idrive Garage Door Opener from Wayne-Dalton - Anyone know anything about these? | FerrariChat
Discussion in 'Other Off Topic Forum' started by LetsJet, Aug 6, 2005.
  1. UroTrash
    Jan 20, 2004
    40,476
    Purgatory
    Clifford Gunboat
    Now why didn't *I* think of that???!!!
  2. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    What are you talking about? Did you just purchase an opener?
    I'm thinking of putting a lift in and would have clearence issues with the Chamberlin I have now. I'd still have to raise the rails for the door. Interesting thing is over in the UK they have nice rollup doors that roll up on top of the door. They don't have rails. I haven't found anything like this in the US.
  3. Lloyd
    Lloyd F1 Rookie
    Aug 25, 2001
    2,714
    Austin
    Here are some links that may be of interest to you with regard to roll-up doors. Good luck with your quest. I have not researched the products listed below and can not vouch for them. I just found these links with regard to a project I was thinking about. (P.S. make sure that whatever you get is installed by a professional as this is the largest and heaviest moving object in your home and it operates over your head. In addition, if you don't know what you are doing and are messing around with the high tension springs and you screw up they can take off a part of your anatomy. As roll-up doors are usually used in commercial applications they may not come with all of the child safety devices and other entrapment devices which are standard with door systems designed for residential settings. I am a personal injury attorney and have seen some horrific injuries caused by improperly installed overhead doors and door openers. Be careful.)
    http://www.tracrite.com/
    http://steelbuilding.com/overheaddoors/DBCI1900Select.asp?Size=8X8
    http://www.dbci.com/products_main.cfm
    http://www.cooksondoor.com/newpages/products/a01.html
    http://www.springstreet.com/resources/rollright/
  4. BubblesQuah
    BubblesQuah F1 World Champ
    13,232
    Charlotte
    My brother-in-law just installed one of these on his door about 2 months ago.
    The difference between this and the "regular" track/cable/chain/screw type openers are like night and day. The IDrive is whisper quiet and fast. No track needed on the ceiling, no frame needed to mount it - the above head clearance is of course much better without having all of that stuff hanging there.
    I'd never use a normal opener again.
  5. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    I have two lift master belt drives. There were $450 each installed and are whisper quite. They do have a rail and mount like a traditional opener.
  6. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Actually that's what I have......... Liftmaster belt drives. They are pretty quiet and I've never had a problem. Except they will need (prob.) a min. of 1' and that is room I want for the car when on the lift....
