If a 180º crank is flat-plane and 90º is cross-plane, what is... | FerrariChat
Discussion in 'Technical Q&A' started by Air_Cooled_Nut, Feb 6, 2007.
  1. Air_Cooled_Nut
    Air_Cooled_Nut Formula Junior
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    ...a 60º crank called? Or a 120º? Or a ...? You get the picture.
  2. Steve Magnusson
    26,931
    "different"? ;)
    Seriously -- I've never come across special names for those configurations.
  3. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Exactly.
    The terms flat-plane and cross-plane ONLY refers to v8 engine cranks. This probably comes about due to the enormous amount of slang used in the ever so common v8 engine.
    Thus a v12, v6 could never have a flat-plane crank ... and have proper firing order. It's all just angles to get even firing pulses, no black magic.
    Pete
  4. docweed
    docweed Formula Junior
    Dec 8, 2004
    452
    Morgantown,WV
    Chuck Stewart
    Google: flat engine wikipedia
    This covers all types of engine.
  5. t024484
    t024484 Karting
    Nov 9, 2006
    171
    Netherlands
    Hans A. Polak
    I was also confused because of previous discussions wether a flat 12 Cyl was a Boxer or not, but I think I got the picture now.
    Ferrari has chosen for all the 12 cylinder engines that I could find, either being flat, V60 or V65, a crank that has 6 crank taps resp at 0, 120, 240, 240, 120 and 0 degrees.
    This is called a three plane crank and has the same setup as in a 6 cylinder inline engine.
    A Ferrari 12 cylinder engine is in fact composed of two 6 cylinder inline enginges sharing the same crank, rotated against each other by 60, 65 or 180 degrees depending on the car model.
    A three plane crank can also be a crank that has crank taps at 0, 180, 120, 300, 240, 60 degrees, but this setup was never used by Ferrari as far as I can see.
    A V8 can be two 4 cylinder inline engines sharing the same crank, with crank taps at 0, 180,180, 360 degrees(F360). In this case the crank is called a single plane crank.
    A V8 can also be build with a crank having crank taps in two planes like two combined V4´s, with taps at 0, 90, 270 and 180 degrees (F430), then of course the crank is called a two plane crank.
  6. Air_Cooled_Nut
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    BTDT and it was no help.
  7. Air_Cooled_Nut
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    I really don't want this topic to get into flat engines and flat-plane cranks. A search will bear more fruit on that topic. I just wanted to know if the other crank configs. had unique names or not.
    Three-plane crank. That makes sense, count the number of crank planes. Don't know if that makes it "official" in the SAE world ;) but it sounds logical to me. I guess three or more planes could simply be grouped into a generic term of "multi-plane".
  8. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Wait, are you telling me the F430 doesn't have a flat plane crank?
  9. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    I believe ALL Ferrari v8's do, but this engine when installed in the Maserati does not.
    Everything else t024484 said is exactly right :).
    Pete
  10. Air_Cooled_Nut
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
  11. t024484
    t024484 Karting
    Nov 9, 2006
    171
    Netherlands
    Hans A. Polak
  12. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Hmmm, well that picture does NOT show a flat plane crank, thus I am very surprised.
    I have heard the Maserati Coupe and they sound like a Chevy ... no F430 sounds like a Chevy which is what a 2 plane v8 crank causes.
    Very odd.
    Pete
  13. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Your original question HAS been answered.
    A 60º crank is called a 60º crank, and a 120º crank is called a 120º crank, they are no SLANG terms for these cranks.
    There is nothing special about the term flat and 2 plane, just like a non-rigid framed Harley (ie. it has rear suspension) is called a 'soft-tail' ... it's just a slang term somebody thought of.
    Pete
  14. Air_Cooled_Nut
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Yup, that's what I figured out by post #7. Just wanted to get a solid answer, that's all.
  15. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Having trouble proving the F430's crank is flat :), but
    Hardly as solid as a parts manual ;), but I suspect that the picture is incorrect.
    But this is from Ferrari
    and
    Thus maybe the picture incorrectly shows the Maserati crank?
    Pete
  16. t024484
    t024484 Karting
    Nov 9, 2006
    171
    Netherlands
    Hans A. Polak
    I am also quite surprised, but the drawings that Eurospares uses are from Ferrari.
    look here for the F360 crank
    http://www.eurospares.co.uk/partTable.asp?M=1&Mo=627&A=1&B=35409&S=
    This is very much a single plane crank, like all the V8´s before this model.
    Either the 430 drawing is right, or Ferrari has considered to use a two plane crank but has left the idea and forgot to change the drawing.
  17. 350HPMondial
    350HPMondial F1 Veteran
    5,334
    Edwardo
    #18 350HPMondial, Feb 8, 2007
