Ignition WOW moment | FerrariChat
Ignition WOW moment
Discussion in '308/328' started by electrogunner, Jul 3, 2014.
  1. electrogunner
    electrogunner Formula Junior
    Sep 2, 2013
    322
    Amish country PA
    Joe
    Just a little history on it.
    Ever since I bought the car it had a miss in it but overall seems to run find. So a couple of days ago decided to put my timing light on the plug wires to see if I was getting juice at the plugs and I found #2 on the front bank dead, good I found it. So I started pulling wires and plugs and alot more wrong. Same #2 had a large crack in extender, no burn marks because no juice. Then #3 on front bank had a badily burned and melted extender!! I continued pulling everything out and found plug #2 plug #3 on opposite terminals on cap!! Wow. And I thought is was running pretty good. I wonder how it will run when I get it sorted?? When I get home I'll take some pics of the extender. Bad Bad. :eek:
    Sent from my DROID RAZR
  2. electrogunner
    Sep 2, 2013
    322
    Amish country PA
    Joe
    Check Your Wires!!! You guys may be surprised as to what you find. :eek:
  3. Wilson308
    Wilson308 Formula Junior
    Apr 27, 2012
    635
    Arkansas, USA
    Wilson
    As noted in Allen Bishop's book, Ferrari engines have a way of being so fantastic that they can trick you into thinking they are running great even when they are terribly out of tune. I would also add the loudness of the engine (both exhaust and valvetrain) can make it difficult to detect issues that might be more easily noticed on a quieter engine. Good that you caught all that, at least it's all easy fixes. +1 to checking the wires if your other components were in that shape. The silicone sleeve over them can be misleading about what's happening underneath.
  4. electrogunner
    Sep 2, 2013
    322
    Amish country PA
    Joe
    I think some 3M tape should fix it up. ;)[​IMG]
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    So, from now on, whenever you say my ___ modification is so good it feels so much faster than ____, we can safely assume that you butt dynamometer is ... worthless... --)
  6. electrogunner
    Sep 2, 2013
    322
    Amish country PA
    Joe
    Hahaha. You got it. That's funny:p
  7. shmark
    shmark F1 Rookie
    Oct 31, 2003
    2,968
    Atlanta
    Mark
    Looks familiar! Had a similar issue with my car. It ran very well but always had a slight stumble at idle. Then one day I lost a cylinder, driving home on 7 in the driving rain. One of my extenders looked like yours (source of the dropped cylinder), and a couple others had pinholes. I also tested my wires and they weren't consistent. Finally I pulled the distributor caps and found the caps worn and the rotors badly pitted.
    New plugs, wires, rotors, caps and extenders, and the car runs beautifully and the idle is perfect. I also took the chance to replace the distributor shaft seals, curing an oil leak that was filling the boots. All in all, a relatively inexpensive fix that made a big difference. Take care of everything and you will not believe the difference.
  8. AHudson
    AHudson F1 Rookie
    2,781
    Florida
    Adams Hudson
    Great reminder to not overlook basics.
    My car went in for belt service (first of its entire life!). Tech pulls wires for load test:
    First one is at 60%
    Second one is at 40%
    Need I go on? Plus, fuel hoses had turned to oatmeal A quick call to Dave Helms and I have new plug wires, fuel lines, coolant hoses. I'll sleep better, I'll wake better.
  9. electrogunner
    Sep 2, 2013
    322
    Amish country PA
    Joe
    And this was connected to front coil!! How was this thing even running??[​IMG]
  10. JohnnyTS
    JohnnyTS Formula Junior
    Jun 3, 2012
    907
    Pretoria East, RSA
    whow man, pretty good find, LOL, good find ! Electrogunner (is that the name of an Arcade Game ) hehe
    cool pic :)
  11. electrogunner
    Sep 2, 2013
    322
    Amish country PA
    Joe
    I'm not sure. But I would play it. :)
  12. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    This area is the simplest to check and unless there is history that the wires , rotors , extenders and plugs been changed it is an inexpensive fix.
