Ignition problem, symptoms, ideas | FerrariChat
Discussion in '308/328' started by Irishman, Jun 9, 2008.
  1. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,526
    Raleigh
    Kevin
    #1 Irishman, Jun 9, 2008
    Looking for ideas for diagnosing what seems to be an ignition problem with my 78 308.
    Background: 3000+ care free miles since my last "major" work. Back then I replaced the plugs (NGK BP6ES) gapped at .030, kept the extenders, replaced the wires (Accell 4040R), replaced the brush and springs, ditched the R2, replaced the main points and condenser, have replaced one coil (front 5-8). Timing set at 5000rpm. Idle timing "not exactly on the mark". Car has run good. Maybe a dead cylinder or two shortly after startup but seems like all on line after warm up. Again, 3000+ miles running pretty good.
    Then all of a sudden I lose 1-4 a mile from home. Limp back and look at the plugs. Hmmmm.... Pictures of the plugs right after I pulled them are attached. Cleaned them up (gapped at .025) and drove again for 30-45 minutes of happy driving, though I hear a few more exhausts pops than "normal". What should I do next? There are two pictures for each plug from 1-4. So, two pictures of plug 1, two pictures of plug from cylinder 2, etc.
    I know the carb cars require a certain mind set, patience and skill. While willing I might be lacking at least two out of three :):).
    Seamus
  2. Steve Magnusson
    26,931
    #2 Steve Magnusson, Jun 9, 2008
    If you can't reduce the richness and maintain good driveability, you might try a set of the NGK Iridium plugs to see if the fouling interval can be extended out to something not so annoying ;). Anti-fouling (or, maybe, better resistance to fouling) is a true benefit of these small diameter center electrode plugs made from the exotic higher melting temperature materials IME.
  3. BillyD
    BillyD Formula 3
    1,835
    Pacific Northwest
    Bill
    This sounds very similiar to a problem I had. The culprit was a bad/weak condensor. Compare the coil performance on front vs rear bank by holding each coilwire 1/4 inch from engine while cranking. Bright snappy blue or dull weak yellow? Just my .02
    Bill
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Just my experience, but my carburrated car also tends to like it a bit rich (actually all Ferraris do giving them their historic reputation for fouling plugs around town). There are two things I would suggest you look at doing that worked for me.
    I have had a very good experience in keeping plugs clean in a relatively rich environment with the MSD 6 multi spark box and an MSD hot "Blaster 2" coil combined with a relatively hotter plug for street driving. Your car would require two MSD 6 boxes and MSD Blaster 2 coils, one for each coil. This combination gives multiple very hot sparks at lower rpm ranges where fouling is common, and in combination with a hotter plug rating my little car has never fouled and been bulletproof reliable so far for 4 years, even with around town driving.
    Another somewhat more involved thing you may want to look at are your carb jettings and settings. Most of day to day around town driving and cruising is actually done on the idle/transition circuit (unless you are really ripping everywhere). One change to consider is going down one size on your idle jets if they are larger than 50s. for example, if you are running 55 idles, you may consider downsizing to 52s, or even 50s. If a flat spot in transition ensues with the smaller idle jet, you can bring in the main circuit earlier with one size`larger main jet for a smooth transition. This has been a successful strategy for me.
    I would look at providing a hotter spark first as Steve has suggested, and follow up with the carb changes if fuel fouling persists. Good luck, this will be a good thing.
    best
    rt
  5. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I'm running BP5ES plugs in my 77 and they stay pretty clean. I ran the 1st set for 5 years and just recently did a "birdman" carb tune up and replaced the plugs. I am running a Pertronix breakerless ign. and set the timing at 7*btdc. Car runs good.
  6. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    My first thought was to go to the BP5ES plugs as well. It sounds like everything else in the system is in good condition. Try the hotter plug and see if that helps keep them cleaner. Otherwise, the carbs my need to be adjusted or rejetted to lean them out a bit.
  7. BigTex
    79,404
    Houston, Texas
    Bubba
    I agree Seamus, man those are DARK plugs! LOL!
    Go to the BP5ES that's what I run and truthfully even your gap at .025 is the upper part of the specified range, .015 - .025...I gap mine just a smudge tighter, bang them on the driveway 'till they read .022....
    And quit loafing arounf town, get out there and hit the HIGHWAY!!!!!! :D
    I guess I'll have to spring for some Iridium, if Steve M. likes them !! :D :D :D
    I have one cylinder wanting to misfire it won't be long......crap for gas these days...
  8. BigTex
    79,404
    Houston, Texas
    Bubba
    I have gone to MSD coils only, like Russ decribes, in an otherwise stock ignition, they have an epoxy potted one that is made for our laydown installation, couldn't hurt......
  9. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    IMHO, since it worked OK for 3000 miles the changes you made aren't the problem. I'd use an Occum's Razor approach and check for a bad or badly connected coil high tension wire, bad plug wires, etc.
