 3
    Sep 4, 2007
    1,360
    NH/the Netherlands
    Menno
    #1 Alfer, Mar 15, 2015
    Idle speed is supposed to be around 1000 RPM. My 328 runs great however idle speed when releasing the accelerator is 1450 and will drop slowly to 1300. When I however make a complete stop (with clutch down and and gear still selected) and slowly release the clutch a bit to put some load on the engine, the idle speed drops to 1000 RPM.
    Can this be the electric switch on the accelerator box that needs adjustment or....
    Thanks for any help.
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,876
    Mike 996
    One thing to consider…
    If you set the IDLE RPM to be 1000 with the AC off, it will drop too low (spec-wise) with the AC on. Remember, these are not computer-controlled engines where the idle will be automatically adjusted based on load… ;) If you never use the AC, then set the idle with ac off at 1000. If you DO use AC, set it at 1000 with the AC on and compressor engaged (which means the idle with the ac compressor off will rise several hundred RPM).
  3. URAS
    URAS Formula Junior
    Oct 17, 2014
    955
    Canada
    vince
    i kept mine at 650 rpm idle. Still pulled without any strain. The odd day if AC required, turned the switch off at stop...:good for a minute with residual and than on once got going.
  4. Rifledriver
    37,130
    Bad idea. The FI does not work well at that low an RPM. There are good reasons the idle is supposed to be 1000-1100.
    Zero advantage to run lower.
  5. URAS
    URAS Formula Junior
    Oct 17, 2014
    955
    Canada
    vince
    Have a 77 cRb not
    Fi.
  6. Rifledriver
    37,130
    Odd
    The question was about a 328 yet you gave info for a completely different car.
    Not a really good choice on your part
  7. URAS
    URAS Formula Junior
    Oct 17, 2014
    955
    Canada
    vince
    Sorry, did not have my reading glasses on and I did not make out the 2 in 328. Realized it afterwards.
  8. Basal Skull
    Basal Skull Formula Junior
    Oct 26, 2010
    427
    Vancouver BC
    I'm learning about these cars too. I assume the 'electric switch' in your pic is an idle speed valve? I've adjusted some of the solenoid types by loosening and turning the solenoid but not sure that 'electric switch' can be adjusted. I did notice that my idle speed went up when I switched to synthetic oil. I adjusted the idle speed down by turning the stop screw on the throttle lever side (the vertical slot screw surrounded by the black plastic surround - I think). Idle speed came down to about a 1000 (on the tach assuming it's relatively accurate) when warm (slightly lower until warmed up and occasionally needing a little throttle for a few seconds) and seems relatively stable. Someone let me know if I did not do the right thing.
  9. Jeka
    Jeka Formula 3
    1,182
    Rotterdam
    Johan
    When it returns to idle only after applying some load you have to check your vacuum relief valve. You can check this by removing the valve and closing the two hoses. If it idles good then the valve is the cause. The valve prevents excessive overrun conditions.
  10. JohnnyTS
    JohnnyTS Formula Junior
    Jun 3, 2012
    907
    Pretoria East, RSA
    #10 JohnnyTS, Mar 16, 2015
    it should be just under a 1000rpm, 900 to 950
    sticky or faulty aux air valve, the one under coolant expansion tank, if the air valve does not close when car warms up after startup and driving it will idle high above 1000 rpm towards 1400 rpm...
    you can test this by blocking the airpipe connected to the valve if the idle speed drops then its defnitely the auxilary air valve.. .
    also lubricated the accelerator cable left of that electric switch and check your throttle linkage if not sticky, new copper slip compound works best..
    flootmats ?? hopefully not ...lol
    cheers
    Johnny
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    That black thing on the right is called a Throttle Position Sensor, and there is no adjustment of the idle with that switch. Idle adjustment is done at the fuel-air metering device (that looks like a big melon, right hand side, under the air filter box).
    At 1400 RPM, your idle is high. What did you do to it before this?
  12. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Umm are you sure about this? I would think the last thing to do would be twiddle the adjustment on the metering device. Everything else would need to be checked first.
    Its probably worth the easy check of the connectors on the AAV and WUR to ensure they are not corroded (the WUR connector is directly under a water-inducing engine cover louvre on the 328) and block hoses on the AAV and the "bypass valve" (top-hat shaped thing) as Jeka suggested above.
    Also maybe check control pressure changes correctly with temperature using a gauge if nothing else found.
    The switch inside the housing should click when the throttle is closed, not a critical adjustment.
  13. JohnnyTS
    Jun 3, 2012
    907
    Pretoria East, RSA
    +1 I did not mention to check the electrical connectors on the warm-up regulator and aux air valve.
    dont mess with the air-fuel metering device unless you know what you are doing, trust me...
  14. yelcab
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    That is true. For CIS one would check the multiple things on the system including system pressure, control pressure, vac leaks, AAV, before tuning the idle. But, if you want to adjust the idle, the place to adjust it is at the metering device.
  15. Jeka
    Jeka Formula 3
    1,182
    Rotterdam
    Johan
    The same way you can check the vacuum relief valve, so you don't have to remove it :)
  16. JohnnyTS
    Jun 3, 2012
    907
    Pretoria East, RSA
    Hey Johan, howzit going there in Netherlands ? I'm visiting in August.
    cheers
    Johan G aka Johnny
  17. Alfer
    Alfer Formula 3
    Sep 4, 2007
    1,360
    NH/the Netherlands
    Menno
    Thanks a lot Johan, i read on an older thread that you had similar symptoms and the matter was solved by replacing this relatively low cost vacuum valve. Will do the suggested trial.
  18. Alfer
    Alfer Formula 3
    Sep 4, 2007
    1,360
    NH/the Netherlands
    Menno
    Johnny, the AAV seems an option as well since the open/close mechanism is just operated by a small coil spring that certainly lost its original properties after 27 years. Also easy and lost cost to replace by new. New you can get at BMW, Alfa, Fiat and likely more.
  19. Alfer
    Alfer Formula 3
    Sep 4, 2007
    1,360
    NH/the Netherlands
    Menno
    Please tell me what WUR is.
    Thanks,
    Menno
  20. Jeka
    Jeka Formula 3
    1,182
    Rotterdam
    Johan
    Hi Johnny,
    It is nice over here and August is a good time to visit because te temperatures will be nice! :) Are you coming for holiday?
    Cheers,
    Johan
  21. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    #21 andyww, Mar 17, 2015
  22. JohnnyTS
    Jun 3, 2012
    907
    Pretoria East, RSA
    Yes, I'm staying in Germany for a week close to Belgium and Netherland which I want to visit and then off to Poland for another two weeks.
  23. JohnnyTS
    Jun 3, 2012
    907
    Pretoria East, RSA
    yes Menno, the warm-up regulator like Andy indicated...
  24. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,315
    Germany
    Steven
    What valve is that?
  25. Alfer
    Alfer Formula 3
    Sep 4, 2007
    1,360
    NH/the Netherlands
    Menno
    Warm-up Regulator, man am i learning things over here! Thanks all