  13. electrogunner
    Sep 2, 2013
    322
    Amish country PA
    Joe
    I replaced
    Wires Taylor spiro- core 8mm 350 ohm / ft
    Plugs NGK BPR 7 eix
    Extenders. 0 ohm model
    Cleaned up rotor and cap contacts
    Metered new wires through cap to plug ends. All good before install
    New cap gaskets
    Now I have a miss at about 5000 rpms and at idel the tach jumps a bit from 1000 to 2000 and back intermittently. Never did that before. I have searched for possibilities and grounded the digiplexes with a second ground with no change. Last night I started it up and turned out the lights looking for arcs or crosstalk between wires. All looks good. I'm not sure if the miss is associated with the tach jumping or not. I will probably pull the new plugs and wires and extenders to recheck it tonight. I do not like the new extenders with the small clip. Also I did verify with a timing light I was getting spark to at least the top of extender. Any ideas from you guys would be appreciated. I was also thinking flywheel sensors since the tach needle was jumping and its just a coincidence with the wires and such ??????? Thanks
  14. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Don't be offended.. but check your wiring again, VERY easy even being meticulous, to wire it wrong.. and it will make the "slow down" light come on.. huh.. or so I hear..
  15. electrogunner
    Sep 2, 2013
    322
    Amish country PA
    Joe
    I'm not offended. Everyone has a brainfart every now and then:eek: I have a 85 euro qv so no slow down light. I do plan on checking all the plug wiring tonight but I don't think that would effect the tach needle but I have been wrong before. Once ;)
  16. jessup
    jessup Formula Junior
    Apr 26, 2014
    403
    Santa Clara CA USA
    Jessup
    What are the plugs gapped at? What is battery voltage while running?
  17. electrogunner
    Sep 2, 2013
    322
    Amish country PA
    Joe
    Plugs gapped to .30 straight out of box. I checked all of them. I will check generator output while running before I pull anything. Thanks
  18. electrogunner
    Sep 2, 2013
    322
    Amish country PA
    Joe
    I meant .030. .30 I huge:eek:
  19. singletrack
    singletrack F1 Veteran
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    That sucks! Good job finding it!
  20. electrogunner
    Sep 2, 2013
    322
    Amish country PA
    Joe
    I still haven't found the smoking gun yet:confused: Still looking
    Any ideas??
  21. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,150
    SanFrancisco BayArea
    1983 US 308 GTS QV
    I will be troubleshooting an irratic misfire on my '83 QV this weekend. My timing light says its my rear bank.
    Here is an thread regarding an alternative to OEM cables:
    http://www.ferrarichat.com/forum/308-328/298179-blue-fire-spark-plug-wires.html
    I got some trouble shooting advice from a factory trained technician (I hope I got this right):
    - If the wires are actually grounding, they will have burn hole somewhere on their length. Look for burn marks. (I suppose this is true of the extenders too, although I have new ones on order.)
    - If there are no burns, then check their resistance which should be a fixed ohms per foot.
    - My misfire started shortly after I replaced the rear distributor boot so this is the smoking gun for me. Something I didn't do when I reconnected the ignition wires back to the rear distributer, was to have nipped off 1/4" from the end of each wire to removed the old pierced section so that the new piercing entered a fresh piece of wire.
    - I have new-ish Iridium plugs. My plan is to pull the plugs, gap them to 0.028" (NKG website says to gap Iridium plugs to manufacture spec just like any other plug)(NGK Spark Plugs USA - Gapping Spark Plugs), remove the rear wires from the distributor, test their resistance and either reinstall or replace. If the rear wires pass, I won't mess with the front wires.
  22. electrogunner
    Sep 2, 2013
    322
    Amish country PA
    Joe
    Thanks Brian. My next plan of action also includes pulling the new wires,plugs and extenders and re metering them. I have the original ohm readings recorded, if any of them are drastically different it could be caused by a slow burn through.
    Joe
