ignition module | FerrariChat
ignition module
Discussion in 'Technical Q&A' started by gabriel, Feb 5, 2004.
  1. gabriel
    gabriel Formula 3
    #1 gabriel, Feb 5, 2004
    Greetings:
    I'm still on the upside of the learning curve re. certain ignition electronic items.
    Can anyone explain exactly what this ignition module does?
  2. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    It looks like a power module. If so it tells the coil when to discharge.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,666
    San Carlos, CA
    Mitchell Le
    If it is a Lucas module, then the purpose is to keep your car ... in the dark. Lucas, the Prince of Darkness.
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    There is also a Bosch equivalent available at most regular parts stores.
    This is the unit (in the 328, at least) that sits on the top of the coil and has a history of failing (at least with me).
    Ferrari does not sell them separate, but sells you the module and coil as a unit which they are quite proud of, judging from the price.
    hope this helps
    rt
