Ignition ON Switch in engine bay (for EFI installation) | FerrariChat
Discussion in '308/328' started by DanielGA, Aug 14, 2020.
  1. DanielGA
    DanielGA Karting
    Mar 19, 2018
    145
    Midwest
    Daniel A.
    Hello,
    I have a Mondial 8, which has the 2v 308 engine, and I am installing EFI and full aftermarket ECU (AEM brand). Anybody know of a convenient source in the stock engine bay to get "ignition on". I see that to solenoid of the starter I get the "ignition start" signal, but what I am searching for is the ignition on ... I have some electric wiring diagrams but cannot decipher where in the engine bay is such a signal ... I'd rather not have to run a wire all the way to the ignition switch in the cockpit...
    Any suggestions?
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I think the fuel pump goes on at ignition on and if so might be used as an ignition on signal?
  3. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Don't know anything about the Mondial 8. But I'm almost positive that you're going to get an ignition source at the harness that feeds the stock digiplex.
  4. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I was thinking the same but don’t know on that car where the box is located.
  5. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    I think the fuel pump only works when cranking or the air plate in the fuel distributor is deflected. Just use a test light and take one of the wires off the coil or Digiplex
  6. Ferraridoc
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    D'oh! Didn't see your replies - I let my subscription lapse, and the pop-ups often obscure some of the page :mad:
  7. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I would imagine the + terminal on the coils is a pretty solid signal for ignition being on.
    Saabguy and Crowndog like this.
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
    One of the three wires that goes to the solenoid is connected to the ignition switch, you can tap it from there but use a test light to find out which one is connected to the ignition switch.
  9. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,952
    The Cold North
    Tom
    Use your ignition switch as the power source. Run a new fuse and wire directly. Dont try to jump into any existing harness connection points.
  10. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Well, since he's going with an aftermarket ECU - the existing harness connections will already be reused, yes?
  11. tbakowsky
    Sep 18, 2002
    19,952
    The Cold North
    Tom
    If that is the case..then build a complete stand alone harness completely separate from the cars existing harness. Power it up by it own fuse board using key on ignition power direct from the ignition..just like the factory would do. Distribute power from the fuse board as needed.
