355 - Immobiliser lockout after too many PIN attempts? | FerrariChat
355 Immobiliser lockout after too many PIN attempts?
Discussion in '348/355' started by redwedge, Apr 17, 2025.
  1. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    437
    London
    Steve C
    I retrieved the PIN from my immobiliser using a brute force approach implemented using a Raspberry Pi to simulate key turns in the ignition. I was quite lucky and the machine hit upon the correct PIN after a thousand and something attempts.
    I'm using the same approach with a friend's immobiliser, however as the setup neared 5000 attempts, the immobiliser behaviour changed. The LED output no longer flashes every 0.6 seconds when inputting a PIN; instead, it simply mimics the ignition key input: ignition on, LED on - ignition off, LED off.
    I know that the modern Ghost immobiliser locks out after 5000 attempts and wondered if anyone is aware of similar behaviour in the Bosch system?
  2. Mike Morrissey
    Mike Morrissey Formula 3
    1,129
    Denver, Colorado
    Mike Morrissey
  3. BenjaminB
    BenjaminB Karting
    54
    Lewisville, NC
    Benjamin
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,394
    San Carlos, CA
    Mitchell Le
    Third vote for Gobble.
  5. redwedge
    Sep 30, 2012
    437
    London
    Steve C
    Thanks all - I've IM'd him.
  6. redwedge
    Sep 30, 2012
    437
    London
    Steve C
    No reply from Gobble; not surprising as this is his business and I do not judge him at all for that. However... it turned out that my box had actually found the correct PIN and the immobiliser was actually in learning mode - I just hadn't recognised it. Perhaps slightly different timing or behaviour to the previous immobiliser I "cracked", one being 167065 and this one being the later 168508.
    Qavion likes this.
