Idle surging from 1300 to 2000rpm | FerrariChat
Discussion in '348/355' started by Ronnies348TS, Jun 15, 2010.
  1. Ronnies348TS
    Ronnies348TS Rookie
    May 27, 2010
    35
    Chestermere Canada
    Ron
    #1 Ronnies348TS, Jun 15, 2010
    Hello all,
    Well I thought I had solved my surging idle with an ECU reset. Clearly I have not. At idle this car goes up and down in rpms constantly. I picked up some Bosch O2 senors today in the hopes this may be the issue. Any other advice appreciated. Also, when it does idle at one rpm it seems to be quite high. All advice appreciated. I also have to correct my title, it is actually idling at about 1800 rpm and surging to 2700.
  2. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    Could it be a vacuum problem ?
  3. Ronnies348TS
    Ronnies348TS Rookie
    May 27, 2010
    35
    Chestermere Canada
    Ron
    I have had a few other people suggest the same thing. I can actually hear an air noice coming from the right side of the motor but cannot trace a bad line. Any suggestions
  4. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    +1. :D:D
    Hard to say my friend. :):)
    I would just look around to see if any hoses are off their intended place. :):)
    Especially around the right hand side of the engine if you say there is a noise coming from there. :):)
