Idling not stable... Testarossa. | FerrariChat
Discussion in 'Technical Q&A' started by patpong, Dec 9, 2005.
  1. patpong
    patpong Formula 3
    Jul 6, 2004
    2,274
    Bangkok, Thailand
    Patpong Thanavisuth
    Have a drive this morning and notice that the idling isn't quite stable. It went up and down from 1000 rpm to 800 rpm when A/C compressor off. Is this normal for the Testarossa? any parts need renew..?? Please advise.
  2. Steve Magnusson
    26,932
    What engine family is your TR? (it's marked above cyl #6 -- it will be something like F113A, F113B, F113A040, etc.)
  3. patpong
    patpong Formula 3
    Jul 6, 2004
    2,274
    Bangkok, Thailand
    Patpong Thanavisuth
    Just ran out to the car and got the number..... it's F113A. It should be the first of its series...
  4. MordaloMVD
    MordaloMVD F1 Rookie
    Sep 7, 2005
    4,222
    WA
    Michael von Ditter
    If 91TR doesn't have an answere for you, you are in trouble. They don't get any better than him. :)
  5. Steve Magnusson
    26,932
    Almost unfortunately, your F113A engine (K-Jet without Lambda) doesn't have the electrics of the KE-Jet so it can't be the problem that causes an unsteady idle on the KE-Jet with Lambda TR (throttle microswitch not closing at idle). About all you can do is try running some injector cleaner and/or retweaking the idle mixtures (if the warm-up regulators check out as OKish when cold and warm).
    There are so many tight-fitting clearances in K/KE-Jet systems that they really suffer from disuse -- e.g., if one little piece of fuel varnish gets dislodged and stuck in a critical place, you're toast. Sorry I can't be more helpful. Hopefully, it will clear up with more running (with the cleaner), but I have to say that these kinds of problems are more likely when you're bringing an ex-garage queen back to more regular use as you are.
  6. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Most likely it just needs servicing and setting up.
    UK cars are this spec, and they hunt terribly if not tuned correctly.
    Both banks must have identical closed throttle butterfly gaps of 0.003".
    Clean throttle bodies, correct cam timing and good ignition leads/caps etc etc.
    Perfectly synchronise the throttle when actuated by the cable (don't press the linkage with your hand, this takes up joint slack from the wrong direction)
    Set idle speed to be 1100 rpm +- 50 using the (cleaned) idle bypass screws near the butterfly. Use a vacuum gauge to read both banks to pull near identical vacuum. Dont trust the cars rev counter for this.
    Tune K-Jet mixtures to be 0.7% CO +- 0.1 using good quality recently calibrated and serviced gas analyser.
    Note... the fans kick in and out confusing idle vacuum/mixture/rpm, and on a std car, the exhaust swaps side.. LH exit = RH bank etc
    See how you go with that, and let us know.
  7. tbakowsky
    Sep 18, 2002
    20,041
    The Cold North
    Tom
    As in hunting around I presume. I would check all the Steve has stated, and also add to check the vacuum balance for the engine. They should be with close in HG of each other, to be acceptable.
    Does the car drop below 1000 rpm when comming to a stop? As in,clutch depressed and using the brake? Drops to say 400rpm..then shoots back up above 1000, then finaly settles?
  8. patpong
    patpong Formula 3
    Jul 6, 2004
    2,274
    Bangkok, Thailand
    Patpong Thanavisuth
    Thank you for the advise. I notice that it only do that when A/C compress off. As soon as the A/C compressor off, the rpm drop from stable at 1000 rpm to 800 rpm, then it get kicked back up to 1000 then drop to 800, back and forth until the A/C compress run again, then it stays at 1000 rpm. It's like a thing that compensate rpm when A/C is on or off... ( please, excuse my less mechanic knowledge )
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Perhaps it's just a loose A/C compressor belt.
