360 - Immobilizer defeat - Dome Light Issues | FerrariChat
360 Immobilizer defeat - Dome Light Issues
Discussion in '360/430' started by Qavion, May 3, 2025.
  1. Qavion
    Qavion F1 World Champ
    14,312
    Ian Riddell
    Just a tip regarding 360 dome light operation (when you open the doors) after removing the Immo ECU as part of an Immo defeat....
    On the 360, the left and right door pillar microswitches normally send signals to the Immo ECU when you open the door/s. This is partly because the Immo ECU handles automatic dome light operation (and light time delays when you close the doors). If you remove the Immo ECU, you have to perform a bypass to get the dome light to operate automatically.
    Jumper these pins on the 20 pin Immo plug:
    i.e. pins 8 and 11 (white/black and white wire respectively).
    You won't have a time delay, but the dome light will go on when you open a door (if your dome light is in the automatic setting)
  2. one4torque
    one4torque F1 Veteran
    5,725
    Houston
    One4torque
    Qav = top 5 360 witch doctors around! Thanks!
