Ignition wires 3500 GT | FerrariChat
Discussion in 'Maserati' started by ch2056, Nov 24, 2013.
  1. ch2056
    ch2056 Karting
    Jun 11, 2008
    68
    Netherlands
    Marcel
    #1 ch2056, Nov 24, 2013
    Hello,
    I have made a slight modification under the bonnet off 3500 GT 101-442.
    The single ignition wire tube only allows small wires and I wanted to go to 7mm copper core wires. It is impossible to get 14 7mm wires through the tube so... I have solved this in a 250F-ish style by placing two ignition tubes.
    Now only 7 wires go through each tube in stead of 14 through one. Plenty of room left now.
    (The old tube and wires are safe on a shelf.)
    The misfires I had before are history now but I know the wires I had were old so 5 mm wires in one tube would have solved the issue too.
    what do you think of the slight modification??
    Marcel
    www.am101.org
  2. rentsch1961
    rentsch1961 Karting
    Oct 22, 2012
    83
    Geneva, Switzerland
    Alain RENTSCH
    Hi Marcel,
    I think it gives a cleaner look. And you did it very nicely regarding the routing and lenght of each cable.
    Alain.
  3. Volante 43
    Volante 43 Karting
    Nov 8, 2011
    73
    The Netherlands
    Rudolf J Visser
    #3 Volante 43, Nov 24, 2013
  4. ch2056
    ch2056 Karting
    Jun 11, 2008
    68
    Netherlands
    Marcel
    Thanks Ruud,
    Did you shorten the tubes?
  5. Volante 43
    Volante 43 Karting
    Nov 8, 2011
    73
    The Netherlands
    Rudolf J Visser
    #5 Volante 43, Nov 24, 2013
  6. mfletch
    mfletch Formula Junior
    Nov 3, 2008
    480
    Marcel, you did a great job on the wires. Your engine compartment looks fantastic. Ruud, your engine compartment looks great also. I notice the extra bracket and return spring you have connected to the throttle linkage. I need to fabricate the same thing. My car had one installed by the previous owner. I thought that when I rebuilt the carbs, it would eliminate the need for it....I was mistaken. I will make a bracket for mine using yours as a template. I hope you do not mind me copying yours. Thanks for posting the picture.
  7. ch2056
    ch2056 Karting
    Jun 11, 2008
    68
    Netherlands
    Marcel
    Ruud I know you have your sebring I for 40 years already. This is the original wire tube I suppose? Never noticed they are different from the tubes used on a 3500GT.
    Marcel