  10. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,526
    Raleigh
    Kevin
    I regret I am unfamiliar with that approach. Can you elaborate?
    I have taken careful note of the suggestions made so far. In particular, I think the switch to the hotter plug could be beneficial, in general.
    But, yes, I drove a *long* time for a *lot* of miles on the previous setup. In that world the cylinders not coming right on line at startup seems suspicious. The only other procedure I can think of is pulling one wire at a time to try and find a dud.
    Seamus
  11. Red 27
    Red 27 Formula 3
    Feb 2, 2008
    1,002
    San Diego, Ca
    Dave
    Hey Seamus,
    I had a similar problem on my 75 gt4 many years ago. The culprit was a weak alternator and battery. The farther I drove the worse it got.
    The fact that you lost a whole bank of cylinders in a snap sounds electrical to me. What were your gauges doing while it was running bad? Mine were jumping all over.
    I am not a mechanic but I did stay at a Holiday Inn.....
    Good Luck,
    Dave
  12. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,526
    Raleigh
    Kevin
    #12 Irishman, Jun 17, 2008
    Don't recall the gauges at the time but they are flaky -- tend to come online only after I pull out of the garage. It might be worse than one bank but when the problem occurred it was only the 1-4 bank.
    I have been off in the mountains on my Harley and had no chance to work in this. On Monday I had to move the 308 as I am having the garage floor done up nice. Lots of exhaust pops. Points/timing/coil -- something is wrong.
    Or, as you suggest battery or alternator. Though on my bike if the battery isn't getting 14v or so then the charging system is suspect. It tends to work, maybe slightly poorly, until it just dies totally dead.
    Seamus
  13. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    I have to agree with Dave. While change to a different plug may help for certain conditions, you have a whole bank failing at once. That's got nothing to do with plugs that are too hot or too cold, the culprit is a fault. Go over your ignition system with a tester, shouldn't be too hard to trace.
    Good luck!
  14. Mike Florio
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    Sorry, I should have elaborated: The simplest solution is probably the correct one.
    Go over the ignition system for that bank
    Check the distributor cap for cracks
    Check the resistance from the pins inside the distributor to the end of the lead, especially the one that goes to the coil with a VOM
    Check the low tension lead between the coil and the distributor - clean up the contacts and wiggle the wire looking for an intermittent short
    Check the points (burned/pitted?) and check the timing, especially the advance (rev motor and make sure the distributor advances.
    Swap the coils and see if the problem changes banks
    etc...
  15. philvecc
    philvecc Formula Junior
    Nov 3, 2003
    751
    Longmeadow, MA
    Philip Vecchiarelli
    I've got a similar situation with my '85 euro. Engine starts, runs fine for a short period (few minutes to 1/2 hour), pops, and then the rear bank drops out.
    We've tried swapping the modules, swapping the coils, replaced the distributor caps, replaced and swapped TDC sensors, checked alternator output, checked plug wires, suppressors, coil lead.... Frustrating!!!!
  16. Red 27
    Red 27 Formula 3
    Feb 2, 2008
    1,002
    San Diego, Ca
    Dave
    Hi Phil,
    Does this happen once in awhile or every time you drive it ?
    Does the engine cooling off seem to help for awhile ? another cycle of good to bad.
    Maybe someone else has experienced this phantom problem.
    Dave
  17. philvecc
    Nov 3, 2003
    751
    Longmeadow, MA
    Philip Vecchiarelli
    Dave,
    It has been in the garage for a few months now, and a little time is spent on it each week. Basically every time, it starts cold, and then runs for a while, anywhere from a few minutes to a half hour before the bank cuts out. When restarted warm or hot it will usually run a shorter length of time before it cuts out again.
    It acts like a heat related problem but don't know where else to look.
  18. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Phil,
    If I recall correctly, your car has three sensors; one for the tach, one for the front bank and one for the rear bank. Is the shop aware of this set-up? Two of these sensors are semi-visible, the third one is not.
    If I were working on this car, I'd have a scope connected to the "suspect" bank, starting at the correct crank sensor to see if your losing the signal to the electonic ignition unit. If so, great; there's the problem. If not, just keep moving upstream to see where the ignition signal is lost. Swaping parts is great, but if you have an intermittant connection/connector, they'll never find it this way.
    Although I can feel your frustration, this should be a fairly straightforward problem to find.
    Regards,
    David
  19. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,526
    Raleigh
    Kevin
    (I know I should have been working on this before now but with summer come many motorcycle weekends in the mountains for me :):) ).
    Cranked it again tonight to see how things are. Idle not right. Occasional exhaust pops. No exhaust pushing out the right rear (ie USA passenger side) tips. Right rear exhaust tips are bank 1-4, yes?
    Thanks,
    Seamus
