Ignition key switch fried? | FerrariChat
Discussion in 'Boxers/TR/M' started by danielc1, Oct 14, 2012.
  1. danielc1
    danielc1 Rookie
    Feb 11, 2008
    38
    Belgium
    Daniel Cappelle
    My car, a 512tr, is in for a yearly maintenance. Got a call friday from the dealer about the start problem I have had with the car. When I start the car sometimes I only get a click. Hot, cold doesn't matter, sometimes just click and no starter running... The dealer has revised the starter and have found now another problem: The ignition (key) contacts are fried so they want to replace it. It will be about 1400$ to replace it. Besides the money, I do not like the idea of having two separtly key's. One for the door and one for starting the car. Do any one know of a different solution for this kind of problem? I want to sell the car and I think that having two separtly key's is a minor...
    Thanks,
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,540
    romano schwabel
    you may change the complete ingnition switch with key and remove the door locks and rebuilt them to this new key or just put in an extra starter knob you may start the engine with
  3. danielc1
    danielc1 Rookie
    Feb 11, 2008
    38
    Belgium
    Daniel Cappelle
    Thanks for your answer Romano.
    The starter button is out of the question. It had a start button when I bought the car, but the car needs a yearly inspection for the road and they will fail every car with a start button that is not original from factory. So I needed to remove the start button to be street legal. I know that this is not a problem for Germany.
    Changing the door lock is an option. Do you know the price range of doing this and who can do this?
  4. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    hello daniel,
    this I never heard that the yearly or 2 yearly road inspection will nor accept this starter button. here in germany we never have problems with this when this button is switched so that it works only when the ignition is on. but this is no problem to make. I also have registered some cars in france and there the controle technique accept this starter button without any problem or discussion.
    it shoud be all equal in whole europe with those regulations??? you may ask about this there
    to change the inside of the locks I did it already on some VW, BMW, MERCEDES, FIAT and also on Ferrari ( 365 GT 4 - 2+2 and also the 400 ) I think it would be the same, but not sure. it takes normaly about 30 minutes each lock when I only have this lock and the key and the right plates to change. otherwise those plates have to been adjusted. on a TR I never did it until now and I also don´t know how such a TR lock looks like because never had one to fix. you may put one lock out and make a picture, then I can tell you if it would be easy or not.
    the question is if it is worth the whole labor because of having then only 1 key for all???
    on my TR 87 I just have the dashboard out because of installing a touchscreen for all my meassurments. as I see there the ignition switch and the electrical part is one piece? the whole part is fasten by 2 special srews what will brake the head when they are fixed right. so to remove this part you have to destroy those screws. may be that the electrical part is separatly and could be removed on a simple way? and could replaced then by a FIAT part or any other italian part. most are very equal.
    I would first remove the keyswitch and habe a look what is really wrong. may be you still can fix it? good luck !
  5. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    Off-Topic, sorry: you wrote "on my TR 87 I just have the dashboard out because of installing a touchscreen for all my meassurments "
    Can you make a new thread about it with text and photo's please ?
    Hi Daniel, I remember you were over here in Holland and had a starting problem also ...
    We rumbled at the powerlead and it was fixed then ......
    Why should the starter be burnt ? How do they know that ?
  6. danielc1
    danielc1 Rookie
    Feb 11, 2008
    38
    Belgium
    Daniel Cappelle
    Mel: It is still the same problem. The car always has had this problem, since I had to remove the start button to get it registered in Belgium. I think the ingnition switch was fried before I bought it and that was the reason it had a startbutton to begin with.
    Sometimes it start with no problem, and sometimes I need to turn the key 8 or 10 times before it will start. The dealer thought first it was the starter at the engine, but now they are pretty sure that it's the ignition switch at the key...
  7. danielc1
    danielc1 Rookie
    Feb 11, 2008
    38
    Belgium
    Daniel Cappelle
    The dealer told me that the switch is one part with key and electronics and that was the reason of being of a higher price then with another car where the switch, electronics and key are separated... I do not know if it is possible to dismantle the unit...
  8. YellowF50
    YellowF50 Formula Junior
    Feb 15, 2007
    840
    K B
    Some ignition barrels are separate from electronic switch, and simply clips on to base of barrel and turns with keys to different terminals on, but the year of car it probably has the sealed unit to prevent it popped off to start with screwdriver by thieves.
    Anyway it all comes apart with patience and knowledge, as it wasn't fabricated in one piece with different tumblers, and the electronic switch at the base. The problem is the barrel will not come out without removing it from the column. And the column is held together via sheer bolts where the head of the bolt snaps off to prevent removal by a thief, so a drill is the only option.
    A new bolt should be supplied with barrel, but when you have a ignition barrel (either new or old ) in your hand with the key in the ignition half way down the stem there will be a a small hole the size of a matchstick.
    Now you put the key in the ignition and turn to position 1 and push something in the hole (might find it easier to put something like Allen key in hole and keep it pushed in whilst you turn key and feel it push in pin) then pull out the barrel with the key ( don't remove the key as the tumblers can fall out and give you problems).
    Repeat with other barrel and put your old key and barrel in new barrel with new switch, make sure the switch has not turned ( so barrel pin will line up with switch ) push in until it clips in place turn key to check it all, remove key and put it back in and turn to make sure it all works.
    Now put it all back together, and you have new ignition with old key, if you are not capable of doing it yourself depending on time involved in removing sheer bolt ( snapped head bolt), but I would imagine any decent mechanic will do this in less than 2 hours. And the process of barrel swapping will take less than 5 mins, so it's worth asking if you are having the barrel replaced anyway.
    Hope this helps.
  9. danielc1
    danielc1 Rookie
    Feb 11, 2008
    38
    Belgium
    Daniel Cappelle
    Thank you so much for your answer. Now I know what to ask to keep the old key.
  10. danielc1
    danielc1 Rookie
    Feb 11, 2008
    38
    Belgium
    Daniel Cappelle
    Litlle update: The ignition switch is new and the dealer has made the lock's of the door too fit the new keys... It was indeed with 'plates' in the doorlock that could be changed to fit any key... few hours of work...
  11. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    so not such a big deal as you thaught first. good to know this with the plates, so same as the 365, 400 and 412, and I think much more other also
