If you help me find an F355 wiring diagram, I offer to: | Page 7 | FerrariChat
Discussion in '348/355' started by jm3, Aug 17, 2010.
  1. stickerjay
    stickerjay Karting
    Nov 27, 2007
    56
    Seattle,WA
    Jay
    Here is a pic the circled pins are that of the two that should be powered
    Qavion likes this.
  2. Qavion
    Qavion F1 World Champ
    14,594
    Ian Riddell
    Great shot. Thanks. Unfortunately, the tracks we need to see are on the hidden side. I would try to resolder the contacts without getting solder on the copper areas (on this side of the board). Hopefully the fresh solder will bleed through to the copper tracks on the other side of the "board".
    I don't know how you normally access the other side.
    Experts?
  3. Qavion
    14,594
    Ian Riddell
    In theory, you could solder a jumper wire across those terminals to help with conductivity.
  4. Qavion
    14,594
    Ian Riddell
    By the way, do you currently have continuity between those two contacts? Unlikely, but I suppose the 30 socket itself could have snapped in two. Do you have continuity front to back on pin 30?
  5. Qavion
    14,594
    Ian Riddell
  6. stickerjay
    stickerjay Karting
    Nov 27, 2007
    56
    Seattle,WA
    Jay
    After inspecting the soldiers better I found one that was cracked so I resolidered both power connections and problem solved. Thank you so much for for you guidance and support. I hope this thread helps someone else in the future. If you’re ever in Seattle I owe you lunch.
    Qavion likes this.
  7. Qavion
    14,594
    Ian Riddell
    Brilliant! Thanks for the update.
    It's always great to work with someone who not afraid to pull his car to pieces/experiment. We've all learned something here.
    By the way, did you have any problems opening up the panel? Are there just clips, or did you have to melt something?
  8. Bob0707
    Bob0707 Rookie
    Jul 11, 2023
    6
    Jakub
  9. Qavion
    14,594
    Ian Riddell
    #159 Qavion, Jul 11, 2023
    Hi, Jakub? Bob?
    I’m not sure how to identify your car with a VIN number, but I assume you have a late model car with a 5.2 engine management system. F1 gearbox? Europe?
    Instead of randomly providing diagrams, I do like to know what the problem is with your car so I can guide you to the correct diagram. Also, if fellow owners have similar problems, conversations on fault diagnosis may help them.
  10. Bob0707
    Bob0707 Rookie
    Jul 11, 2023
    6
    Jakub
    Hi, thanks for your replay. My name is Jakub but for firends I'm Bob :p . It's probably US version, it got OBD socket. We got this car from previous workshop... they made total mess with wires and gearbox control unit, I can see one place where should be probably capacitor and it's missing in TCU. We got communication with ECU by generic OBD, we already started the engine by wire the up starter. The starter can't work with ignition switch for this moment, the car probably doesn't have communication with Gearbox control unit. That's why I'm interested in all electrical diagrams for this car, of course I can pay for it if it's needed. Do you have any advise with which diagnostic tester/program we can try to connect with gearbox using 3 wires socket? If it will be easier we can contact also with whatsapp
  11. Qavion
    14,594
    Ian Riddell
    #161 Qavion, Jul 12, 2023
    Sorry for the delay, I couldn't access FChat
    Do you know if the starter relay is working? The F1 TCU controls the starter relay and allows power to be sent to the starter. There is also an associated diode bridge (marked in red on this simplified diagram):
    https://www.dropbox.com/t/imCLJZvc7JBFDID2
    I believe this is in the passenger footwell.
    Is your rear deck lid closed? Are your brake lights working?
    There is another diagram for the F1 system, but it doesn't tell you much more:
    https://www.dropbox.com/t/Xat7YSRMgTHghax9
    Here's the 5.2 Engine Management diagram showing the connector which goes between the Motronic ECU and the F1 TCU:
    https://www.dropbox.com/t/lZ79AXODW39czBvu
    Sorry, I have no idea what tools to use to intercept the signals. As I understood it, the Motronic ECU should tell you if there is no comms with the TCU (through fault codes).
