Ignition condensor specs | FerrariChat
Discussion in 'Technical Q&A' started by Difaz, Jan 22, 2009.
  1. Difaz
    Difaz Karting
    Mar 30, 2005
    116
    Sydney Australia
    Phill
    What are the correct points condensor for a single distributor model 308. My points on one bank are notched. The other side are clean but the condesors do not have any ID specs.
    Regards
    DIFAZ
  2. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,441
    B.C., Canada
    The dual lead condensors I have didn't have any markings on them, but the single lead condensors had this:
    Magneti Marelli - CE29T (microfarad) 0.25
    Here in Canada (and it is applicable to the U.S. as well), Echlin MA-3 condensors from NAPA auto parts are the correct size and microfarad rating and are a good substitute for the single lead condensors only. The old "FAF Tuning Tips & Maintenance Techniques" book by Gerald Roush and John Apen suggest GM condensors although not which model of GM car. They do mention those are rated at 0.18 microfarad. I haven't found anywhere a dual lead substitute for the original Marelli version.
    I hope this helps.
  3. Difaz
    Difaz Karting
    Mar 30, 2005
    116
    Sydney Australia
    Phill
    Thanks for your response Peter that is exactly what I needed to know.
    I can conclude from that info that I probably have two different condensors. The lower rating condensor being on the points that are notched.
    From my days at the Tafe college as an apprentice mechanic, I remember my teacher saying "notch negative, not enough". That means if the points have a notch (small indent from arching) on the earthside of the points, then the condensor is not rated high enough.
    I suspected I had the wrong condensor on one side but didn't know how much higher to go.
    Thanks again Peter
    Regards
    DIFAZ
  4. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    Gee. Its years since I last heard that!
    Think it might've been ultimo college I heard it at too.
  5. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,441
    B.C., Canada
    And thank you for that helpful hint. ;) I hadn't heard that one before.
  6. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Definately needs to go in the same tool drawer with 'righty tighty, lefty loosy'
  7. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Wow, I was thinking the same phrase yesterday but didnt post it. Unbelievable.
