Ignition and Door Keys | FerrariChat
Discussion in '308/328' started by 1ricardo, Jan 29, 2020.
Tags:
  1. 1ricardo
    1ricardo Karting
    Nov 14, 2012
    69
    Brazil
    Ricardo Baptista
    Dear Friends,
    I have just bought a 1978 308 GTS and the transportation Cia. that I hired LOST the keys for the car
    Now the car is in my driveway with the steering wheel locked and I have no keys!
    So I wonder what to do now and have a few questions :
    1-) It's possible to make theses keys to match my ignition lock system and doors?
    2-) Is the door the same key for the ignition ?
    3-) Does any body know where I can find a locksmith to make theses keys ( I'm in Fort Lauderdale) but any where in USA is a start
    4-) How do I remove the ignition lock system If needed?
    Thank you all for the help
    Ricardo
  2. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,774
    Australia
    Mark R
    Have you checked the car thoroughly.
    Truck drivers have a habit of hiding keys under sun visors, door pockets, consoles, under seats, even hidden in the boots of cars.
    Ianjoub likes this.
  3. LuigiVampa
    LuigiVampa Karting
    Jan 17, 2020
    65
    Todd
    You give your local Ferrari dealership a copy of your title, VIN number, and driver's license and they can make you up a set of keys.
    Crowndog likes this.
  4. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    Any competent locksmith with the correct blanks can make keys. They'll make the door key first. If it works in the ignition, they are done. If not, pay them for 2 key cuts. Probable about $100, cheaper than the Ferrari dealership route.
  5. Banzairacer
    Banzairacer Formula Junior
    486
    San Diego, CA
    Sanjeev Thohan
    Correct blanks can be sourced from eBay.
    Ferrari 308 KEY BLANK SET. Ignition AND Door/Gas keys. 308GTS 308GTB
    The seller is obertro. They’re nice keys. I bought a set as an extra for just such an issue.
    obertRo likes this.
  6. BrockBenson
    BrockBenson Formula Junior
    Oct 18, 2018
    276
    Australia
    On my '84 QV it is a different key for the door compared to the ignition. Totally different type of key :)
  7. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    781
    Treasure Coast Florida
    MATT
    Yes... door and ignition are different keys however I believe both are made by a company called ILCO and believe it or not your basic Ace Hardware carries it
  8. POLO35
    Feb 21, 2005
    781
    MATT
    I don't think the dealer can cut a key from a VIN number from that old a Vintage
  9. kiwiokie
    kiwiokie Formula 3
    1,539
    Tulsa, OK
    John McDermott
    I had some door keys made for my ‘69 Alfa Spider. Bought correct ilco blanks. Took out lock mechanism and left it with the locksmith as it requires some trial and error to get it right. From memory he had to disassemble the tumblers to determine cuts. A week later picked up keys and they worked perfectly.
  10. Sigmacars
    Sigmacars Formula 3
    1,204
    Hi I have the folding key blanks an the Door/gas door keys let me know if you are interested
  11. 328GTSinPA
    328GTSinPA Rookie
    Dec 22, 2019
    42
    PA
    David Felker
    Are the door/gas key blanks the original Torino SAFE keys?
  12. Sigmacars
    Sigmacars Formula 3
    1,204
  13. BigTex
    79,325
    Houston, Texas
    Bubba
    Oh boy..they need to FIND them, you are in the hurt locker, now.
    Door key as above is the least of your worries.
    The ignition key is different.
    Extra set at sellers house maybe?
    I had a locksmith "feel the pins" and make a key, but he ruined the lock doing it.
    MAYBE if you had the Books the dealer wrote the key codes in the Warranty Coupon Book.
    Look there?
    This is really terrible, but as you can tell I lost the "only keys" once and had to work thru it all.
    I ended up pulling the ignition switch entirely and getting it to a local Safe and Lock company
    Same procedure with the doors but truthfully I would buy new locks and keys and call it a day there.
  14. BigTex
    79,325
    Houston, Texas
    Bubba
    Ilco Ferrrari keys for a 1978 are like $3
    Neiman blanks are pricey if you have to have them...
  15. BigTex
    79,325
    Houston, Texas
    Bubba
    Yep, if they scatter the "rooftop pins and springs" they can do anything they want....
  16. 1ricardo
    1ricardo Karting
    Nov 14, 2012
    69
    Brazil
    Ricardo Baptista
    Dear friends,
    Thank you all for the Help and the input!
    I called my local Ferrari dealer and apparently they are able to make some keys ( they charge me U$ 238.00 for the ignition key)
    Mean while I bought a set of blank keys from Obertro. Turns out the Ignition is all the same but the door/gas key has 4 different options model 1,2,3 or 4
    So let's see what Ferrari Dealer has to say to me on Monday...
    But again,
    Thank you all for the help!
  17. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,772
    Cerritos, CA.
    If you can pull the ignition switch off, it will unlock the steering wheel then you can start the engine using a screwdriver.
  18. Lwignall
    Lwignall Rookie
    Sep 3, 2022
    15
    Denver
    Luke Wignall
    For those that land here, Oberto is still sourcing, quick, inexpensive, and super helpful. Plus, my passenger door was keyed differently, or at least not working, and Bill from Maranello Motorworks had a locksmith who easily repinned it to match drivers side.
    However, after brilliantly cutting the ignition key, Ace butchered the door key. Since I had the blanks they did it for free, not that this helped with the second key. Oberto just sent me more blanks, and off we go again…
    obertRo, corey1 and dyerhaus like this.
  19. dyerhaus
    dyerhaus Formula Junior
    Nov 4, 2012
    862
    Santa Rosa, California
    Christopher Dyer
    I'll second that! My car (fortunately) still had both sets of its original keys — a 1975 308 GT4. So I bought two sets of the blanks form Oberto and had a local locksmith cut them. Everything was smooth! In fact, the locksmith thanked me for bringing in the key blanks as they didn't have anything similar (which is crazy as they had a huge wall of hundreds of key blanks behind the counter). Anyway, Oberto was fast, responsive, and very helpful. Now I use Oberto's keys all the time, and only take out the original keys when it's show time!
    obertRo and corey1 like this.
  20. Sigmacars
    Sigmacars Formula 3
    1,204
    Key update all the keys are sold
  21. obertRo
    obertRo Formula Junior
    Dec 20, 2014
    343
    Holland, Michigan
    Robert Clark
    Just stumbled on this thread. I'm "Obertro" on eBay as well as here. Thanks for all the kind words :)
    I can now (Nov, 2024) cut door keys to original Ferrari spec's if you have the key code (4 digits on TORINO key).
    I hope one day to be able to cut the ignition keys, but have not found a way to decode these numbers yet.
    I have also taken apart a couple 308 and one 330 key cylinders that had no keys and made keys for them. Not inexpensive, but not "Ferrari" expensive either.
    dyerhaus and miketuason like this.