    Are you getting the right indications on the instrument panel? Is the car going into N? If not, have you checked the extra (F1) fuses in the passenger footwell.
    Here's another diagram which shows the relay and diode bridge:
    https://www.dropbox.com/t/4BRva85llmGmmWOA
    Bob0707 likes this.
  12. Qavion
    14,594
    Ian Riddell
    If you disconnected the connector on the TCU and jumpered pins 27 and 30, you could bypass the F1 TCU's control of the starter relay. This would prove that all the circuitry between the TCU and the starter was ok.
    Of course, without the TCU hooked up, you're not going to know if your gearbox is in neutral, so make sure your foot is hard on the brake (or lift the back wheels off the ground) when you turn the key. This technique has been used in manual conversions (on F355's, 360's, 430's etc)
    You could also jumper contacts 1 & 2 on the "Dashboard System Connector", but I'm not sure where that this.
    Bob0707 likes this.
  13. Bob0707
    Bob0707 Rookie
    Jul 11, 2023
    6
    Jakub
    You're awesome! Thank you for your help, in next days I'm going to work on the car and try to fix it
    Qavion likes this.
  14. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    juan villarreal lois
    hi, anyone have the electric diagrams for berlineta 355 manual 1995 ? maybe complete manual apreciated the help, thanks.
  15. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    i need the wiring for the front headlights lifting device
  16. brogenville
    brogenville Formula 3
    2,312
    Robin
    @Qavion Hello Ian, don't suppose you could repost a download link for 355 wiring diagrams please?
    Actually, 348 diagrams would be useful too, as I'm trying to establish if a particular 348 part would work in a 355.
    HNY everyone. :)
  17. Qavion
    14,594
    Ian Riddell
    Any particular part, Robin? What system are we talking about here? Just too many diagams to upload.
    F355 2.7? 5.2? Spider?
    F348 2.5? 2.7?
    Euro/UK, I assume.
  18. brogenville
    2,312
    Robin
    Hi Ian,
    Euro ideally. So my theory is that a 348 oil pressure/water temp gauge might just slot right into a 355 for a manual swap. Obviously it would need a new decal insert, but this shouldn’t be too difficult. I’m keen then to look into the wiring diagrams for each of the 355 F1 / manual and 348.
  19. Qavion
    14,594
    Ian Riddell
    348 Instrument diagram (Euro)
    https://www.dropbox.com/t/X9AXOVrmiZEfpVwt
    355 F1 instrument diagram (USA Spider) is the only F1 one I've got:
    https://www.dropbox.com/t/uTvHK4fEnDihYG0w
    F355 manual (Euro) Instrument:
    https://www.dropbox.com/t/TZBE1juSMxvLZyhx
    The wiring at the back of the F1 instrument cluster is going to be completely different on the F1 because of the F1 gear display. You'd still have to run wires from the oil pressure sensor to the new gauge (probably from plug 41024 under the dash).
    Also, you'd have to know how the gauge is calibrated (in relation to the senders).
    I might be able to give you some ballpark figures for the F355 sender (and gauge) i.e. create a sender resistance/gauge pressure table.
  20. Qavion
    14,594
    Ian Riddell
    Here's what the F1 display looks like:
    According to the manual, here is the pinout for the F1 water temperature gauge:
    It looks like the water temp pinout is similar.
    Here's what the F355 non-F1 display looks like:
    Here's a graph for the F355 water temperature gauge on my manual '98 (P/N 148677)
    I don't know if there is a similar map for the 348 water temperature gauge.
    I haven't yet created an oil pressure graph.
    brogenville and JazP like this.
  21. Qavion
    14,594
    Ian Riddell
  22. brogenville
    2,312
    Robin
    Thanks Ian. There are important similarities, but there are also key differences as well. The 355 has the extra lamps for the warning lights as well as the backlighting, and whilst you might say that you could do without that, the fact that the pins don't look like they line up all that well is a bigger issue.
    I think its a dead end sadly. Oh well, was worth looking at.
    Qavion likes this.
