Ignition trouble | FerrariChat
Ignition trouble
Discussion in '308/328' started by daniel sternotte, Aug 10, 2022.
  1. daniel sternotte
    Aug 10, 2022
    3
    Daniel Sternotte
    Hi there
    After having washed my 308qv spider with a hose the car fired up with great difficulties and wouldn’t idle properly nor run on all eight cilinders. Also a smell of gasoline comes out of the exhaust when running…
    Anyone a guess?
  2. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    Seems obvious that some part of the ignition system got wet and that created a problem. More than likely it will go away once everything dries out. Could be a chore to debug while everything is wet, but you may get lucky and see clues (spark jumping, etc).
    GordonC and thorn like this.
  3. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Check for wet distributors, and connections.
    GordonC and daniel sternotte like this.
  4. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Wait till this evening (after dark). Open engine cover, start car and observe the light show! :)
  5. daniel sternotte
    Aug 10, 2022
    3
    Daniel Sternotte
  6. daniel sternotte
    Aug 10, 2022
    3
    Daniel Sternotte
    Thanks for the advice. Will wait till dark and watch. But :
    Just tested all spark plugs.
    Rear cilinders: 2 and 3 give no spark.
    front cilinders : 2 gives no spark.
    Rather strange?
  7. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    741
    Omaha, NE area, US
    Steve
    While you are waiting for it to get dark you can remove the distributor cap(s) and dry them out. If you do so, I'll wager your problem will go away before dark.
    GordonC likes this.
  8. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    852
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    Another vote for a Wet Dizzy .
  9. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
    If moisture gets inside distributor cap, this will and can cause your issue. Dry it or spray WD-40 should fix it.
    4rePhill and GordonC like this.
