Ignition help please! | FerrariChat
Discussion in 'Technical Q&A' started by Nickt, Nov 22, 2007.
  1. Nickt
    Nickt Formula 3
    Feb 24, 2006
    1,741
    Iver, Buckinghamshir
    Nick T
    Hi, my 78 Euro GT4 has developed a strange issue.
    Sometimes, when the ignition key is at the auxilary position (first click) the ignition light comes on along with all the auxilary circuits. Its not a fault in the key switch, so what could it be?
    If I pull the ignition wire from the fuseblock and put it back on, the ignition light goes out. Is there a relay failing?
    Cheers
    Nick
  2. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    It sounds that way. How do you know it's not the ignition switch?
  3. Nickt
    Nickt Formula 3
    Feb 24, 2006
    1,741
    Nick T
    I don't think it is, because when I pull the wire from the fuse block that powers the ignition circuit and leave it off for a mion or two, then reconnect it the ignition light goes out. you can hear a relay click.
  4. Steve Magnusson
    26,932
    Does your key switch assembly actually have a physical detent at Position I? Your OM only mentions using Key Positions 0, 2, and 3 , however, the schematic implies that the ignition switch construction is such that, by turning the key only part way to Pos II, it will turn on some Pos II circuits first and not some other Pos II circuits until you reach the Pos II detent.
